Question about Acer Veriton L410-ED4450C PC Desktop
My cd rom is not working and i have a cd jammed in the drive
    President:
  • 2,571 Answers
Have you tried pushing something into the eject hole on the front of the drive
Posted on Oct 15, 2010
How do I get a cd that is jammed into a cdrom drive out when the drive will open.
there is a little hole in the cdrom\'s door.....prick it with a pin and the cd will come out
Oct 15, 2014 | Gateway Computers & Internet
Can't eject CD from CD rom
Disassembling may be your only option, if the CD is Broken or jammed. Try rebooting and pushing the DVD rom button at boot. I had a DVD explode, I had to remove the drive and disassembling the DVD rom to remove all the pieces.
Apr 07, 2013 | Acer Aspire Z5700 All-in-One Desktop Pc
Acer CD is not getting ejeccted
The mechanism is physicall jammed.
Take a Norwegian paper-clip, and straighten one end.
Push that end into the small hole in the faceplate of the CD-drive.
Push until you feel resistance, and then push another 1/4 inch (10 mm).
The door should "unlock" -- gently pull the tray the rest of the way open, and remove any disk.
Then, it's time to spend $40, to buy a new CD/DVD reader/writer.]
Sep 20, 2010 | Acer (91.49C37.001) CD-ROM Drive
Cd drive door was jammed and so i deleted the High and Low filters using regedit and now the dvd rom will not write however it will read. How do i fix the problem...im using a Dell xps 400 which has a...
You can go to dell's website support.dell.com to download the firmware of the dvd/cdrom. if you want to knpw the exact model of your drive you can check it at device manager,to dell's website Use your service tag to see the list of the drivers for your system when you go to support.dell.com click drivers and downloads.
Jul 20, 2010 | Dell DVD-rom DVD Drive
Cd rom door wont open
Do you see blinking light on your CD Drive. If not, you may need to check you power supply to CD Drive.
If yes, may be door looks jam, opening up once may remove any dust to smooth it out again. To open up there is small pin hole on cd drive, generally on the right side, use needle and press it through the pin hole, it will eject the CD Door and you can pull it out completely.
May 13, 2010 | Computers & Internet
I have a HP desktop PC and the DVD/CD ROM keeps opening and closing. How can I fix this? Thanks
It has gone faulty, this is not normal behavior. You will have to replace it. Check the button on the front, ensure it isn't jammed on?
Feb 26, 2010 | E-Machines emachines (emachinees) CD-ROM...
My CD rom drive won't eject the cd on my Dell Studio Laptop. I press the eject button on the comp, and the click eject on the cd screen, and it makes a noise but nothing comes out.
You may have a cd jammed in your drive. Switch the computer off and on the front of the CD rom drive is a small hole, if you push a straightened paper clip quite hard into this hole it will open the drawer.
Nov 07, 2009 | Dell (0F146) Internal DVD Drive
A cd broke in my cd rom
I've seen and come across cd-roms where cd's have broken (or in most cases exploded/shattered). In one case the drive flew open and bits of cd flew across a classroom, in most cases the drive remains shut (even the tray can get jammed).
This problem is usually caused by a flaw on the cd itself, a scratch or mark on the cd causes it to 'wobble' and due to the speeds cd-roms spin cd's they come off the 'spindle' inside (all that holds it on is a magnet).
I have taken cd-roms apart and removed all the cd parts and the drive has worked perfectly afterwards. Other times the drive has needed to be replaced, so i would say its purely luck if your drive isn't damaged in some way.
Although the problem could have been your drive. Without being able to get the drive ejecting and spinning cd's again you'll never know... just make sure you don't use an important cd to test it with!
Dec 27, 2008 | E-Machines emachines (emachinees) CD-ROM...
CD ROM is jammed-wont open
This has happened to me. Sometimes when I'm in a hurry I'll place a CD or DVD in the tray and start to close it without making sure that the disk is seated flat in the tray. If it's ****-eyed the CD wil shatter when the tray is closed. The only way to remove the pieces inside the CD drive is to take apart the CD drive. Might be easier just to replace the unit. They run from about $25.00 to $75.00. One other note: You can try to open the tray manually by inserting the end of a paper clip into a small hole on the front bezel of the drive.
Oct 17, 2008 | E-Machines emachines (emachinees) CD-ROM...
Cd rom
its very simple .remove the outer cpu case.then remove the cd rom open itplace THE TRAY in RIGHT MANNER ONCE AGAIN . donot try to move the tray of your cd rom without opening the cd rom ,it might result in a permanent damage
Nov 03, 2007 | Packard Bell GCD-R580B (gcdr580b) Internal...
Acer Veriton L410-ED4450C  PC Desktop Logo
77 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
