Question about Craftsman Garden
My Craftsman 3-one lawn mower, Model: 917.373981 will start, but immediately stalls. The air filter is clean. Please let me know your solution recommendations. Thanks!
2 Suggested Answers
  • 636 Answers
SOURCE: my craftsman lawn mower stalls .i changed the oil
Is your primer button stiffing up when used or is it or does it remain sponge ? Or you may have something in the carb .Take the bowl off and clean it. Is your gas fresh or has it been sitting around awhile? Hope this helps you out.
Posted on Jul 29, 2009
My lawn tractor craftsman 14.5hp IC OHV B&S stalls approx. 5 mins after starting so I restart and it can stall in another 10-15 min again and so on.
you may have some debris in your gas tank blocking the pickup tube. It will float away when the mower dies, then block the tube after it runs again.
Jan 03, 2017 | Craftsman Garden
I have a 7 year Craftsman 17.5 HP 42 in. lawn tractor. It starts to leak gas recently and stops frequently after running over 30-40 minutes. I can not identified where is the gas leak from but I saw gas on...
I have a Craftsman mower. Last year I had a similar problem with the mower stopping after running awhile. I noticed that the plastic gas tank was collapsing. The next time it began to stall, I immediately loosened the gas cap and it didn't stall. The vent holes in the cap had plugged up. Check this out.
I can't help you locate the fuel leak, although it sounds like the carburetor float is not stopping gas from flowing into the carburetor.
Dec 02, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
CAN A VERY DIRTY AIR FILTER PREVENT MY 6.0 HORSE POWER PUSH MOWER FROM STARTING? i.e. GAS FOUL SPARK PLUG AFTER ONLY 3-4 PULLS
Yes, if your air cleaner is dirty it will cause the condition that you talked about...flooding.
You need to either replace or clean your airfilter.
The following is for the foam type air cleaner.
Normally if you clean your filter, you would wash the air filter in a cleaner such as kerosene or diesel fuel, dry it, add a little bit of oil to the outside of the sponge filter and squeeze it to distribute the oil around the filter.
This is a free answer, Please rate me
Oct 13, 2010 | Craftsman 675 Torque 190cc 21" RearBag...
Mower surges its a 5.5hp craftsman mower
Carburetor possibly needs cleaning. Initially, remove air filter, start mower and while it is running, spray some aerosol carb/choke cleaner into the carb thru air intake area. Continue doing this several times but not too fast or heavy to make it stall and then spray it heavily until engine dies. Let it sit for several minutes and then try a restart. If no difference in performance is noticed, carb may have to be removed and cleaned in bath-type cleaner and governor settings will need to be checked also.
Please vote on this solution.
Sep 13, 2010 | Craftsman Garden
Craftsman 16.5hp 42 in. Mower runs for about
mine always starts-- and won't start again if I turn it off- going to try the flywheel key replacement-- which affects the timing-- otherwise-- let me know what you find out as a solution
May 24, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
22" Rear Bag Rear Propelled High Wheel Lawn Mower (): I can't find the manual -- how do I start the mowe...
Fully depress primer bulb only 3 times, then pull starter cord. Ensure air filter is clean and gas is fresh before attempting to start.
May 16, 2010 | Craftsman 22" Rear Bag Rear Propelled High...
My lawn mower starts, then stalls immediately.
the carb will need to be removed and cleaned and blown out or ultrasonic cleaned is best if you can get that done? if not a can of carb or brake cleaner and blow through all the jets the blow out with compressed air
Jul 08, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Can locate air filter on Craftsman 5.0 lawn mower Model#971 377 2
It is behind the cover hooked to the carburetor.
Mar 25, 2009 | Garden
Garden Logo
283 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
