Question about Panasonic DMPBD45 BluRay Player
BD45 upgrade using CD - displays UPD NG, This should go to Finish within 10 minutes. If I turn the unit off will it corrupt the Firmware?
2 Suggested Answers
  • 5 Answers
SOURCE: got the error code upd
Were you upgrading it over the network from the player? If you had network problems you can also download it to your computer nd burn it to a CD. then insert the CD into your player. Here is the link to the download: http://www2.panasonic.com/consumer-electronics/support/Video/Blu-ray-Disc-Players/Drivers-Downloads/model.DMP-BD60K.D#ts
Posted on Sep 19, 2010
Philips dvp31111/58 doesnt work after upgrade
The firmware upgrade failed. Try making a new CD from a fresh download, using different CD-burning software if possible. and double-check your CD-writing procedure to make sure it conforms with the firmware download instructions. Try doing the firmware update again. If it won't run, the EEPROM chip in the player will have to be replaced with another one programmed for the player because the program in the existing chip is corrupted and crashes.
Dec 02, 2013 | Audio Players & Recorders
Lost all drivers
Try resetting the unit by holding the reset button for 10 seconds and after that turn it off..
Hope that helps........
Jul 20, 2008 | Pontus PAC7002 CD Player
Tip
How to fix a hanged/frozen/non responsive Pan Digital Novel E-Reader
If your Pan Digital Novel Reader... does not respond or hangs, it means the unit/device has frozen. This is a software/OS (operating system) problem.
Usually, resetting should do the fix. To reset, push the hole at the back of the unit with paperclip and the unit will reset. But if you have reset the unit by pushing the small hole at the back with paperclip (which means reset) and that seems not to solve the problem, then it means the operating system of the unit is corrupt. This is a software problem and to fix this problem, you need to install the firmware for your unit.
Firmware helps to remove the corrupt software and re-install a new one. Your unit will be as new once this is done.
Upgrade via PC
This option is for Windows PC only at this time.
With this method, you must connect your pandigital novel to a PC and then run a downloader program which automatically downloads the firmware to your device.
1. On your computer, go to www.pandigital.net/downloads.
2. Choose the "Upgrade with Your PC" option.
3. When asked to Save or Run, select Run.
4. Follow the prompts in the Upgrader window to download the firmware into your device.
5. After the download is complete, turn your device off.
6. Press the Volume + key plus slide the power key on simultaneously for 5 seconds, and then release both.
7. Your device is upgraded and restarts automatically.
8. In the Language setup screen, tap Save with English selected (other languages will be available in future firmware upgrades).
9. In the Date/Time screen, if necessary, tap in the Time Zone, Date, and Time fields to set the correct time for your location. IMPORTANT: In order to connect with your Barnes & Noble online account, the Date and Time must be set correctly according to your location.
10. Tap Save.
11. The HOME screen is displayed.
Re-Upgrade
If you have previously performed a firmware upgrade to your device using one of the above methods, we recommend that you move the existing upgrade file into a different folder before performing another upgrade, which allows you to revert back to the existing version if desired.
1. Connect the device to your computer.
2. In a Windows Explorer or Finder window, create a new folder titled Firmware, and then copy the existing upgrade file into the Firmware folder. (The upgrade file is named similar to SYY_MM_DDK_PD_INX7E_ENG_6410POP.)
3. Perform the new upgrade using one of the methods above.
Revert back to Previous Version
2. In a Windows Explorer or Finder window, delete the upgrade file from the root, and then copy the upgrade file from the Firmware folder back into the root of the device.
3. Turn your device off.
4. Press the Volume + key plus slide the power key on simultaneously for 5 seconds, and then release both.
5. Your device is upgraded again and restarts automatically.
6. Follow the prompts to re-set your language and date and time.
I hope you found the above helpful.
Regards.
on Sep 27, 2011 | Tablets & eReaders
Got the error code upd ng on my DMP-BD60.....tried to upgrade firmware
Sep 15, 2010 | Panasonic DMP-BD60K Blu-ray/DVD Player
I have tried downloading from the samsung website lastest firmware update, which is an iso file when extracted it saves it to disc as a xuf file and the blu ray wont read this what am i doing wrong??
Read the Upgrade Guide (PDF) for instructions on how to do this. It says to burn a CD. The ZIP file extracts to ISO type. The guide tells you what format it needs.
http://www.samsung.com/us/support/search/supportSearchModelResult.do?menu=SP00&searchWord=bdp1400&searchInputBox=bd-p1400&find_button=
READ the PDF file under Upgrade Guide. Make sure you designate the proper file type when burning CD. Check your burning software.
How to make a firmware update CD
Please follow the below procedures.
1 Download the new firmware file from www.samsung.com
2 If the firmware file is compressed (*.zip), the file should be uncompressed to CD image file
(*.iso).
3 Please burn the CD image file on a blank CD-R/RW disc
1) Recommended CD Burning Program is Nero Burning ROM.
2) Burning Options (in case of using Nero Burning ROM)
A. ‘Recorder’ menu ?? ‘Burn Image…’ ?? Select an uncompressed image file(*.iso)
B. Please check ‘Finalize CD (No further writhing possible!)’
C. Please refer to your own CD burning Program Manual if you want to use any other
CD burning program for burning ISO image file.
D. Make sure if the downloaded software is eligible for your BD-P1400.
E. The System Upgrade will not be executed if using the update CD made with NOT
following the upper procedures.
Warning
The following events may interrupt the upgrade process and MAY RESULT IN PERMANENT
DAMAGE TO THE UNIT WHILE UPGRADING.
1. Unplugging the power plug
2. Power outage
3. Dirt or scratches on the burned CD-R/RW disc
4. Closing or opening a disc tray during update processing
How to upgrade the BD-P1400
1. Press OPEN/CLOSE button to open the disc tray.
2. Insert the upgrade CD.
3. Press OPEN/CLOSE button to close the disc tray.
4. Please wait about 6 minutes while verifying.
Verifying Firmware Version.
5. When below message box comes up, please check the date of the Firmware version.
Do you want to update Firmware?
>Current Version : 070730.02_XAA
>New Version : 070903.01_XAA
Yes No
6. Press ‘Enter’ button to choose ‘Yes’ for upgrade and please remove the disc on the tray.
If you select ‘No’, BD-P1400 will be automatically powered off.
If you don’t see above message box, try another disc. Generally, this is caused by disc
quality or a disc creation problem.
7. Please wait for about 7 minutes.
Firmware Update.
Now, Processing…
Please, do not turn off the power.
8. When finished, the screen and the power will turn off automatically.
9. Turn on the unit again. The tray will close automatically. Below screen will show up. Please
select the language you want with a corresponding number button.
MENU LANGUAGE SELECTION
Press 1 for English
Pulsar 2 para Español
Touche 3 pour Français
Macrovision : BSS01
10. If you want to do System Upgrade through the network, please refer to ‘System Upgrade’
Article on the User’s Manual.
Aug 18, 2010 | Samsung BD-P1400 Blu-Ray Player
HP LJ4250dtn 49.5F11 Service Error
49.xxxx error occurs when the printer does not understand the Print Job Language. Following could be the reason:
  • Faulty Network Cable/Port
  • Corrupt Driver
  • Firmware of the printer and the Jetdirect Interface.
  • Corrupt file.
  • Corrupt Print job.
  • Less memory or corrupt memory DIMM
Hence to start with, please let me know when do you get the error. Is it when you powercycle the printer.
Please perform the following:
  • Upgrade the firmware of the printer and the jetdirect card.
  • Change the driver and install the UPD drivers.
Let me know the next update...
- Nikhil
Aug 07, 2008 | HP LaserJet 4250dtn Printer
Denon s52 not working after firmware upgrade
ok, mine its been fixed, main board replaced because of corrupt software. But still unable to update.
The unit saids that there is an update avaliable, you try to update your unit and it seats forever trying to download DSP firmware 1/4... it does not go any further.
DENON... we pay a lot of money for this unit we deserve SUPORT... the manual is **** the web is even worst.
AVOID THIS DENON S52, it is not finish and it is been abandon by Denon
Apr 06, 2008 | Audio Players & Recorders
HDD Corrupt
I have the XS35 and the HDD drive is curropt. Can I do the following?
1. Download the Toshiba firmware update:
http://www.tacp.toshiba.com/customersupport/model_firmware.asp?model=rd-xs34
2. Burn the ISO to a CD-R disc. ImgBurn is an excellent free burner for this.
http://www.imgburn.com/
3. Insert the CD in your unit. It will auto-install the firmware. Follow onscreen instructions. Takes about 10 minutes total.
After the update, my existing HDD shows are playable again, and I can record and playback from the HDD. I bet it would be a good idea to periodically backup your shows on DVDs, and regularly reformat the HDD.
Mike
michaelz@resourceinternational.com
Oct 18, 2007 | Toshiba RD-XS34 DVD Player/HDD Recorder
Firmware upgrading - how long
please check the firmeware version and send me the screen shot of the software u r using for upgradition. pleasr rate this solution.
Sep 12, 2007 | Philips GoGear SA261 MP3 Player
LVW-5005X DVD Recorder setup tv tuner
You have the wrong firmware,or cd is corrupted.These Liteon recorders have had some issues with the timers.The 5005xa can actually be transformed into the Ilo R04.Look on internet the Wizard has free firmware for your unit, look for iLO R04 which is almost identical to your unit.
If the remote is broke they are easy to replace ,if the recorder is a 5005xa the remote is a clone to ones used in the iLO RO4,used ones can be bought on Ebay for $10 to $20.If it is 5005XSA use the Liteon Rm 51 remote.The Gateway AR 230 recorder and some of the Akai remotes are clones to the Liteon5005XSA remotes.
Jul 10, 2007 | Lite On LVW-5005X DVD Recorder
Panasonic DMPBD45 BluRay Player Logo
207 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
