Question about Sony STR-DE435 Receiver
Str de 435 I was watching a movie nothing was being moved when suddenly I heard the relay click the protector mode came on thank you
  • 10,594 Answers
Relay click and Protect display indicates that receiver got problem in output amplifier section and most probably output chips got defective. This kind of problem is not user level repair and local repair shop will help you to get it fixed.
Thanks.
Posted on Oct 15, 2010
I have a Sony receiver model Str - de 435 it constantly flash Protector and I tried everything to fix this any ideas
The protector indicator usually indicates that one of your amplifiers has shorted output transistors. This is not a user repairable problem and the amp will have to be taken into the shop for service.
Mar 21, 2015 | Sony Audio Players & Recorders
Receiver goes into protector mode
Nope, power supply it would not even power up.  The capacitors are fried
Jan 04, 2009 | Sony STR-DE635 Receiver
Sony STR-DE525 Protector mode
Download service manual of STR-DE525 here and fix your receiver.
Must download all 4 files at web site.
Need further help, let me know.
Sep 24, 2008 | Sony STR-DE525
Help
check/replace your speaker wires. If a wire came loose, it will go into "protect" mode and shut down, to protect from a short circuit.
Jun 16, 2008 | Sony STR-DE525
Looking fot tech help
The clicking might have been the speaker relay attempting to engage. Measure any DC on the output transistors. You should see (B+/-,0.0 and +/- 0/6V). Anything else and the protection circuit will kick in. Update this with the measurements and we'll go from there. Note that this unmit may have darlingtons in it in which case the +/- 0.6 will be +/- 1.1
Dan
Mar 27, 2008 | Sony STR-DE635 Receiver
Sony STR DB-930 Receiver jumping into protector mode
I went through the amp/receiver and used small star washers on all the grounding screws I could find including the one securing the transformer, cleaned dust off all circuit boards, checked output transistors and fuses, all OK.
Re Assembled unit and it worked OK.
I will buy a fan and fan it to avoid sourcing heatsinks for the previusly suggested IC's.
Thanks for the technical help, sure solved my problem.
Regards
Darryl.
Mar 07, 2008 | Sony STR-DB930 Receiver
STR-DE945 stuck in auto protect mode?. I'm pretty sure it is the output capacitors but I do not Know where they are located to change them.
First of all my STR-DE845 started having the protector problem about 6 months ago and I bought this receiver back in 2001. This is what I found wrong with mine. After searching online I found a service manual for the receiver, this came in handy when diagnosing the problem. The first obvious thing was discoloration of the board around the IC 501, 601, and 701 Op-amps. When looking at the receiver from the front these are the three vertical NEC ICs to the right of the main amplifiers. Even with no load these amps get very warm. Sony failed to add any heat sink to these ICs so eventually they can de-solder themselves, specifically the 701 IC which is the one closest to the back of the unit. With mine I was able to slightly push the 701 more vertical, since it was leaning, and I believe it has helped it make a better contact. The protector circuit will kick in if it senses the Op-amps are shorted or not making contact. The best solution is to add some copper heat sink to these ICs, they already have screw slots for a heat sink. If they ever fail you will have to get new op-amps and re-solder them to the board. Hope this helps.
Jan 17, 2008 | Sony STR-DE845 Receiver
Protector mode SONY STR D1011S am fm receiver
I've had this happen, it's when you have speaker wires crossed.....
Dec 27, 2007 | Sony STR-DE945 Receiver
Protector mode..
Cambiale los IC de audio que esten dañados.
Oct 13, 2007 | Sony STR-DE825 Receiver
Sony STR-DE435 Receiver Logo
238 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
