Refurbishing a 'fuser'
Can you refer me to a dependable outfit that i may send our fuzer to get refurbished?
  • mike56 Jun 03, 2008
    We have a Ricoh Aficio 2028P, that we want to excange or send its 'Fuzer' for refurbishment.
    Any outfit?
  • Dave Toombs
    Dave Toombs May 11, 2010
    What make, model of copier or printer do you have and what needs to be done?
    Dave T
Generally what does it cost to refurbish a Doc 12 fuser. Mine has new heat and pressure rollers, the upper bar with the stripper fingers is missing fingers or has damaged fingers, also the chrome door at the end of the fuser, the one that swings up is bent and will not lock in place properly.
Posted on Sep 19, 2008
    Novelist:
  • 158 Answers
Try www.partsnow.com. They refurbish fusers for many office machines.
Posted on Jun 03, 2008
How do you replace the fuzer and what is the fuzer?
Its the heater section of the machine which melts and presses the toner on the paper and no need to replace the fuser section as it it a 100 dollar disposable machine so better buy a new machine.
Jun 18, 2014 | Xerox Phaser 3100MFP/S Laser Printer
What is a 50.2 fuzer on a printer
Your laser printer has a fuser on it, this device is used to fuse the toner to the paper. This is a consumable item and does need replacing. The error you are getting is requesting you to replace the fuse. Below is a list from Amazon of available fusers online:
http://www.amazon.com/s/?ie=UTF8&keywords=2840+fuser&tag=googhydr-20&index=aps&hvadid=3997274965&hvpos=1t2&hvexid=&hvnetw=g&hvrand=17470625861140096160&hvpone=&hvptwo=&hvqmt=b&ref=pd_sl_47sd1z0h1s_b
Hope this helps
Mar 26, 2012 | HP LaserJet 2840 Printer
Fuzer noise problem
I would recommend having the fuser looked at by a professional. If he/she cannot find something wrong, then there really isn't anything you can do. You could try to replace the fuser though, aand see if that makes a difference.
Feb 17, 2011 | Canon LBP3460/33ppm Laser Printer
Horizontal lines in mits dlp wd52725 problem started right before old bulb went out, put new one in and it seems to be worse. Is picture and sound but have lines in cable, hdmi, and in aux. inputs. Is...
This has been a very common issue with this model series. Unfortunately there is no quick cheap fix. The correct way of repairing it involves removing the Chassis Cluster and sending it back to Mitsubishi for refurbishing. The cause of the problem is many capacitors are failing or have failed across 4 or 5 boards. The way the chassis is laid out it is most difficult even for the professionals
to totally tear it down and rebuild it. Average cost of refurbishing is around 600.00 to 800.00.
Because Mitsubishi is not going to support this model series much longer, I would look to replace instead of repairing it.
I hope this helps,
skyassoc
Dec 10, 2010 | Mitsubishi Televison & Video
I need to upgrade a samsung code w/windows 6.1 to windows 6.5, itsthat pposible, Ihave metro pcs. thanks!
It is possible. I have a Samsung Code that has been upgraded to Windows 6.5. Mine was done by Samsung. I have had many problems with the phone. After the fifth time of sending it in to them, they refurbished it. Upgrading it to 6.5 was part of the refurbishing process. So I do know that it can be done. I do not know where you can go to have it done, other than Samsung.
Sep 03, 2010 | Cell Phones
Same problem
The fateful Green LED Blinking problem can be fixed only in my opinion by sending the Chassi Assay. out to Mitsubishi for Refurbishing. It is a costly endeavor but it will fix it. You can contact Mitsubishi at 800-332-2119. They will need to refer you to a Auth. Mitsubishi Service Facility to come out, remove, and reinstall chassi. Refurbishing of the Chassi would cost aprox. 700.00 to 800.00 plus Labor and Service Call Fee if any.
I hope this helps,
Skyassoc
Jun 22, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Refurbishing
If its just cosmetic issues then you can go on ebay and buy one that dont work and just use the parts to replace on yours.
Jan 19, 2009 | Nintendo DS Lite Console
I took my ds aprt put it back together and no power on?
Oh... Taking your DS apart is a huge no no! Only professionals should take apart your DS. That goes for other items as well.
I suggest that you take it to a professional and have your DS refurbished. Refurbishing makes your DS like new, and can cost anywhere from $70 - $90, depending on where you take your DS to be refurbished.
Hope it helps~
HP Color Laser Jet 1600 Problem
Hey I have 1 problem I have the printer of 2600n when i give print Command of RED Colour its come orange and right side i get light print and left side i get little dark print , what is the problem i don't understand any can help me . Thank u Morgan.M
Dec 12, 2007 | HP Color LaserJet 2600n Printer
k24674
jasbo
jasbo
