My computer is not starting and the screen is black. There is no option to click. And also the keyboard is not responding to the monitor. How can I fix it?
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 50 Answers
To solve the issue try the below step,
1. This is possibly due to virus,
restart the machine in safe mode with networking,
kindly install an latest anti virus (Avast 4.8 or 5.0) update with latest definitions and schedule boot time scan from the configuration tab
2. reboot the machine for initiating the boot scan.
3 if the issue persists, do update the graphics driver by navigating through RC my computer-> manage ->device manger and vaga properties and update.
Posted on Oct 15, 2010
    Genius:
  • 1,325 Answers
What is your model number and S/N of this compouter
i assume its a desktop, not notebook
Needtogetaroundcomputerkey
You can adjust turn on or adjust settings for these features on the Use the computer without the mouse or keyboard page in the Ease of Access Center. Open the Use the computer without a mouse or keyboard page by clicking the Start button , clicking Control Panel, clicking Ease of Access, clicking Ease of Access Center, and then clicking Use the computer without a mouse or keyboard.
Select the options that you want to use:
Use On-Screen Keyboard. This option sets On-Screen Keyboard to run when you log on to Windows. On-Screen Keyboard displays a visual keyboard with all the standard keys. You can select keys using the mouse or another pointing device, or you can use keys on the standard keyboard. For more information about using On-Screen Keyboard, see Type without using the keyboard (On-Screen Keyboard).
Use Speech Recognition. The option allows you to control the computer with your voice. With a microphone, you can speak commands that the computer will understand and respond to, as well as dictate text.
May 11, 2015 | Computers & Internet
I have a compaq and it starts up but screen stays black
A blacked-out screen doesn't necessarily indicate a broken monitor.
If the computer has run out of charge or is in hibernation or sleep mode,
if the screen is too dark, or if the display cable has come disconnected from the motherboard, the screen may appear black or fail to turn on. To fix a blacked-out laptop screen, troubleshoot the screen settings, check the LCD connector and see if the computer is awake and receiving power.
Touch the touchpad or move the external mouse to see if the computer is asleep or hibernating. If the computer fails to respond, press "Enter" on the keyboard. Press the power button if the screen remains black.
Confirm that the power indicator light, found at the front of the computer or above the keyboard, is glowing solid green or blue. Confirm that the power adapter is plugged into the computer and into a wall outlet. Confirm that battery indicator light is glowing solid green or blue. Hold down the "Fn" key. Press the up-arrow to see if the screen brightness increases.
Some computers also use the "F6" or "F7" keys to increase screen brightness.
Hold down the power button for 10 seconds to turn off the laptop.
Remove the AC adapter from the computer, close the screen, and then turn the PC over.
Slide the battery latch to eject the battery. Pull the battery out of its compartment. Turn the computer back over, open the lid, and insert the edge of a flathead screwdriver or other flat, solid object beneath the bezel above the keyboard. Wedge the edge of the keyboard bezel off of the top cover.
Work your way along the edge of the keyboard bezel to loosen it.
Pull the bezel off the laptop.
Trace the cable coming from the laptop screen to the connector found beneath the bezel. Reconnect the display cable to the motherboard if the cable has come loose from the connector. Line up the tabs on the bezel with the slots along the top of the keyboard. Insert the right edge of the bezel into the gap above the keyboard, and then push the bezel back in place. Turn the computer back on. If the laptop screen is still blacked out, connect an external monitor to the video port on the side of the PC to confirm that the video card isn't defective. If the external monitor works, the LCD screen could be broken. If the monitor doesn't work, the motherboard or video card might need to be replaced.
Feb 10, 2013 | Computers & Internet
How to flash bios
Download the appropriate BIOS update and flashing utility for your motherboard from the motherboard manufacturer's website. Most manufacturer websites keep the files under a section labeled "Support." The files will likely come in a ZIP archive, so you will need to extract the files to your desktop. Copy the flashing utility and BIOS file to the DOS boot floppy. If your computer does not have a built-in floppy drive, you will need to connect a USB-type floppy drive first by plugging it into a free USB port. Rename the new BIOS image "newbios.bin" to make remembering it easy. Reboot the computer with the boot floppy in the floppy drive. Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu
Please select an option: Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice. Select safe mode with command prompt When the boot process is done, you will be at the "A:\" prompt. At the "A:\" prompt, run the flashing utility. For example, if the flashing utility is named "awdflash.exe," then you would type in "awdflash" and press "Enter." The flashing utility will likely have a simple graphic menu system with a list of the commands and what they do. Save an image of the existing BIOS to a file called "oldbios.bin." Once the backup is complete, point the flashing utility at the new BIOS image and start the update process. Remove the DOS floppy and reboot the computer when the update is complete.
b>
Jan 18, 2013 | Dell Inspiron Computers & Internet
Xps M1530 error code 2000-0322
If you want to know what this is the error code is related to
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured or click start type in event viewer press ENTER you might be able work your way through the problem
Trace the cable coming from the laptop screen to the connector found beneath the bezel. Reconnect the display cable to the motherboard if the cable has come loose from the connector. Line up the tabs on the bezel with the slots along the top of the keyboard. Insert the right edge of the bezel into the gap above the keyboard, and then push the bezel back in place. Turn the computer back on. If the laptop screen is still blacked out, connect an external monitor to the video port on the side of the PC to confirm that the video card isn't defective. If the external monitor works, the LCD screen could be broken. If the monitor doesn't work, the motherboard or video card might need to be replaced. Hope this helps
Dec 09, 2012 | Dell XPS M1530 Laptop
Acer laptop switched on light up on switch but no screen display
A blacked-out screen doesn't necessarily indicate a broken monitor. If the computer has run out of charge or is in hibernation or sleep mode,
Press the power button if the screen remains black. Confirm that the power indicator light, found at the front of the computer or above the keyboard, is glowing solid green or blue.
Hold down the "Fn" key. Press the up-arrow to see if the screen brightness increases. Some computers also use the "F6" or "F7" keys to increase screen brightness.
Hold down the power button for 10 seconds to turn off the laptop. Remove the AC adapter from the computer, close the screen, and then turn the PC over.
Wedge the edge of the keyboard bezel off of the top cover. Work your way along the edge of the keyboard bezel to loosen it. Pull the bezel off the laptop.
hope this helps
Hope this helps
Nov 24, 2012 | MSI P45 Neo3-FR (MS-7514-010) Motherboard
How can i unlock my keyboard
Recognize that you have a locked keyboard.
If your PC computer is not responding to keystrokes or is responding very slowly, you could have a locked keyboard.
Use your mouse to move the pointer over the "Start" button.
Use the left-click button to bring up the "Start" pop-up menu.
Position the pointer over "Settings" and use the left-click button to select. T
hen select "Control Panel." On some versions of PC operating systems, you can select "Control Panel" directly from the "Start" menu.
Select "Accessibility Options" to bring up another menu, then select "Keyboard."
You'll see three options that have check boxes.
Make sure each check box does not have a check mark in it.
The three options are "StickeyKeys," "FilterKeys" and "ToggleKeys."
Note that these options can become checked if the keyboard operator has repeatedly depressed the "Shift" key in rapid succession--or if the "Shift" key is held down for longer than eight seconds.
If the keyboard is still not responding, the problem could be that the computer has lost communication with the keyboard.
Turn off the computer.
Disconnect the power supply.
Remove and then reconnect the keyboard cable, then reconnect the power supply.
Turn the computer on.
This will reboot the computer, allowing it to recognize the keyboard.
hope this helps
Oct 03, 2012 | eMachines Computers & Internet
Screen goes black when turned down and it does
try removing suspend on lid close .. refer to your laptop manual .. try this too disable herbernation also ..if nothing works check if you have latest graphic driver !! it might be a problem with ACPI .. but my two solutions should work !!!
Mar 10, 2010 | ASUS W7S-3P100E T7500 PC Desktop
When i plug in the switch "on" my HP COmpaq LCD 15" monitor can not respond. black screen and the power putton light GREEN show but not display. after 1 minute the green light off. when i soon "on" monitor...
ysm7862001, Monitor has possible problem lighting-up cold cahtode fluorescent lamps that provide lcd panel with white light from rear(reverse side) of the panel. No white light= black or blank n black screen. Read my fixya profile for all options you might have open to you.
12fixlouie
Mar 01, 2010 | HP Compaq 1501 15" LCD Monitor
'input not supported'
just had this problem and just fixed it. all you need to do is unplug it directly from the outlet then turn on it worked for us so hiopefully it will work for ya'll
Sep 07, 2008 | Computers & Internet
SCREEN MESSAGE - MODE NOT SUPPORTED
You have set a resolution that is too high or incompatible with your monitor. I assume you are using Windows. Turn the computer on and immediately keep pressing F8 on the keyboard until the 'Windows Advanced Options Menu' appears. Use the Up and Down keys to select 'Enable VGA Mode' Press enter and your screen will work again when windows starts. Now go to the display properties and click 'Advanced' then click the 'Monitor' tab and tick 'Hide modes that this monitor cannot display' OK everthing and now you should be able to adjust the resolution without getting a blank screen again! Good luck and come back to comment soon. Regards
Sep 26, 2007 | Daewoo L700C 17" Flat Panel LCD Monitor
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
