Question about Haier 539490003 Air Conditioner
A/C Unit Pushed too far into window??
I need a haier a/c manual (window unit) manual. I am concerned that I put my unit too far into the window well and it may fall onto the neighbor's house. Can anyone clarify how it rests in the window frame?
    Genius:
  • 3,587 Answers
It's better to put a supporting frame under these for a variety of reasons, not withstanding your neighbors sanity and well being.
Posted on Jun 03, 2008
Haier service manual
This is what you error code means.
E1 = Room temperature sensor fault
Haier Air Conditioner Fault Codes
AC Repair Tamarac
Aug 25, 2014 | Haier Esax3186 Energy Star 17,000 Btu...
I need an owners manual for a Haier HWF05XC7-2
Do not add water to the pan under the air conditioner. Water may collect in the pan and could overflow the pan in some conditions. If you add water, you are more likely to have water spill from the pan. Air conditioners like this work by refrigeration. As the air cools, the air can't hold as much water and this condenses into the pan.
The user manual for the HWF05XC7-2 is available from Sears Parts Direct on the product support page: http://www.searspartsdirect.com/partsdirect/user-manuals/HWF05XC7-HAIER-AIR%20CONDITIONER-manual . The direct link to the manual is http://c.searspartsdirect.com/mmh/pd_download/lis_pdf/OWNM/L0808288.pdf . Note: the manual covers two models, HWF05XC7 and HWF05XC7-2.
I hope this helps.
Jun 15, 2017 | Haier Heating & Cooling
Frigidaire Window/Wall Unit Dripping onto neighbor downstairs - suggestions for redirect?
Hello, you can use a drain hose and coonect it to the outlet of the drain hole. This way you can terminate the hose away from your neighbor.
Jul 08, 2012 | Frigidaire FRA186MT2 Window Air...
1 month old Haier 12000BTU Portable Unit LEAKS like mad!
If it has an evaporation pan to "Cook Off" the moisture, it would be putting it back into the air, where it just removed it from. This will, in time cool the room but the humidity is being returned. It is possible however, that drain from the condensor to the collector is clogged, causing it to overflow. If you still have it, install the window exhaust kit that came with the unit. This will help eliminate the humidity from the room and the moisture from the unit.
As for the mols problem, Use a sprayer of choice, depending on how much area you need to spray. Mix unscented CHLORINE bleach with water, 1/2 cup bleach to 1qt water. Spray until surface is wet but it doesn't have to run down the walls, unless you need to treat them too. The chlorine bleach will kill any mold & fungus spores that it contacts. Unscented is a lot easier to live with. The regular smells like a swimming pool for a few days.
Aug 28, 2009 | Haier HPAC99ER Air Conditioner
Lost Manual to Heir window unit
hi there. i can help you. here is the link to haier's site where you can download a free manual. just enter your model number where they ask for it.
http://www.haieramerica.com/en/support/?sessid=8398284157804f528f7f52348d7e0ff2
Jun 10, 2009 | Haier ESA306 Air Conditioner
Haier AC HWR10xc6
Haier Air Conditioners do not have a drain hole or hose like most A/Cs. This problem can easily be solved by carefully drililng about an 1/8 or 1/4 inch hole in the bottom outside edge directly on the metal frame, around the cooling fins.... This will elt the water drain out...if you when outside and looked in while it was spitting you would see the water pooling up in there. Haier expects us to mount these units at an ungodly angle to drain the water, but drilling a small hole will help (really anywhere in that bottom plate would work since the whole bottom is a "drain pan"
Aug 30, 2008 | Haier hwr10xc6 Air Conditioner
Manual needed
I own a Haier A/C window unit, and have the owner's manual. If anyone needs help with this make and model, I might be able to help. Please remember, I am not a certified tech. I only have the manual for simple questions. chicagosinger
Jul 11, 2008 | Haier hwr10xc6 Air Conditioner
HAIER HWV10XC6
Fabricate a new bracket that can support the unit weight and for the safe of the unit also.
Mar 31, 2008 | Haier hwr10xc6 Air Conditioner
Haier a.c. will not run 24,000 btu. Window Unit.
1.voltage stabilizer.
2.selector switch.
3 check input wiring.
4 check out put wiring.
Mar 25, 2008 | Haier Preference Plus HWR24VCA Air...
Haier 539490003 Air Conditioner Logo
79 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
