Question about Delta 28 276 14" Band Saw W/ 3/4 Hp Motor & Open Stand
Upper Wheel Rubs Housing I recently purchased a new Delta Model 28-276 Open Frame Bandsaw. I have completed assembly and leveling/squaring all the components. When I turn the saw on, there is a slight rub of the housing on the top wheel. I don't want to pry to back by placing pressure on the top, or the bearing in the hub for that matter. Any ideas? Thanks.
5 Suggested Answers
jyackle5
  • 8197 Answers
SOURCE: Need Manual for Delta Bench Band Saw 28-185
http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/Delta/En1346498.pdf
Posted on Jan 11, 2009
  • 236 Answers
SOURCE: I am not having much luck with blade alignment on
Check that the washers on the motor shaft are positioned properly. I believe the washers are dish shaped one should be on each side of the blade with the wide shoulder aginst the blade. Check this. Also if you go to Deltaportercable.com you can get an owners manuel for free on line. If this was helpful, please leave feedback.
Thanks, Snugglepants
Posted on Nov 03, 2009
  • 4088 Answers
SOURCE: Will Delta Belt fit Mastercraft Band Saw
If you still have the old belt, take it to a well equipped hardware or auto parts store for a replacement. If the previous belt is missing, you will need to measure the pulley 'V' width at the top of the 'V', the center to center measurement of the two shafts, and the outer diameters of the two pulleys. Hope this helps!
Posted on Jun 25, 2010
SOURCE: 28-276 Delta bandsaw blade keeps coming off?
Unplug the machine, gain access to the two wheels. On the back of the machine you should have a tilt adjustment knob. Manually turn the wheels in the direction of the cut and at the same turn adjust the tilt knob on the back of the machine. This should solve the problem.
Posted on Jan 23, 2011
I need a manual for Delta Bandsaw model 28-150
You can download a copy of the Instruction Manual for the Delta 28-150 Bandsaw from the following link:
http://www.mikestools.com/download/Delta-Bandsaw-manuals/28-150.pdf
Jun 28, 2011 | Garden
Tire comes off top wheel almost all the time. Tire comes off bottem wheel sometimes. Don't know how to set up this saw.
My jet bandsaw did same thing only fix was new tires .Tires are supposed to be tite on wheel .get wood dowels between tire and wheel and roll new tire onto wheel. If desperate could glue on with weather strip adhesive.put bandsaw blade on both tires spin wheels with power off till blade is running in center of wheel by adjusting top wheel in or out. When done adjust blade guides to blade and bearings to back of blade .This is top and bottom of cutting area
Jan 16, 2011 | Delta Woodworking Delta Rockwell 14 Inch...
My bandsaw will not always start. It will make a buzzing sound like the motor is trying to spin, but the blade doesn't move. I've sometimes spinned the lower wheel by hand quickly, and then turned it on,...
The problem you describe is common to capacitor start motors. It is the starting capacitor that is bad. (There are no diodes and Radio Shack will not have the part you need.)
The starting capacitor is under the small cylinder on the side opposite the electrical connections (Not inside the motor housing.)
My bandsaw has a capacitor with leads that go into the housing. If I had to replace it I would cut the leads right next to the capacitor leaving them as long as possible and splice them using wire nuts or put spade lugs or quick connects on them depending on the new cap. The important criteria for the cap is Voltage rating (probably 200volts if you are using 110vac) and Capacitance.
Graingers or McMaster-Carr would be a source.
Good Luck
May 20, 2010 | Delta Woodworking Delta Rockwell 14 Inch...
I just purchased a used Rockwell bandsaw. I need
Ok so you understand that Rockwell became Delta, or was it the other way round?? Either case the best source of manuals for these much loved machines is over at Old Wood Working Machines:
http://www.owwm.com/mfgindex/detail.aspx?id=698&tab=3
You should find your model.. 14" Delta doesn't really pin it down too exactly. The model number should be on the warning plate.
Feb 26, 2010 | Delta Woodworking Delta Rockwell 14 Inch...
I am changing the saw blade on 12 inch Craftsman bandsaw
Go to: Searspartsdirect.com and enter the complete model number minus the decimal point. This will bring you a series of parts drawings and possibly an owner's manual. Generally, adjustment is provided for the upper wheel only--use hand power to check the tracking performance. Good luck!
Jan 12, 2010 | Saws
Upper wheel on a model 28-682 bandsaw. How do you adjust it.
With saw unpluged!!!!! open top wheel gaurd.Spin wheel by hand while moving the adjuster knob on back of the machine. As you turn both at the same time the blade will trac either the front or back of the wheel. Move the knob (while spinning the wheel) until the blade is tracking in the middle of the tire. (rubber strip around the wheel)
Jun 10, 2009 | Saws
Rubber on wheels is shot. Where can I get new rubber?
Here are a few links to new tires for your bandsaw, available here and here and here. If you google "bandsaw tires", you'll find they are pretty widely available and may be able to come up with a better price...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
May 08, 2009 | Delta Woodworking Delta Rockwell 14 Inch...
Need bandsaw manual
Go to this link: http://www.dewaltservicenet.com/Products/DocumentView.aspx?productid=43116&typeId=9930&documentId=29416
Instead of clicking on Instruction Manual, click on the model number of the saw. This takes you to a page showing the parts diagram.
In the upper left of that page see 2 links to manuals. You want the one that begins EN...
If I've managed to answer your question or solve a problem, please take a sec to rate this post....thanks!
Mar 29, 2009 | Delta BS100 Shopmaster 9 Inch Bench Top...
Manual for Rockwell 52-235 14'' bandsaw
I don't know how old that machine is, and I can't get any hits on the model number you gave, but have a look at this link and the other Delta/Rockwell bandsaw manuals available at the same site, and you may find something that you can use. Go to machine info>publication reprints>and choose either Delta or Rockwell, then you can filter the results by bandsaw and see what's available out there. To download, just click on the blue letters PDF under the publication preview picture.
Mar 08, 2009 | Saws
I need to know how to get to the rear suspension (tower)
i don't think you have to do any repairs from the top end. I will list most fromFord shop manual. Please rate as Fixya if this answers your questions. Please report back. Good luck.
Section 04-02: Suspension and Wheel Hubs, Rear 1994 Town Car, Crown Victoria/Grand Marquis. Workshop Manual
REMOVAL AND INSTALLATION Spring Rear
Removal
  1. Position a hoist under the rear axle housing, and raise the vehicle. Refer to Section 00-02 . Place jackstands under frame side rails.
  1. Remove rear stabilizer bar as outlined.
  1. Disconnect the lower studs of the two shock absorbers from the mounting brackets on the rear axle assembly .
  1. Unsnap the RH parking brake rear cable and conduit (2A635) from RH upper arm retainer before lowering the rear axle assembly .
  1. Lower the hoist and axle housing until the rear springs are released.
  1. Remove rear spring and rear spring center mounting insulators (5741) from vehicle.
Shock Absorber Removal
Raise the vehicle on a hoist. 1. To assist in removing the upper attachment on shock absorbers using a plastic dust tube, place an open end wrench on the hex stamped into the dust tube's metal cap. For shock absorbers with a steel dust tube, simply grasp the tube to prevent stud rotation when loosening the retaining nut.
  1. Remove the shock absorber retaining nut, washer, and insulator assembly from the stud on the upper side of the frame. Discard nut. Compress the shock absorber to clear the hole in the frame, and remove the inner insulator and washer from the upper retaining stud.
  2. Remove the self-locking retaining nut, and disconnect the shock absorber lower stud from the mounting bracket on the rear axle tube.
  3. Perform Shock Absorber Checks. Refer to Section 04-00 to determine shock absorbers performance.
Installation
  1. Properly prime the new shock absorber . Refer to Section 04-00 , Shock Absorber Checks.
  1. Place the inner washer and rear spring insulator (5536) on the upper retaining stud, and position the shock absorber so that the upper retaining stud enters the hole in the frame. While holding the shock absorber in this position, install a new rear spring insulator , washer and nut assembly on the upper side of the upper frame. Be sure to seat the rear spring insulator in the frame attaching hole. Tighten nut to 34-46 Nm (25-34 lb-ft).
  1. Extend the shock absorber , and place the lower stud in the mounting bracket hole on the rear axle assembly housing. Install a new self-locking retaining nut. Tighten nut to 76.5-103.5 Nm (56-76 lb-ft).
  1. Lower vehicle.
Arm Lower
Removal
Refer to the illustration in Description and Operation. NOTE: To improve rear axle assembly noise and vibration concerns, the rear suspension should be fastened to the frame and rear axle assembly at the curb height position.
NOTE: If one rear suspension lower arm requires replacement, also replace the opposite rear suspension lower arm .
sra~us~en~file=ani_caut.gif~gen~ref.gif WARNING: TURN REAR SUSPENSION LEVELER COMPRESSOR SWITCH OFF (IF SO EQUIPPED).
NOTE: If both rear suspension arm and bushings and both rear suspension lower arms are to be removed at the same time, remove both rear springs as outlined under Rear Spring Removal. For air spring removal, refer to Section 04-05 .
  1. Mark rear suspension shock absorber relative to protective sleeve with the vehicle in a static, level ground condition.
  1. Raise the vehicle on a hoist, and place jackstands under the rear axle assembly . Refer to Section 00-02 .
  1. Lower the hoist until the shock absorbers are fully extended to relieve rear spring pressure.
  1. Support rear axle assembly under differential pinion nose as well as under rear axle assembly .
  1. Remove and discard the lower arm pivot bolt and nut from the axle bracket. Then, disengage the rear suspension lower arm from the bracket.
  1. Remove and discard the pivot bolt and nut from the frame bracket, and remove the rear suspension lower arm .
Upper
Removal
SPECIAL SERVICE TOOL(S) REQUIRED Description Tool Number Suspension Bushing Service Set T79P-5638-A1, A2 and A5 Rear Axle Control Arm Bushing Tools T86P-5638-AH
sra~us~en~file=ani_caut.gif~gen~ref.gif WARNING: TURN OFF REAR SUSPENSION LEVELER COMPRESSOR SWITCH (IF SO EQUIPPED).
  1. Raise the vehicle, and support the frame side rails with jackstands. Refer to Section 00-02 .
  2. Support the rear axle assembly .
  3. Lower the rear axle assembly , and support the rear axle assembly under differential pinion nose as well as under rear axle assembly .
  4. Unsnap parking brake rear cable and conduit from upper arm retainer.
  5. Remove and discard the nut and bolt retaining the rear suspension arm and bushing to the rear axle assembly housing. Disconnect the rear suspension arm and bushing from the housing.
  6. Remove and discard the nut and bolt that secures the rear suspension arm and bushing to the frame bracket, and remove the rear suspension arm and bushing . If upper arm rear bushing is to be replaced, use Suspension Bushing Service Set T79P-5638-A and Rear Axle Control Arm Bushing Tools T86P-5638-AH and the following procedure:
  7. Place the upper arm rear bushing remover tool in position, and pull bushing out. Using Suspension Bushing Service Set T79P-5638-A install bushing assembly into bushing ear of rear axle assembly.
Stabilizer Bar
Removal
  1. Raise vehicle on hoist, and place jackstands under the frame side rails. Refer to Section 00-02 .
  1. Lower the hoist and rear axle assembly housing until the shock absorbers are fully extended.
  1. Disconnect rear stabilizer bars from rear stabilizer bar link and bushing (5C488) . Remove bolts and stabilizer bar bracket (5486) retaining rear stabilizer bar to rear axle assembly .
Mar 05, 2009 | 1994 Lincoln Town Car
Delta 28 276 14" Band Saw W/ 3/4 Hp Motor & Open Stand Logo
63 people viewed this question
Top Delta Saws Experts
Jim London
Jim London
John Trevino
Are you a Delta Saw Expert? Answer questions, earn points and help others
