Question about Craftsman Garden
My Craftsman Series 550 Lawnmower was working fine and I decided to check and clean the airfilter and carburetor. When I tried to restart the pull cord is stuck and won't allow me to pull it. I have changed the oil, checked the spark plug wires and even check to make sure something wasn't blocking the blade. I can manually move the blade. Any suggestions? I took top cover off and didn't see anything visually wrong.
    Loyalty:
    Visited the website for 30 consecutive days.
  • Craftsman Master
  • 1,101 Answers
I suggest you pull the housing off for the pull cord and see if it pulling fine if it does see if the brake is of on the motor i would bet the brake is not releasing
Posted on Oct 31, 2017
4 Suggested Answers
garing
  • 998 Answers
SOURCE: My 550 series Bolens lawnmower won't start. When
keep pushing the prime button
Posted on Aug 08, 2009
rycgl
  • 1545 Answers
SOURCE: repalce blade on 700 series craftsman lawnmower
Tilt the mower back in a direction that brings the front (spark plug end) of the engine up and the back of the engine down if possible. This keeps the oil from going places it doesn't need too.
Under the deck of the mower you will find the blade bolt It will be in the center if the blade and should be a hex-head bolt Around the 1/2 " size. You will need to either jam the blade where it can't turn the motor while you attempt to loosen the blade bolt or enlist a helper wearing gloves maybe to hold the dull side of the blade still (if you can't hold it yourself). For easier removal of the blade bolt the next time around, coat the threads with Permatex Anti-Seize Dry Graphite Compound. You won't have it stuck or rusted next time.
Posted on Jul 11, 2010
Knucklebstr
  • 222 Answers
SOURCE: poulan pro w/ 550 series
Your carburetor needs a good cleaning or a rebuild kit, depending on its condition once opened up. There are tiny holes (jets) in there that easily get clogged or gummed up with today's crappy gas (ethanol). This is the problem with 90 percent of the machines I work on or fix. If you don't know carbs, then I recommend you take it to a professional and have the carb done (30 to 40 USD, probably), but it should run like new, once this is properly done. If you are a "do it yourselfer". then you can find plenty of videos on youtube to help you get started. Just pay close attention to what goes where when you take the linkage apart. Trust me, do not leave it to memory; take photos. Best of luck to you.
Posted on Jul 02, 2011
Testimonial: "Much appreciated. Giving me an idea of what to look for as well as where I can go for further information is extremely helpful. Thanks. -Jake Towley"
Craftsman 22" self propelled platinum series lawnmower died while pushing it. wont restart. ????
A good place to start is taking the air filter off. Then try stArtingvit again. Often a dirty air filter will not allow a mower to stay running. If that does not help. Remove the cover under the carburetor looking for dirt in the cover. Also well the cover is off remover the small pin that holds the float in place. Pull the neddle valve out cleaning it and the other parts with a carburetor cleaner then reassemble
Jul 21, 2014 | Briggs & Stratton Garden
I have a craftsman Briggs & Stratton 550 Silver Series mower that won't idle after being primed. I have tried every solution found online and it still won't idle. Any thoughts?
what is every solution found? does it run at full throttle? if I remember right the 500 series is all or nothing and if it's nothing then I'd say to replace the carburetor. it is running on the prime and once that s gone it dies as the carburetor can't supply fuel enough to keep it running. you can try cleaning it but for about 30 or 40 bucks it's just as easy to replace.
Sep 29, 2013 | Garden
I have a briggs and stratton 550 motor on my bolans lawnmower, i changed the spark plug oil and air filter but its still running rough. what else can i check
Check to see if you have water in the fuel tank, then clean the tank. Clean the carburetor if it has a bowl. If it has the carburetor on the tank then you should replace the diaphram as when they wear out they can cause rough idling.
Sep 16, 2011 | Garden
Lawnmower working find put choke on engine ran rough and stalled and would not restart. I tried every trouble shooting method which includes air filter, spark plug , fuel, electric connections, fuel filter...
sounds as though the carburetor is not working, pour some gas into the carburetor and see if it runs, if it runs and quits then the fuel is not getting to the carburetor or the carburetor needs to be cleaned and rebuilt. Hope this helps Tim
Jun 12, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I have a craftsman briggs and stratton 550 series silver edition lawn mower and when i turn my lawn mower on the engine revs and then lets of over and over again like it is about to die but dont... what...
i have a brand new craftsman briggs &stratton silver engine series 5.50 158cc it will start but will not run unless i keep pushing the prime button to give it gas once i stop so does the engine
Oct 22, 2010 | Garden
When I try to start my Craftsman Model # 917.388861 lawnmower, it will start and then dies right away, then Iit would start unless I prime it. Before it started doing this, the lawnmower was running very...
Sounds like you will need to clean your carburetor.
Be sure to use compressed air to blow out all the fuel and air passages.
Sometimes you can get by with priming the carburetor a few times, and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
If the mower/weedeater is over a couple years old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, You will first seat the jet screws and count the number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns they were in/out.
Please rate me,
Thanks
Good Luck,
I hope this helped
Aug 16, 2010 | Craftsman 675 Series 190cc 22" Briggs ...
Starts fine runs good for 1-2 minutes then dies. starts up with several pulls or choke. then dies again. changed the sparkplug no differance. cleaned the airfilter same result. george from texas
Check the fuel filter and muffler for plugging. Check the fuel tank vent for plugging. Check the fuel lines for damage or decay. Check all of the carburetor fasteners for tightness including the mounting hardware for the carburetor to the cylinder. The carburetor does not appear to be pulling new fuel into itself after running on the initial prime. If the above hints don't help, you may have to service the carburetor. Check the gaskets and heat insulator block behind the carburetor for any obstruction/damage of the impulse passage which allows the carburetor to pump fuel. Hope this helps!
Jun 17, 2010 | Stihl Chain Saw Handle Models 064 066...
Aug 08, 2009 | Garden
Why is my 4.0 crafrtsman lawnmower flooding gas into my airfilter
float is sticking in the carb. Pull carb clean holes with paper clip put back together.
Jul 19, 2009 | Craftsman Garden
Garden Logo
205 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dean Gruber
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
