Question about Philips 109B60 (White) 19" CRT Monitor
Hello, Philips 109B7 monitor i have and its video cable pinout has broken, to fix this trouble i need to know its pinout cable color. Not just pinout chema but Pin Assignment The 15-pin D-sub connector (male or female) of the signal cable colors to fix its plug. Sorry about my english. thanks for advance.
    President:
  • 2,571 Answers
CRT VGA cable pin color problem. I can not get which pin connect where
Refer its connection diagram. The user manual might help you. If not, contact any service technician.
Nov 25, 2014 | Philips Televison & Video
I need help with the color there is no red or green went thru the manual and the sample colors are ok, went back to regular program and colors are terrible,
check you cables like a VGA monitor you have three colors Red Green Blue on the cable and if one is broken then the color will not come in correct. on your device that feeds video to the tv try some different cables and inputs it might be a bad cable
Jan 02, 2011 | Philips 42PFL3704D LCD TV
Necesito el diagrama de conexion interno para lcd kds 700p. i need de pinout tech info for lcd monitor kds model 700p myy wire is broken........ i just adapt a new part used,,,?
necesito el diagrama de conexion interno para lcd kds 700p. i need de pinout tech info for lcd monitor kds model 700p myy wire is broken........ i just adapt a new part used,,,?
Dec 12, 2010 | KDS K717s 17" LCD Monitor
What is VGA cable extend color code ???
bro it a cable connected through monitor
Nov 12, 2010 | Computers & Internet
Hello, The VGA cable broke. it was cut off and now it's lost. I can put back a VGA connector however I need a wiring diagram so I can know what color goes to which pin. Can you help? Thanks.
Not knowing which monitor that you have I will have to be a bit general. If the cable disconnects from the back of the monitor then you can simply replace the cable with another vga cable. If the cable does not disconnect then my best advice is to look at the other end of the cable and get the pin out from the controller board on that end. Unfortunately that procedure would require opening up the monitors case.
http://pinouts.ru/Video/VGA15_pinout.shtml
The above link will also help as a reference. However keep in mind that some of the colors may not match. Which is why you would need to check the other end of the cable to be sure. Good luck.
Aug 25, 2010 | Computers & Internet
Cable end chopped off need to know pinout mapping to reattach a new cable end to attach to computer.
All VGA connectors use the same pinout. Here's a link that shows you the VGA Pinout,
http://www.interfacebus.com/Design_VGA_PinOuts.html
More monitor pinouts,
http://www.montest.com/technote.html
Apr 21, 2009 | KDS K717s 17" LCD Monitor
Rabbit eats video cable....
That is a dificult task to find a new one, unless you have a broken one you want to take apart they are not a standard cable. Your best bet is to go to an electronics store and buy a new plug to solder onto what is left ofthe cable. To find the pinout, just use a digital multimeter and test the continuity of the pin to the color of wire on the other end. Then just find yourself a VGA extension cable.
Jan 15, 2009 | ViewSonic VE710b 17" Flat Panel LCD...
Phillips VGA Cable colour chart
you can use any vga monitor with the same color output and resolution setting just goto craigs list in your town and look for someone throwing one out detach old cable and reapply to your screen by either soder or splicing the wires independently together this is tricky
http://www.lammertbies.nl/comm/cable/VGA-monitor.html
Pin Name Function 1 RED Red video 2 GREEN Green video 3 BLUE Blue video 4 n/c not connected 5 GND Signal ground 6 RED_RTN Red ground 7 GREEN_RTN Green ground 8 BLUE_RTN Blue ground 9 VDC 5 VDC supply (fused) 10 GND Signal ground 11 n/c not connected 12 SDA DDC / I2C data 13 HSYNC Horizontal sync 14 VSYNC Vertical sync 15 SLC DDC / I2C clock
Jun 02, 2008 | Philips 107E66 17" CRT Monitor
Philips 109B60 (White) 19" CRT Monitor Logo
193 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
