Question about LG WM2487H Front Load Washer
Started out with the door having a small leak coming out of the bottom part of the door. Just in the last two days the floor is now soaked with water? Can you tell us where to start looking for the problem?
  • 57 Answers
Most common and hard to believe is hair of any kind on the door boot(seal). Wipe the seal off and look for any misalignment of door.
Posted on Oct 15, 2010
What causes water to leak into the interior after rain?
Are you saying the water reappeared while the car was still in the garage? Hope this is not true, as that would most likely be related to the heater core or plumbing, but I thought all that was on the passenger side. If you mean after putting the car back outside and in more rain, possible cowl vent tube leak, windshield leak, or door vents at bottom edge blocked with debris.
Dec 27, 2014 | 1998 Lexus ES 300
Fridge leaking intermittently from the bottom
Sounds like your gasket may be going out. Consider replacing the gasket on the doors. Look for signs like small lines of frozen water that lead to the door or unexplainable excess ice in the bottom of the freezer.
I would also check for excess water in the condensation catcher tray, which may very well be located in the same spot under the ice maker. Depending on where you live (southeast, coastal, etc...) can have a strong contributing factor of having excess condensation, which will cause the tray to overflow.
Apr 25, 2017 | Kenmore Refrigerators
2002 suburban has leak in driver side rear floor. Cannot see where water would be coming from?
We had same--water on driver side rear floor (soaked!). Driver side front floor seemed dry until feeling UNDER rug, was slightly damp. We found the location of TWO leaks causing this.
Leak #1 was through the parking brake line/cable seal; Recaulked with silicone. Removed plastic trim on floor between floor and door to reveal metal channel filled with water.
Leak #2 was where the door meets the car, near the hinge. It was the accordian-looking tube housing the wiring for the door. The big, rubber, circular plug connecting it to the main part of the car had come loose and water ran down through that, into the SAME metal channel filled with water from leak #1; will seal with silicone.
Note: We found that the channel filled extensively near the front door, BUT the carpet edge from the floor near the rear seat was dipping into it, wicking it up to the rear floor. Also, upon acceleration, the water in the channel gushed toward the back, thus soaking the rear carpet.
These leaks were found by removing all plastic trim (covering edges of carpet by doors), then one of us pouring water into specific areas of the exterior of the vehicle, and the other one watching closely with a flashlight for any signs of dripping.
Feb 18, 2010 | 2002 Chevrolet Suburban
Whirlpool Front load washer - Water leaking
I would check to see if you have a hole or crack in the rubber boot inside the door. Open the door and seperate the fold in the rubber boot and check for a leak. If something sharp was left in someones pocket it will get stuck in this part of the bood.
Dec 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water leak passenger side in dodge caravan 2005 carpet soaked
look at the firewall on the engine side and you will see a small stub hose coming out on passenger side about even with the bottom of the heater box inside. that hose drains condensation from the ac...clear it out and you will have a dry floor. (unless heater core is leaking but you didn't mention any overheat or coolant loss so likely that's not a problem)
Jun 15, 2009 | 2003 Dodge Caravan
Saturn LS 200 leak on drivers side.
more than likely it is your A/C box drain clogged look for a rubber spout that comes out of the firewall and try to squeeze out the clog you will know when water starts to come out
Apr 21, 2009 | 2003 Saturn Ls 4dr Sedan
3rd door seal leak
From what I understand (and have experienced) the S-10 has a tendency to need the pins and bushings replaced early. Mine started with moisture in the cab, but the problem became apparent when there was a breeze around my door frame. I confirmed the diagnosis with my "car guy" and have replaced my pins and bushings. The mystery moisture and wind-noise is now a thing of the past. More recently I've had to move on to the next disgustingly popular issue... the broken third door handle.
Dec 04, 2008 | 2001 Chevrolet S-10
Bosch Dishwasher door leaking at bottom, brand new.
Um rough to diagnose without seeing it but there should be a rubber gasket along the bottom of the door. And does the door panel hit the side of the tub when u shut the door? It shouldnt
Nov 22, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
LG WM2487H Front Load Washer Logo
129 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
