Had the same problem. It all looked OK and it found the Avantalk, but it would not 'pair' and kept failing. I decided the problem was probably with the Avantalk unit and wondered if I had paired it with too many other phones so decided to do a 'reset' on it. This is achieved with the Avantalk turned 'on-standby', with the two blue flashes every few seconds. Press and hold the up and down volume buttons for more than 5 seconds, at which point the red and blue lights will flash on and off 5 times very quickly. The unit should then return to its 'on-standby' state again. Switch it off (larger MFB phone button), then on again and then set it into pairing mode (immediately after the Avantalk has come on, press and hold the MFB button again until the red and blue lights are flashing), then go through the searching blue-tooth device and so on again with you phone. It should all work now.
Cheers... Rob.
Hi i have the galaxy s2 i have paired it with the avantalk but when i am in the car i and i want to call somebody i still have to touch the phone then say what i want to do am i doing something wrong can you help please thanks kath
