Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
I have a 6 yr old Whirlpool side-by-side fridge and we've had the same problem over and over. No one seems to know what is wrong. 1st there would be water just leaking from the back of the freezer and eventually out to the floor. The drain would plug-up with ice. We also have a lot of frost build-up in the middle vent in the refrigerator side. When i open the freezer door i can feel cool air coming in the top vent to the fridge side but when i close it...nothing. it takes me 30 min to an hour to defrost the vents so it can cool the fridge side and repeat the whole process every 6 weeks but now its every week. please help! E from Illinois
  • Whirlpool Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 17, 2010
Whirlpool Refridgerator Model # ET1FTKXKQ00 My Question: I can not seem to locate the hose that would take the moisture from the freezer/fridge to the evaporation tray at the bottom. My fridge is...
Hey i think they freze free lol and thers no tubes they are connected by chanels/ tunels blockes at the back fron freezer down. Reg temp yr nobe controler could b gone or temp module. So thats why it wont help lol check if the temp changes after yr turning it, so atleast u can iluminate that.. if it is working. Than i would sugest next checking yr front doors rubers and magnets on them all the way and both doors.. as wen it gets old it could b having gaps so there 4 it will not close the dore properly and u wont even know or notice and if thats the case. Thats why it running inside, as it not fully and all aront germeticky closed .. hooe that helps you . G/luck ??.. Tony
Apr 19, 2017 | Whirlpool Refrigerators
Regulating Temps on Whirlpool Side by Side
well i think you know what this is!!!!
you moved it and it got upset about it?
but some freezers need to be dead upright
or,,,its the darn thermostat's there playing you up like mad if you cant control them there on there way out
best bet is have new ones fitted or just dump it all together,,after all think of how much that floor is worth? and how much ice cream do you need????
ps,,,i use a hammer drill to get my ice cream out the tub?? have you ever tryed "fried ice cream" its realy
"""""yucky"""""??? (sorry im mad you see)
Oct 28, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a 3 yr old side-by-side. The freezer is freezing ice cream solid even though it's turned all the way down. Food in the bottom two drawers on the refigerator side are freezing. Water has dripped...
Hi, this problem is going to be with the running thermostat. (cold Control). It has gone bad and stays open which in turn will keep the compressor running continually and will cause the fridge to get colder and freeze food. It can normally be located in the control panel inside the fridge (it is the control that has wires, the other is the damper). Locate the thermostat and replace it. If you have any other questions or concerns please feel free to comment again. Good Luck!! Mike
Oct 22, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Fridge running hot!
One you can to try and extend the life of the fridge is to vacuum off the compressor and coils. They can be located either behind the toe grill on the bottom front or through an opening on the back of the fridge. It is natural for a fridge to blow warm air.
Aug 30, 2009 | Maytag MSD2454G Side by Side Refrigerator
Our whirlpool 6 yr old refrig / freezer is not working correctly
Use a vacuum and clean under your fridge. A dryer cleaning brush will help make the job go much faster. Use a good light so you can get all the lint out. Give it 12 hours to level out. hope this is helpfull.. Saw
Aug 09, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
13 yr old Whirlpool side by side fridge temp. contol problem
Is your model the ED25PQXF ? Can you explain what you need to do manually to cause it to work? The thermostat? If thermostat is the answer the thermostat will need replaced. By straight wiring the 2 wires it turns refrigerator on. Let me know, Sea Breeze
May 19, 2009 | Whirlpool 25.2 cu. ft. Side-by-Side...
No power to control unit in fridge
Turns out we had a bad control board. One of the coponets was blown and it had to be replaced. $400.00 and its good as new.
Dec 16, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool side by side fridge freezer s20-d rbb32 a/g
Either there is a loose connection at that board or in the plug where the wiring goes into the door (should be at top or bottom door hinge). If all connections are tight then replace the board. Not sure how old this unit is but it does come with a one yr warranty from date of purchase.
Oct 06, 2007 | Refrigerators
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
151 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
