Question about AEG Lavamat 88840 Front Load Washer
AEG Lavamat error ef0 Dear technician, our washing machine keeps beep "ef0" and can't work, the door can be open to fetch the clothes, but the clothes are still wet with water, but there is no water inside the machine and all the waters leeks out to the floor. Many thanks!
  • 1462 Answers
SOURCE: AEG Lavamat w850 not finishing cycle! help!
check no kink in drain hose and if plumbed in unbder sink, check spigot into sink drain is not blocked. put drain hose lower down band check there is water coming out freely. if not, then suspect something trapped in hose from tub to pump
Posted on Mar 26, 2007
  • 236 Answers
SOURCE: AEG Lavamat 72640 Front Load Washer
are the holes that spray out the water partially blocked? if so the water will spray out at every angle filling all the tray slots. try popping out the soap tray and cleaning above it with a stiff washing up brush and then reducing the water pressure by turning the tap off a bit.
Posted on Jun 02, 2007
rizla
  • 1463 Answers
SOURCE: AEG Lavamat 1000
hi
dont know if this is the one you need AEG 1000 Washing Machine
you may need to scrool down to download the manual .
riz.
Posted on Mar 03, 2008
EngineerGR
  • 119 Answers
SOURCE: need the manual for Aeg oko lavamat 74630
Dear Biyo,
Please download the manual from here. (simply press left click)
http://www.manualshark.org/manualshark/files/5/pdf_10516.pdf
I have sent you an email as well.
Regards,
EngineerGR
Posted on Apr 09, 2008
  • 44 Answers
SOURCE: AEG 16820 Lavamat-turbo
Hi
this sounds like the fill vavle is fauty you can check this if you have a muiltmeter.
remove lid and unplug the green soliaod and check to see if open circuit.
if so replace and should be ok.
regards
Posted on Mar 21, 2009
ERROR SHOWS EF0, WHAT IS THIS
drain filter, overdosing of detergent or leaks water on the base.
Dado
Jul 28, 2014 | AEG Lavamat 12710 Front Load Washer /...
AEG Lavamat W1450 Electronic - after about 10 mins of programme machine is making beeping sound and stopping
this is an errorcode !
try to download a servicemanual,
then you can figure out the exact failure -
like : does not heat up etc. ....
May 05, 2012 | AEG Lavamat W1450 Front Load Washer
AEG Lavamat 76810 E70 7Beeps Does seem to still work but display shows E70 and 7beeps over and over. Many thanks gary
I Have AEG Lavamat 76810 E70 7 Beeps and Beeps never stops
The water was not hot
I took all the multi-plugs out and put them back in the whole machine ALL CONNECTORS
Now it works fine E70 is gone
Jul 14, 2011 | AEG Lavamat 16810 Front Load Washer/Dryer
I have a Kenmore 110.4751 It will periodically beep while washing clothes. I don't find any error codes visible. I don't find any explanation in the manuals for this condition.
1 Beep/E10--Error: Water doesn't enter Cause: Water supply problem, Check kinks and faucets
1 Beep/E10--Error: Water leaks Cause: Water connections loose,household drain clog,oversudsing. Correct problems.
1 Beep/E10--Error: Dispenser drawer is open Cause: Washer will not operate if drawer is open.
2 Beeps/E20--Error: Water dosen't drain. Cause: Drain is kinked or household clog. Correct.
3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart.
4 Beeps/E40--Error: Door is open. Cause: Washer will not operate if door is open. Close door.
5 Beeps/E50--Error: Motor is overheated. Cause: Wait 30 minutes to cool down. Restart.
7 Beeps/E70--Error: Cold water doesn't enter. Cause: Hoses crossed,faucet problem.
15 Beeps/EF0--Error: Oversudsing. Cause: Too much detergent,or improper detergent for machine.
15 Beeps/EF0--Error: Hot water doesn't enter. Cause: Hoses crossed,faucet problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 24, 2010 | Kenmore HE2 Plus Front Load Washer
AEG Lavamat 6250 - opening door?
Try spoon handle gently prise open
Nov 12, 2009 | Washing Machines
Kenmore elite washer cycle signal keeps going off an on turing cy
Jan 04, 2009 | Kenmore Washing Machines
Washing machine not starting
Jan 03, 2009 | Washing Machines
C2 error
aeg lavamar error c2
Dec 25, 2008 | Maytag NFW7200TW Front Load Washer
Operating instructions lavamat 538
type in ' AEG lavamat 538 ' into the top right hand address bar on your pc and you will find links that will give you all the instruction manuals you need... AEG is at the lower end of the list....
Good luck
sue
Aug 03, 2008 | Washing Machines
Does not spin when inserting 5.5kg clothes ,only when decreases weight
I'm not a technician, but I own a AEG Lavamat. As far as the owner manual says, this washing machine doesn't allow more than 5 kg.
Jan 12, 2007 | AEG Lavamat W1050 Front Load Washer
AEG Lavamat 88840 Front Load Washer Logo
226 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
