Question about Vacuums
Brewing, on RED button, goes short time then stops, and does NOT dispense. Water never flows into cup in any amount >? ?
  • hgekdeahl Oct 16, 2010
    To: angelo_mic - The item I questioned the operation on is -
    KEURIG HOUSEHOLD COFFEE MAKER
    Model B31
    Keurig is related to Green Mountain Coffee Roster company.
    I received no help from www.leurig.com
    Item is one week "old" to me and worked fine for making
    first 5 cups of coffee !
    Thanks
    Harry G Ekdahl
    717-334-4058
    hgekdahl@gmail.com
  • 712 Answers
Which is the company and the model # ?
Posted on Oct 17, 2010
    Genius:
  • 1,035 Answers
Hi. May i ask what is the device that you are inquiring? May we have the brand and model name of this device?
Posted on Oct 15, 2010
How do I get Bissell Proheat 2X to work. Not dispensing water.
Did you clean the filter on the water tank. It's generally a red screen type device. Additionally, there is a filter under the Flow Indicator, unscrew the cap, lift out the propeller, lift the filter screen and clean it. Reassemble in reverse order. If you occassionally run one and half cups of white vinager through the machine it will clean out the calc buildup. Additionally, the filters should be cleaned after each use.
Feb 07, 2016 | Bissell Brushroll Proheat 2X 8920 9200...
My brew station leaks water all over the counter top before it is brewed.
Mine Too! So frustrating. I have to take out the coffee filter, then remove the piece that it sets in. Make sure and clean the spring and the hole in the bottom. This seems to cure the problem until the next time. It seems to get plugged up quickly. I have learned to rinse it out every time I make coffee.
Feb 12, 2015 | Hamilton Beach Brew Station 12 Cup 48465
My Bissell ProHeat 2X CleanShot Upright Deep Cleaner, 9500; flow gauge will not spin and the machine is not dispensing solution with both the solution and water tank full. I have cleaned all inlets where...
No what it means are the tubes that carry the solutions are plugged and most likely full of old detergent that hardened. You will need to clean all the plastic tubing out for the dispensers. When your done using the machine always run clean water only through the dispenser and tube to flush out the detergents.
Jun 10, 2011 | Bissell 9500 ProHeat 2X CleanShot Upright...
I have a coffee maker that makes 36 cups of coffee. How many cups of ground coffee should I use to brew 36 cups?
I would ordinarily use half the amount of scoops of coffee as the amount of cups the coffee maker makes. A scoop being a Tablespoon of ground coffee. Less if you want it weak and one or two more if you want it very strong.
Apr 09, 2011 | Vacuums
The red light on my coffee pot is on and will not go off. I have run cleaner thru the regular cycle now what? Its a 12 cup programmable Mr. Coffee.
I know this sounds like a pain but it takes a while toget that silly light to stop. Decalcifying your MR. COFFEE® Coffeemaker Minerals(calcium/limestone) found in water will leave deposits in your coffeemaker andaffect its performance. It's recommended that you regularly remove these depositsusing MR. COFFEE® Cleaner or vinegar. MR. COFFEE® Cleaner is available at manyretail stores or by calling the MR. COFFEE® Consumer Service Department at 1-800-MR COFFEE(1-800-672-6333). 1. Follow packageinstructions to prepare one batch of MR. COFFEE® Cleaner. Pour the mixture into the water reservoir. Before decalcifying,remove the water filtration disk from the machine. NOTE: 4 cups or 20 fl. oz. of undiluted, white householdvinegar may be used as a substitute for the cleaner. 2. Place an emptyMR. COFFEE® 10-12 cup basket-style paper filter or MR. COFFEE® permanent filter into the filter basketand slide the brew basket in place. 3. Place theempty decanter back in the unit. 4. Press theCLEAN button until the CLEAN indicator light turns on (Figure 9). For your convenience the cleaning cycle isautomatic. The entire cycle will take 45-60 minutes to complete. During thecleaning your coffeemaker will: a. Slow brewapprox. 3 cups of cleaning solution. b. Pause for 30minutes (the CLEAN light will remain on to alert you that the process is active). c. After 30minutes, your coffeemaker will brew the remainder of the cleaning solution. d. When complete,the CLEAN light will turn off and your coffeemaker will turn off. 5. Discard the cleaning solution and rinse the decanterthoroughly with clean water. 6. Fill the water reservoir with clean, fresh water. 7. Place the empty decanter back on the coffeemaker. 8. Remove and discard the paper filter usedduring the cleaning cycle. If a Mr. Coffee® permanent filter was used during cleaning, remove it andrinse it thoroughly before replacing it in the filter basket. 9. Begin brewingand allow the full brew cycle to complete. 10. Repeat steps 5 through 9 one more time.
Mar 31, 2011 | Vacuums
Keurig model B40 How do I empty the resevoir , I can empty the cold watet tank. We are moving so need to completely empty all water.
The water reservoir lifts out. There are two tabs on the side which lock it in place. You may have to pres on them to remove it. If you are wanting to completely empty the entire machine, I have found an instruction manual and have instructions for purging: Fill reservoir with clean water and replace on machine with lid on it. Raise and lower handle without K cup inserted. Wait for the red light next to "heating goes off.
The blue lights on the control center will begin flashing. Put a cup on the drip tray and press "Brew"
When finished, repeat brew procedure 2 or 3 times and inner tank should be empty.
Hope this helps, if it does, please place a vote for me.
Good luck with your move,
Handie Andie
Mar 28, 2011 | Vacuums
I DON'T HAVE INSTRUCTIONS FOR A TM4 MR. COFFEE ICE TEA MAKER I BOUGHT AT A THRIFT STORE TODAY. I DO NOT KNOW HOW IT WORKS. I PRESS THE BUTTON AFTER ADDING WATER TO THE WATER LINE BUT IT CLICKS OFF...
I just got the exact IcedTea maker that you have (model TM4) from Mr. Coffee. I think that we were both trying to make it work the same way, which is wrong. The plastic pitcher goes on the bottom, while the part that plugs in with the button&indicator light goes on the top. Put water in the pitcher to the indicated water line and then pour it into the part with the metal basket. I didn't have any directional sheet either so I didn't know that the water goes in there. I thought the water would be gently warmed while in the plastic pitcher. After pouring water into the heating part, fill the pitcher with ice to indicated level (about 2 ice cube trays). Place the heating part with the button&indicator light on top of the plastic pitcher and cover it with the white lid. Push the button and it will heat the water and dispense the brewed tea into the pitcher thru a valve. The indicator light will go off when the brewing process is done. The entire manual can be downloaded from going to: http://www.mrcoffee.com/manuals/MrCoffee/tm4.pdf I hope this helps you if you still have the item. I bought mine to give my daughter while in college. I really like that it is so space saving compared to many that I am finding in stores today. Good luck and happy brewing!!! Susan
Mar 05, 2011 | Vacuums
I have a Hamilton Beach 6 cup brew station and it has stopped taking the water from the tank and making any coffee. It just sits in the tank making noise like it is working but nothing happens. Thanks...
unplug it,empty contents
put 2 cups white vinegar in tank , plug in and start brew cycle.
discard vinegar and run 2 tankfuls of water through to remove vinegar taste
Jan 08, 2011 | Vacuums
Poor flow takes two cycles to brew one cup. Heater working etc. Something stuck inside inner tube? Sucking air somewhere? can it be dis assembled?
This problem is usually caused by calcium carbonate deposits from hard water collecting in the thermal pump mechanism. The fix is to make a 1/2 pot mixture of white vinegar and cold water (about 50:50) and run through several times. Let cool off each time, and use a clean filter to catch the deposits that are removed. Finally, run several pots of cold water to wash out the vinegar taste. Hope this helps!
Jun 25, 2010 | Vacuums
Water is not dispensing to clean carpet. Water
the problem is the heater is cloged you can drill it out to clean it
Dec 10, 2009 | Bissell 1699 ProHeat Clear View Upright...
Vacuums Logo
23 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
