Question about Whirlpool Duet GHW9150P Front Load Washer
How I can change the washer from 110 V to 230 V.?
  • donnamolinar Oct 16, 2010
    what about the washer?
    President:
  • 1,554 Answers
The machine central control unit (CCU) is designed for 120VAC and the CCU cannot be converted to operate on 230VAC. But there are two possible ways you can use your machine on 230VAC. First is replacing the CCU with the CCU used for the export version of your machine where the standard voltage is 230VAC. Second and probably the quickest, cheapest, and more viable way is by using a step-down transformer with rating that can safely power up the machine.
Posted on Oct 15, 2010
  • Jahn27
    Jahn27 Oct 16, 2010
    Please explicitly indicate what is your concern.
Model glgt1031fs1 how do you change the washer belt
Good Morning Friend,
I understand you want to know how to change the washer belt on your Frigidaire Affinity washer, model# GLGT1031FS1. Typically, this is not a do it yourself repair, as there are no step by step instruction manuals. I suggest contacting your local authorized technician for further assistance. They have been trained on your appliance and should be able to change the washer belt with ease. Hope this is helpful.
-Best Regards-
WP
Jul 09, 2014 | Frigidaire Washing Machines
Is there an issue with acura TL aluminum oil plug washer problem
no more than most cars...just they sometimes need replaced, like any other car after repeated oil changes, the washer wears out and needs replaced
Dec 03, 2012 | Cars & Trucks
"Control Locked" lamp is lit on the washer. Tried
Press and hold the end of cycle button for 15 seconds this should clear it.
Control locked
Nov 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How to change oil in a pressure washer
From the manual CleanShot 2050 Briggs and Stratton
Change Pump Oil
1. Drain engine oil and fuel from pressure washer
2. Use an 8 mm allen wrench to remove black pump oil cap between high pressure outlet and garden hose inlet.
3. Tiltl pressure washer to drain oil into an approved container until it drips slowly from pump.
4.Tilt pressure washer in opposite direction and empty premeasured pump oil bottle into same opening (a small funnel may be helpful) [THIS IS WHAT THE MANUAL SAYS-NOT CLEARLY WRITTEN IN MY OPINION OR WRITTEN BY SOMEONE FOR WHOM ENGLISH IS A SECOND LANGUAGE]
5. Install black pump oil cap and tighten firmly.
6. Set pressure washer in upright position. Add fuel and engine oil.
From the engine manual use synthetic 5w-30, 10w-30 from -20 degrees F to temperature of 100 degrees F.
Change oil after 5 hours of operation initially. Before tipping to drain oil, remove fuel from fuel tank by running until tank is empty. Remove oil cap and dipstick and tip engine. Keep spark plug side up. Or remove drain plug from the bottom of pressure washer with a ratchet and square extension and drain oil from bottom. (fuel does not have to be removed)
May 21, 2009 | Briggs & Stratton Pressure Washer...
Water hose leaks at the washer connection
Did you change the rubber washers in the hose? or did you use the old ones there should be a rubber washer inside the front of the hose.
Jan 05, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Neptune front load washer
if i remember correctly usa is 60 cycles and european is 50 ..might be wrong but don't think it's possible without a lot of changes ..best get an adaptor if available..this should plug into foreign outlet and then plug washer into it
Jun 02, 2008 | Maytag Neptune MAH5500B Front Load Washer
How hard is it to change the hose connetors on the washer
The washer valve assy. was damaged. The only solution is to replace the valve assy. period. No other way around it... sorry.
Mar 17, 2008 | Kenmore 24902 Top Load Washer
Changing a belt
the belt is under the washer. you may be able to reach it if you do not have a cover on the bottom of the washer... if you do have a cover on the bottom than you will need to pull the washer out. and take the back panel of the washer off. from there you will be able to see under the washer. you will be able to see the belt. just release the tensinor and replace the belt....
Oct 20, 2007 | Amana DLW330RA Top Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
21 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
