Question about Kitchen Ranges
Ge side by side m# gss25qgmd coil freezes up, seems like no power to defrost heater
  • 57 Answers
Defrost heater, defrost thermostat on evaperator( pink and orange wires I think). If computer model check to make sure orange wires on plug going into cabinet near compressor are connected. Not enough information to help you.
Posted on Oct 15, 2010
Ge side by side ref.
no,its more than likely the defrost heater located just under the coil thats freezing up,check this heater for continuity,if its o.k. then test the defrost thermostat thats clipped onto the same coil near the top of the coil,note,the defrost thermostat needs to be below 15 degrees to check good as its a thermal switch,then if still problems then check the main board in the back of the unit behind a panel this is where the defrost circuit gets its power,but i will likely say its the heater thats open because i replace about 5 per week with the same issue as yours
May 22, 2012 | GE Refrigerators
Model GSS25SGMCBS coil freezes.heater checkedout ok service man changed the circuit board for $312.After 3 days, same problem again. Freeze temp ok but refrigirator sectio quit working after coil freezes....
Control board is new, heaters ok, Check defrost thermostat and thermisters located on evaporator.
PC board not getting information to defrost properly.See site below
Also check the fill tube at ice maker . Iv'e seen these get loose and fill evaporator with water causing ice block
good luck
GE Refrigerator Repair Guide
Aug 16, 2011 | GE GSS25SGMBS Side by Side Refrigerator
Hi, my GE refrigerator has ice developing on the rear wall of the freezer, and things in my crisper drawer are freezing solid,please help!!!!
Unplug refrig. Empty all food from freezer side and remove shelves from freezer. Remove back metal cover from inside freezer. Melt frost with a hair blower. Examine defrost heater at very bottom of the coils you defrosted. If heater coil inside glass tube is broken, replace defrost heater. (note: replacement may look different, but insturctions included with replacement address that) If heater is not broken, replace the small white pencil shapped sensor at the top of the cooling coils.
Dec 26, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a GE GSS20IEM side by side. It is not
The possibilitty is the 8 hour timer may be defective. This timerr is the one which cut off the compressor and powers the heater to defrost the coooling coils to condense the water to the try below. If this wont happen then the possibility of the cooling coils building up frost will decrease cooling. The thermostat can also be a culprit as the thermostat is also in circuit . You can see if the timer works in this cycle by shutting off the fridge for several hours and restarting to check the defrosting cycle.the timer is placed near to the compressor unit and the heater near the cooling coils. Hope you check this out. Good day .
Jul 26, 2010 | GE GSS20IEM Side by Side Refrigerator
Freezer side still freezing but frig side not cooling at all.
The defrost heater is located on the evaporator coil (located in the freezer compartment) and is designed to melt the frost from the coils. If there is power getting to the heater and it will not get hot, the defrost heater is most likely faulty. It should have a resistance of 20-50 ohms in most cases. Part number=> WR51X100423f97641.jpg Can be also purchased here=> Appliance Part Southeast
The defrost thermostat is designed to turn the power off to the defrost heater once the coils are clear of frost. It is a temperature actuated switch and once the coils are clear, the thermostat will open and the heater will be turned off. If the thermostat does not reset once it gets below freezing, it is most likely defective. Part number=> WR50X10054
Can also be purchased here=> Appliance Parts Southeast You may contact me here at Fixya or Appliance 911 or through my website SEA BREEZE APPLIANCE PARTS AND TECHNICAL SERVICES Thanks,and if you have questions or need help please let me know, Sea Breeze
Dec 30, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE side by side. The freezer will freeze up with
Replace the defrost heater, located at the bottom of the cooling coils, behind the back wall of the freezer.
Aug 04, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE side by side GSS20IEP Refrigerator freezer freezing
this is a problem that is no stranger to most GE side by sides; GE has used a glass type defrost heater in the freezer which often fails. If you manually defrost your appliance (unplug and leave doors open for 24 hrs) then plug back in, it will appear to work normally for a few days and gradually build up frost on the evap panel (back panel in the freezer) and eventually the refrigerator side will seem to loose cooling due to frosted damper, or lack of cold air transfer over the evap coil. The fix for this is to replace the defrost heaters (s). While not as common, defrost thermostats can open causing the unit to skip defrost, and even less likely is the defrost control (either mechanical timer or adaptive defrost). First, defrost your appliance, then remove the evap panel and ohm out the heater(s), if open, replace. If they check ok, check your defrost thermostat (small disc like object attached by a clip on the evap. coil itself) for signs of popping open or open ohm readings at normally closed temperatures. Its a good idea to change this anyway when replacing defrost heaters as the two work hand in hand. Last, check the defrost timer by manually advancing the screw advance clockwise until you hear the first click, then check voltage to the defrost heater and thermostat, if no voltage present replace timer. If your appliance is equipped with a adaptive defrost board, refer to the schematic for proper diagnostics.
Jun 11, 2009 | GE GSS20IEP Side by Side Refrigerator
GE TFX20JR BK WW side by side won't cool or freeze
First point: The entire fridge is cooled by the freezer section. A fan blows air across to the food section.
2) Every 8 hours or so, a timer shuts off the compressor cycle, and starts up a heater to defrost the freezer coils. If the heater(s) are burnt out, or if the safety thermostat (to prevent overheating) is open, then you will have no defrost. The coils will frost up and eventually prevent airflow to the food section. Milk goes sour.
3) In rare circumstances, the timer itself can stall. This cause the same symptoms as above, but this is not as common as the other 2 causes of No Defrost.
Sequence: Check heater continuity. Check safety thermostat continuity while cold. Check defrost timer operation.
Hope this helps. I am a journeyman with 39 years exp. Happy New Year.
Dec 24, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE refrigerator TBX25zpk coils Freezing
It's almost always the defrost heater. If you have volts to the defrost thermostat the defrost control is working. Set your meter to check ohms and remove the wiring from the heater. If anything changes when you touch the meter leads to the heater terminals then the heater is probably good, but my guess is nothing will change, which means you've got a bad heater.
Jul 21, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Frozen Freezer Coils
all of the above the heater is on the coil you will seethe wires the therm. is on the top of coils timer could be at lower back of refrig.
Nov 15, 2007 | GE GSS25JEMWW Side by Side
Kitchen Ranges Logo
65 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
