Question about Frigidaire Gallery 30" Self-Cleaning Freestanding Gas Convection Range - White
How do I change the light bulb in a frigidaire gallery oven
4 Suggested Answers
  • 150 Answers
SOURCE: frigdaire gallery stove
lock mechanism is acting up. happens sometimes. you can get to it from the back and get the thing open to use until you get the part
Posted on Apr 22, 2008
  • 11 Answers
SOURCE: Frigidaire Gallery Professional Series Oven Won't Turn On
Suspect a bad oven element. Worse case is a bad oven relay on the clock control board.
Posted on Sep 20, 2009
SOURCE: Frigidaire Gallery Series ES340 ceramic-top range:
The manual is missing a step. After pressing Clean or Quick clean you need to press the ^ button once.
Posted on Sep 05, 2010
How to change a light bulb on my Frigidaire oven model RT 70 light bulb in the signal light area in the surface unit switch?
Hello Heidi, thanks you for your inquiry!
From the information you have provided you need to change the light bulb inside of your Frigidaire Imperial Electric Range. This appears to be an older model and I was unable to locate any direct information on how to change a bulb. Since your appliance is older than ten years old the manufacturer may not have any information for it. You may need to perform a generic search online for further help with the bulbs or speak with a local technician. I hope this information is helpful. -Matt
Jun 02, 2015 | Frigidaire Kitchen Ranges
FGMV205K cover removal
Good Afternoon Friend,
I understand that you want to know how to remove the cover on your Frigidaire microwave, model# FGMV205K. There are two different covers that you are able to remove for access to two different light bulbs.
If you are trying to change the Microwave Oven Light for inside your microwave:
    1)To replace light bulb, first disconnect power to your microwave oven at the circuit breaker panel or by unplugging it.
    2)Remove the louver by removing the three Hood Louver Screws.
    3)Push in the upper tabs and pull the louver away from your appliance.
    4)Remove the light bulb and replace with a new 20 watt light bulb. DO NOT USE BULB LARGER THAN 20 WATTS.
    5)Close the Oven Light Cover by carefully pushing into place. Push the louver back into place (engaging both the bottom and top tabs) and change to hood Louver Screws.
    If you are trying to change the light bulbs underneath your Microwave:
      1)To replace light bulbs, first disconnect power to your microwave oven at the circuit breaker panel or by unplugging it.
      2)To open Light Cover, remove the screw on the light cover.
      3)Replace the light bulbs with new 20 watt light bulbs. DO NOT USE BULBS LARGER THAN 20 WATTS.
      4)Close the Light Cover and secure with screw removed at step 2.
      If further troubleshooting is needed, I ask that you please let me know the error codes displayed on your appliance. Hope this is helpful.
      -Best Regards-
      WP
Jun 07, 2014 | Frigidaire Gallery FGMV205K 2.0 cu. ft....
I need to change the interior light bulb in my Frigidaire over the counter microwave. The model # is FMV156DCA.
Good Morning Evelyn, thank you for allowing me to assist you!
Here are some simple troubleshooting tips to help replace the light bulb on your Frigidaire microwave, FMV156DCA.
    ·First, disconnect power to your microwave. This can be done by either unplugging it or at the circuit breaker panel.
    ·To release cover, remove the screw on the light cover (light cover may become very hot, do not touch glass when light is on).
    ·Remove old light bulb and replace only with equivalent watt bulb available from parts distributor or the manufacturer directly. Bulbs are also available at most hardware stores or lighting centers. Bulbs larger than 30 watts are NOT recommended.
    ·Close light cover and secure with screw removed in step 2.
    I hope this information proves to be helpful. If you have further questions, please do not hesitate to reconnect.
Nov 25, 2013 | Frigidaire FMV156DC Microwave Oven
How to change a bulb in fgm0205kf
part # 5304440779
you will need to take the cover off the unit for that.
the bulb is on the right side mount to a black plastic.
FYI your Model # is FGMO205KF
Good Luck
Mar 14, 2013 | Frigidaire FGM0205KF Gallery 2.0 cu. ft....
Oven light won't come on
turn light switch off !! then take bulb out, then look inside socket u will see center little pin, with small flat head screwdriver gently pries out so that when new bulb goes in u r sure to make connection.
Oct 11, 2012 | Frigidaire Gallery 30" Self-Cleaning...
Oven light is not working
It is most likely to be the bulb which is faulty.
You should be able to replace it quite easily, nornally the bulb cover will turn anticlockwise and reveal the bulb which you then replace , remember to use a high temperature replacement.
Jan 04, 2010 | Frigidaire FGB24S5A Gas Single Oven
Cannot clear PF light flashing on frigidaire dishwasher
Frigidaire dishwasher will not work at all it has PF blinking
May 27, 2009 | Frigidaire 30 in. Electric Gallery Series...
Frigidaire Gallery Professional Series - No clock/oven functions
i have an old model of the fridgedare gallery professional series stove. After self cleaning, the ignition sparks for the burners will not come off, they keep clicking and only stops when i pull out the plug. can you help me with this situation?
Nov 01, 2008 | Frigidaire FGB24S5A Gas Single Oven
Frigdaire gallery stove
Dec 18, 2007 | Frigidaire Gallery GLEFM397DS Electric...
Frigidaire Gallery 30" Self-Cleaning Freestanding Gas Convection Range - White Logo
275 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
