Question about Cell Phones
The phone switched to WLAN only ans indicates "not allowed to dial". When you try to change the mode it gets stuck in "unfinished". A number of solutions have said enter a code.You cannot enter a code because you cannot dial (to enter the code),ie I have no idea how to enter a code. Any help would be appreciated.
  • wcjordan Oct 15, 2010
    It is not a very satisfying solution to have to rely taking the phone to the repair shop and pay someone else to fix the problem, especially since it came on by itself. Is there any solution I can use myself, so that if it happens again I am not stuck with "take it to the repair shop"?
    The phone switched to "WLAN Only" on its own. It says "unfinished" when I try to change the mode. The SIM is fine (it works properly in other phones). I need a solution where I can work with the phone, I cannot afford to take it to the shop everytime something like this happens. Can you force the phone to reset to default settings somehow? It worked fine for 3 months.
  • Cell Phones Expert
  • 2,973 Answers
A sure case of corrupted firmware. Please visit the nearest Service center and get the firmware reinstalled. All your worries will disappear.
Posted on Oct 15, 2010
    Genius:
  • 1,416 Answers
The way to solve the phone problem now from your statement is to take the phone do to a very good phone technician around your local area to flash/unluck the phone to be able to make use of the phone again WITH a computer soft ware
However what am saying here is that the phone need to be reformat ,then you will be able to make use of the phone.
Thank you for using fixya.
I cannot dial out I Problem with the Cellular Phones I cannot dial out I get a message Not allowed to dial. Also in the upper left I see wlan on I go to network setup then Preferred mode select GSM...
Please try this and let me know if it works.
  1. Change to flightmode.
  2. Then power off the device.
  3. Restart it and change to normal mode.
Also do a factory reset. The default passcode is 1122.
Apr 14, 2011 | Cell Phones
Not allowed to dial china w9630
me suve pero se me resetea se nkeda en blanco mi 9630
Dec 12, 2009 | Cell Phones
M001 Phone when trying to make a call it says : NOT ALLOWED DIAL"
This is for another similar clone marked with the "vaio" name but it might be useful to someone out there. I found that by following solution one above (thanks Mrfixit) to step 6 as below and then following the second part of what I found at http://chinamobiles.org/archive/index.php/t-16088.html worked for me. I reproduce the steps below:
1. make sure to have 2 sims in phone(do not use 3g sims) 2. make sure wlan is disabled 3. enter engineer mode (type in *#3646633# 4.scroll up not down to number 10 RF test tool 5.choose gsm touch ok verify ok touch power scan 6.select band dcs 1800 press ok phone will go to test looking for DES(frequencies) wait until phone crashes or seems inactive
BUT THEN
Connect your mobile via USB cable to a PC, DO NOT CONFIRM any connection mode at your mobile, just and ONLY connect the cable!!!
11. Press the Menu button (second from the left, the one with the seven small dots on it) until you are at the main menu with the 12 icons on the display.
12. Go to "Settings" --> "Network Setup" --> "SIM1 network setup"
13. Go to "Preferred mode" and choose "GSM preferred" or "GSM only"
14. The mobile will switch to your selection, but the message that it will stays on display. Do not press anything else, just wait for about 10 - 15 seconds.
15. Disconnect the USB cable from the phone, it will show you that it has switched to your selection.
16. Get back to main menu, switch off and restart the mobile --> DONE
Sep 22, 2009 | Cell Phones
I am unable to change connection Network Setup > SIM1 network setup > Preferred mode I am stuck in "WLAN only". When I select "GSM" or "GSM preferred". The phone states "mode switching" and then...
Guys I had the same problem with the k599 Sciphone and none of the solutions found on the internet helped me. New chinese models tend to restart after testing is over and this results in turning the wifi application on. So I spent many hours on thinking how to bypass this function and this morning I woke up with an idea that really worked!! The steps are quite similar with the ones followed to debug older models:
put 2 chips on cell
Disable WLAN.
1-enter in factory mode *#3646633#
2-go to RF Test Tool
3-choose GSM, confirm OK!
4-go to Power scan
5-Select Band DCS1800 click OK
6-the cell frozen
7-wait for 3 minutes testing
8-while testing connect to a pc using the USB cable (do NOT select ANY of the options appearing on the cell screen)
9-Click the CENTER button of the cell until you go back to principal menu
10-go to settings/network settings and choose GSM Preferred or any other option (except WLAN only!!)
In this way the cell does not reboot, and the wifi application stays off, so the option can now be changed...
Hope this helps!
Greetings from Greece!
Sep 05, 2009 | Dual Electronics CECT P168 Cellular Phone
"Not allowed to dial" new c5000 wi-fi phone
put 2 chips on cell
Disable WLAN.
4-go to Power scan
6-the cell frozen
Hope this helps!
e-mail me to akiss_bd@hotmail.com if any questions..
Sep 03, 2009 | Dual Electronics CECT P168 Cellular Phone
"not allowed to dial"on f003 phone
hi mate,just follow these instructions 1. make sure to have 2 sims in phone(do not use 3g sims) 2. make sure wlan is disabled 3. enter engineer mode (type in *#3646633# 4.scroll up not down to number 10 RF test tool 5.choose gsm touch ok verify ok touch power scan 6.select band dcs 1800 press ok phone will go to test looking for DES(frequencies) wait until phone crashes or seems inactive(can take 3 to 15 min) press the end button (red one) phones with one middle button use that one phone will go off turn on phone and it will be reset to flight mode....(you can try to make call to verify,phone wil say cannot make call,not, not allowed to dial like before) go to settings and network setup,sim1 network setup,prefered mode and select gsm prefered...(phone will now change mode unlike before saying unfinnished) try the phone to make a call (should be no prob now) not finnished though .... go into settings again select restore factory settings (password 1122) wait for phone to restart...now its all done .....now you can change your tones and turn wlan on etc do not for any reason select wlan only or gsm only again...
Jul 19, 2009 | Dual Electronics CECT P168 Cellular Phone
Mi F003 show the error NOT ALLOWED TO DIAL tis is a video of the error: http://www.youtube.com/watch?v=bhJj21J6z_M Thank´s
put 2 chips on cell
Disable WLAN.
4-go to Power scan
6-the cell frozen
Hope this helps!
email me to akiss_bd@hotmail.com if any questions
Jun 30, 2009 | Dual Electronics CECT P168 Cellular Phone
Cell Phones Logo
76 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
