Question about Zoom G1x Guitar Multi Effects Pedal with EXpression Pedal
Hy everyone, The left knob of my G1X is not working properly. You have to push it down so hard to make it works. Thas part can be repaired?
  • 94 Answers
NO.
Posted on Oct 25, 2010
  • gklohn Oct 25, 2010
    YES.
My zoom g1x theres no sound.all power are working lcd light are on.but the sound cannot come out.can any one help me..
What letters / numbers that appears on the screen?
If the display is normal, and you can switch to other banks, and can edit each bank, then the problem of no sound, is at the pre-amp IC input, output amp, or CODEC converter.
This is the overall image of G1X inside.zoom-g1x-theres-no-sound-all-power-2ss5ycyvkoajtv035dpuezke-2-0.jpg Next, we zoom-in the middle of picture above.
See the next picture.
IC2 (left) is input pre-amp IC (NJM2100).
IC4 (middle) is the CODEC IC (WM8734).
IC5 (right) is the IC output (NJU7082).zoom-g1x-theres-no-sound-all-power-2ss5ycyvkoajtv035dpuezke-2-1.jpg
Test whether the input IC is working normally, turn ON G1X, plug the guitar, go to BYPASS/TUNER menu. When the TUNER function could work, certainly input IC is not damaged.
Means only two possibilities, namely CODEC and output IC. That is not easily tested, except in specific ways.
May also, there are problems in the input / output socket.
Turn ON G1X. Try the following (see figure below):
  • Test the output socket. Touch pin output socket (right red arrow) with finger / screwdriver / whatever. If sound is heard in the amplifier, the output socket is normal.
  • Test the input socket, Same as above. (left red arrow). (if this happen in this point, problem is clear).
NOTES:
If lcd light are on (as you say), but appearing G1 or d5 or bt, and the system are hang / frozen, this is a different issue to the one described above,and dealt with in different ways too.
References IC datasheet:
NJM2100.
http://www.njr.com/semicon/PDF/NJM2100_E.pdf
NJU7082
http://www.datasheetarchive.com/dlmain/Datasheets-22/DSA-439015.pdf
WM8734 http://www.cirrus.com/en/pubs/proDatasheet/WM8734_v4.4.pdf
Sep 10, 2015 | Zoom Music
Zoom g1x dc supply not working, my zoom g1x is working when battery operated but if i connect it to a adaptor there is no power, i've already checked my adaptor and it was properly working, what can i
Some possibilities:
  • Damaged on the DC-IN socket.
  • Broken solder joints on the center pin of the DC IN socket (see figure: pin 1 on DC208B).
  • Damaged (broken) in D2 or R54
Aug 18, 2014 | Zoom G1x Guitar Multi Effects Pedal with...
Circuit diagram of zoom g1x
G1X circuit diagram is the same as the G1. They differ only on the pedal circuits.
circuit-diagram-zoom-g1x-shyexoo0xcste5eq310zs3ot-4-0.jpgcircuit-diagram-zoom-g1x-shyexoo0xcste5eq310zs3ot-4-1.jpg
Give your email,and I'll send the circuit diagram.
Jun 24, 2012 | Zoom G1x Guitar Multi Effects Pedal with...
Zoom g1x dc supply not working, my zoom g1x is working when battery operated but if i connect it to a adaptor there is no power, i've already checked my adaptor and it was properly working, what can i...
Is the unit old?? Is it stored in an environment that has temperature fluctuations?? It could be the terminals on the input of the unit have dry jointed. This is when the solder lifts away from the circuit board. I have had the same problem on my ZOOM MRS1608 recording desk. Resolder the connections on the input. The base plate will problably remove easy enough to get to the point where the adapter is soldered onto the circuit board.
Good luck
Aug 11, 2011 | Zoom G1x Guitar Multi Effects Pedal with...
G1X not working
The first thing to check is the power source. A weak battery or adapter will cause this.
Beyond checking these the only other problems will be internal and require electronic servicing.,
Jul 02, 2010 | Zoom G1x Guitar Multi Effects Pedal with...
When I turn on my G1X it just says "d5" and doesn't play any sound or lett me choose patches
i have the same problem, but if i use it in the morning it works normally, and my G1X pedal also doesn't work for wah efx, let me know when you fixed yours and how it is done tnx..
Jun 12, 2010 | Zoom G1x Guitar Multi Effects Pedal with...
Zoom G1X Repair!!!!
If the pedal still works, likely the circuit board is not cracked.
The control that is damaged is LIKELY an encoder.
Many of these are made by ALPS, Bourns and others.
You need to open the unit top get at the device.
The encoders are available from either DigiKey.com or Mouser.com
Here is an example page:
http://search.digikey.com/scripts/DkSearch/dksus.dll?Selection
You need to match the pinout and part number if you can find it on the part.
May 13, 2010 | Zoom G1x Guitar Multi Effects Pedal with...
Zoom G1x Guitar Multi Effects Pedal with EXpression Pedal Logo
243 people viewed this question
Top Zoom Music Experts
Barry Webster
Level 1 Expert
patonplace
Level 1 Expert
Are you a Zoom Music Expert? Answer questions, earn points and help others
