Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
I have a PCG23MIMHFBB I purchased in the UK about 4 years ago. I need to replace the icemaker (part no WR30x10081). Is this the correct part and if I sourced the part in the USA would it be ok?
2 Suggested Answers
Bogie Boy
  • 46 Answers
SOURCE: water dispenser quit dispensing 2 days ago
Sounds like the micro switch has gone bad behind the dispenser cover. locate your handle or push button either you will remove the front cover to find the switch sometimes you remove inside the door behind the dispenser. but that sounds like the trouble your having. Maybe I've helped good luck. BB
Posted on Jan 21, 2010
Loud buzzing from freezer
icemaker wont work in fridge. the buzzing sound might be the water solenoid operating and waiting for water level sensor to be happy. solenoid will make a loud harsh buzz check water supply to back of freezer and see if there is a lever on icemaker you can lift up to turn off.
May 16, 2013 | Frigidaire Professional 27.8 Cu. Ft....
Can you get a replacement grey button that's at top of seat which needs to be pushed in to remove seat from base?? My one got broken...
Hi
No the recline / remove grey button is not an item that can be replaced. In the event of it becoming broken the seat unit needs to be replaced.
If you're in the UK and the product is under 2 years old, please contact your retailer with your proof of purchase and they can arrange for it to be sent to our engineers for inspection and as it cannot be repaired a replacement will be provided under warranty.
If you're in the UK and the product is over 2 years old or you no longer have proof of purchase a replacement Quinny Zapp Xtra seat unit can be purchased from your local Quinny retailer rrp 125GBP.
If you're outside the UK please visit www.quinny.com and select the country you're in, then use the "Contact Us" tab on the right side for your enquiry to be sent through to the customer care team in your country.
If you're in the UK you can order by contacting the customer care team on 01284 413 141 Mon-Thur 8.30-6.30 / Fri 8.30-4.30 (Excluding Bank Holidays)
If you're outside the UK please advise which country you're in and we can put you in touch with the correct distribution team to assist you.
Sep 11, 2012 | Quinny 2011 Zapp Xtra Stroller- Rebel Red
My dell studio can not charge.
Make sure the battery is well seated in the laptop. If that doesn't work, the battery may be going bad and you will need a replacement. I've had to replace my Dell's battery twice since I got it about 4 years ago.
Mar 18, 2011 | Dell Studio 17 Laptop
I have a bebecar vector 3 in 1 that i brought 4 and a half years ago. the break has broken and the tyres would need replacing. i was just wondering if we could get them fixed and how much roughly? thanks
The brake may just need lubricating, so try that first. Tyres are available by visiting your local retailer or by contacting Bebecar direct on 01692 408807 or email service@bebecar.co.uk
The cost of tyres will vary depending where you purchase them from. They can be between
Oct 14, 2010 | Baby Gear
Difference in waterline hookup between old and new icemakers
this is so often the case with some of the larger companeys. there are only two types of connections for these water lines. 1st is a compression fitting 1/4 inch 2nd is a push lock style also 1/4 inch. Both styles can be purchased at any large hardware store. they should be with pipe supplies. Hope this helps and good luck.
May 07, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Dishwasher purchased 8 years ago, $200 repair 4
For what you pay for dishwashers its normally better to replace them
Apr 24, 2009 | Maytag MDB7100AWB Dishwasher
Use US Panasonic TV in the UK?
hello, you will need the power step down transformer. i understand the voltage supply in uk are at 220v here it is 120v
they have an adapter for the plug and hopefully you can find the tranformer for it. then you should be able to use it ..
happy holidays and best of luck to you.
Dec 18, 2008 | Panasonic Viera TH-42PX80U Plasma TV
Icemaker quit working
Hello.
First of all you need make sure that your freezer is freezing enough. Sometimes everything will seem to be freezing ok, but it won’t be cold enough to make the icemaker work. The best way is to squeeze your ice cream, if you have any that is.
Then you need to make sure that the ice level sensing arm is in the down/on position.
If all of this checks out ok, then you need to make sure that nobody turned off the water supply that is sometimes located under the kitchen sink. Also make sure that the ice bucket is positioned properly so as to trigger the ice bucket sensing switch.
If all of this checks out ok, let me know and I can guide you through an icemaker diagnosis by forcing it into a harvest mode.
Nov 20, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Icemaker won't fill
HAVE YOU INCREASED THE TEMP SETTINGS AS THE PIPE MOSTLY FREEZERS WHEN IT IS 2 COLD IN THE FREEZER.ALSO IS THERE WATER COMING TO THE ICE MAKER IF NOT YOU NEED TO LOCATE AND CHECK THE WATER VALVE.LET ME KNOW IF YOU NEED MORE ASSISTANCE.GOODLUCK.MOHAMED
Aug 01, 2008 | Whirlpool ED2FHEXN Side by Side...
Kenmore side by side 253.54662400 makes hollow ice cubes - do not dump
yes i would replace the icemaker. it sounds like the heater and ejectors have lost their sync. could be caused by the internal drive motor.
Jun 29, 2008 | Kenmore 53642 / 53644 Side by Side...
Refrigerators Logo
89 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
