Question about Jenn-Air JJW8527C Expressions Collection Electric Single Oven
Inserting ribbon connector into New electronic clock assembly
Trying to replace electronic clock assembly on drop in Jenn Air oven model W30400W.  He the new part but can't seat the ribbon into the slot.
    Guru:
  • 1,342 Answers
If it is a flat ribbon there will probably be a retainer clip that either lifts up or slides up and down to hold the ribbon.
Posted on Jun 15, 2008
    Genius:
  • 1,665 Answers
Select your model at search tab of the link below to parts available
http://www.repairclinic.com/SmartSearch/smartsearch.aspx
  • 1,512 Answers
Hi Lil
Does the ribbon connector have a locking tab that fist needs to be lifted a mm to allow for the ribbon to be fitted. Then locked down afterwards to hold it in place
    Guru:
  • 1,894 Answers
Wi cant to just remove some portion of it
  • dewan nafees ahmed Jun 15, 2008
    else buy a smaller ribbon than that so that it fits inside.
    if ribbon dint get seated properly then it wont move properly.
    Master:
  • 555 Answers
Is the ribbon binding up on another component?
Posted on Jun 03, 2008
FO beeping on both upper and lower ovens
Hi
Error code F0 means that an error with the keypad has occurred. Usually it happens due to loose ribbon cable on the keypad or the electronic control assembly itself going bad. To resolve this issue first, disconnect the power to unit and then gain access to the back of the clock assembly (Electronic Range Control/ERC). Now unplug the touch pad ribbon connector from the ERC, it would be a flat wire approx. 1 1/2" to 2" wide and make sure that the cable is not broken and nothing is shorted on the keypad. After this is done insert the cable back and then plug the unit back to check. If the error is still there then the electronic control board should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 10, 2011 | GE Profile JTP56 Electric Double Oven
What does F-7 mean on display. I was taking milk out of microwave and dropped it and it spilled on oven which is directly below. It is beeping and will not quit.
Hello & Welcome to FixYa
F7 error code is displayed when the clock assembly/electronic range control (ERC) goes bad and needs replacement. Please get back to me if you have any other questions.
Kevin
Dec 13, 2010 | Jenn-Air JJW8230D Electric Double Oven
F1 error code and constant beeping and oven shuts off.
Hi gwhiz03,
If you are having error code F1 with your Jenn-Air double wall oven this is because you have a defective touch pad or clock (ERC). This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Hope this helps.
Thank you for using FixYa.
Feb 10, 2010 | Jenn-Air WW30430P Stainless Steel Electric...
Jenn air oven
More then likely your electronic clock control board is going bad. After turning the power off, you can also try cleaning the connectors on the clock board and make sure the connectors are tight.
Mar 23, 2009 | Jenn-Air JJW8230D Electric Double Oven
Display pannel does not display/work
I had the same problem... fading on the display. Replaced the display internal panel. It is a common part with other major appliance manufacturers. The problem was corrected.
Mar 23, 2009 | Jenn-Air JJW8527C Expressions Collection...
F7 fault code on the Jenn-air W30400W
The F7 error code on your oven indicates the touch pad has failed. To repair it you will need to replace the touch pad which is listed as a control panel w/keypad in the parts diagram.
If you do the repair yourself, disconnect the power to the oven. Take the 3 screws out above the door that hold the control panel on to the oven. Pull the control panel out at the bottom and lift it up, then pull out the top and drop it down so you can see the back side of the control panel, and you will see a ribbon connector going from the touchpad to the electronic oven control (ERC).
There is a latch holding the ribbon connector to the ERC, raise the latch to release and pull the ribbon out of the ERC.
Replace the part and reverse these instructions to replace the control panel.
Hope this helps .
Mar 04, 2009 | Ovens
Jenn-Air Wall Oven Model #WW30430P F5 Fault Code
I have the exact same problem with an F5 fault code. I also have a new clock assembly. RepairClinic.com said "Jenn Air fault code F5 = Hardware and watchdog circuits disagree / Replace clock assembly (also called the ERC)
Jenn Air Fault code for newer models F5 = Power to element relays disabled in cook mode
1. Intermittent oven temperature sensor or wire harness or,
2. Intermittent contact on power relay board"
This doesn't help since it is too technical. What should I do next?
Oct 19, 2008 | Jenn-Air WW30430P Stainless Steel Electric...
Jenn air oven display
the digital display on my jenn-air oven, model jjw9527c...has gone completely out. i am very efficient in wiring and electronics and would have no problem fixing it myself, just not sure which parts i need to order. Please return this with a solution, holiday season is very close.....thank u
Feb 09, 2008 | Jenn-Air JJW9527C Expressions Collection...
Jenn-Air WW30430W double oven flashing F7 and beeping
It seems you have a stuck button. Here is a list of fault codes:
JENN AIR
Range/Stove/Oven Fault Codes
Failure
Code
Condition Check/Repair F1 Defective touch pad or membrane Replace touch pad or membrane (this problem is usually the touch pad) F1 Watchdog on board Replace touch pad or clock assembly (also called the ERC) F2 Oven too hot Replace relay board (if present) or oven temperature sensor F3 or F4 Open or shorted oven temperature sensor Replace oven temperature sensor F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Check for proper voltage F7 Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or attempt to un-stick button F8 Analog/Digital supervisory Replace clock assembly (also called the ERC) F9 Door latch supervisory Check door lock circuit or replace clock assembly (also called the ERC) F0 Function key stuck Replace touch pad or clock assembly (also called the ERC)
Dec 09, 2007 | Jenn-Air JJW8530C Expressions Collection...
Jenn-Air JJW8527C Expressions Collection Electric Single Oven Logo
123 people viewed this question
Top Jenn-Air Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Craig Butler
Craig Butler
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
