Question about Nautilus Commercial Series T916 Treadmill
T916 tredmill turns on, but then says it needs calibration and the motor doesn't turn the belt.
  • 3 Answers
Where are you located
Posted on Nov 21, 2010
SOLUTIONS TO E1 PROBLEMS IN TREDMILLS
Dear Sir:
adjust the speed sensor, clean, and tight very well.see the diagram attached
2) Test the input voltage motor, if there are THE MOTOR need repair
3) Tes the output voltage in the main motor board , if there are Not, the board is faulty.
Of course run the software calibration aftr you fix it.
sincerly. God bless you
Apr 24, 2012 | Bh Fitness X8 Treadmill
Error 7 how to fix for tredmill
Dear Sir:
This is indicating problem with your elevation motor.
Please check the connection, and tight, lubricate the gear + shaft .
Test the motor is o.k or faulty.
Run the software calibration for easy diagnose and troubleshooting.
See my personal TIPS for diagnose and Help.
sincerely. God bless you.
Ernesto Cuadra
Managua, Nicaragua.
Mar 05, 2012 | Exercise & Fitness
How do i fix an e07 error on carl lewis tredmill or does any1 know why it has happenend?
1) Make calibration for to help to diagnoctic the troubleshooting in acording with your owner manual, The steps are under the hood.
2) You must adjuts the speed sensor, and tight the connector.
3) The main motor can be faulty. test the voltge withouth load 115vac.
4) The controller motor board had been faulty. Test for input voltage 115 VDC. and +5VDC for input for display board.
5) Test the transformer for primary voltage 115 vac, AND SECONDARY voltage. 6) Adjust for mechanical the deck belt, 7) Lubricate the deck belt.8)See the block diagram that I did for people like you. and take the diagnostic for better result.
The error code e7- could be the same for e1 , only vary from manufacturers. If you need parts. you can go www.weslo.com or www. proforma.com or www. reedbook. com they represent to carl lewis manufactering.
sincerely. Merry Christmas.
ernesto cuadra
mnagua, nicaragua
Dec 15, 2011 | Exercise & Fitness
I have a pro form xp weight loss 620 tredmill and when I turn it on and press start the belt runs for about 1 sec. On the main board in the bottom of the tredmill there is a LED and sometimes it turns off...
Since the motor shroud is off I would like you to manually move the running belt by foot and see if that LED flickers if is does then your speed sensor is working properly. If not then the speed sensor needs to be replaced. The next thing I would be checking is the drive motor, using a fully charge drill battery, lantern battery or even a 9V battery by connecting the two leads coming off the drive motor it should move the motor at approx. 1 mph if it is moving the motor is good. then I suspect the lower board will have to be replaced.
May 17, 2010 | Exercise & Fitness
Tredmill not moving
That's an embarrasing admission. A treadmill works like a conveyor belt or a car's fan belt. If it is too loose it will slip under load. There will be an ajuster on your treadmill. All you have to do is tighten the belt. Do not overtighten it though. an
Feb 17, 2010 | Cadence Weslo 825 Treadmill Walking Belt
Weslo cadence treadmill wont work
I centered the belt on my tredmill and now it wont move at all. I tighted and loosened the belt. motor runs belt wont move
Feb 05, 2010 | Cadence Weslo 825 Treadmill Walking Belt
Hi my tredmill will turn on but moter wont
If elevation will work it's more than likely your motor controller. I would need to know which treadmill you have to help any futher.
Nov 15, 2009 | Exercise & Fitness
I am having trouble with my Bowflex TC5000. The calibrations is failing. The treads aren't moving but the monitor is trying to calibrate.
The motor must move the drive pulley for calibration to pass. remove rear covers and check drive belt. you should hear the lwr board relay click to engage the motor. if you hear it and the motor does not move and you have checked the belt then you need to test the motor. Typically remove the belt and turn by hand...it should be very smooth and spin freely. If not replace the motor. Direct 9 volts to the motor leads unplugged from the board will tell you if the motor is good. be careful as capacitors are present and risk of shock is always possible. capacitors stay charged for about 10 mins after unit is unplugged
Jul 30, 2009 | Bowflex Treadclimber
Tredmill error code
Moat likely a problem with the motor control board. See treadmilldoctor.com
Apr 16, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Nautilus Commercial Series T916 Treadmill Logo
175 people viewed this question
Top Nautilus Exercise & Fitness Experts
David Payne
David Payne
Electro Med Services...
Techmotionusa.com
Techmotionusa.com
Are you a Nautilus Exercise and Fitnes Expert? Answer questions, earn points and help others
