Question about Motorola Cell Phones
Phone not charging. starts charging then stops repeating that cycle. After many attempts I can charge it enough to use it for a day. At night it is always a fight. the phone is a Motorola Slvr L7
    Brigadier General:
  • 7,752 Answers
You need to change the battery if the problem persist then have the firmware reflash on the phone.
Posted on Jun 03, 2008
Wheelchair runs fine after charging but only after 1 day 6hrs use it stops with a jerk and then controller lights start blinking.
Thank you for all the information, number one, charge with the joystick on for 12-14 hrs. there is a circuit in the joystick that can cause problems, in order to reset it you will need to charge it like this. The batteries will last longer if the batteries are charged every night that it is used during the day, also, instills good charging habits.
The blinking is a flash code, count the flashes, and refer to the owners manual for meaning. The joystick maybe failing or the controller or both. Motors may need to be cleaned out.
Apr 12, 2016 | Health & Beauty
Why is my bike clicking and wont start?
make sure you got your terminals tight. then if so its still your battery not charged, just push it til you get jogging speed jump on put it in second pop the clutch it will start let it run about 20 to 30 mins should be enough charge built in your battery to restart it, if not your battery is bad even though its fairly new could be low on water inside it !
Jan 19, 2013 | Motorcycles
My device won't charge
This situation sometimes occurs when the batteries get overcharged. Use the phone for a day and then attempt to charge. If it still won't charge, remove the battery for about a minute. Then re-install the battery and attempt to charge. If that doesn't clear the problem, you may need to get a new battery.
Mar 03, 2012 | Motorola Mobility T505 Handsfree...
My battery was was not charged for 2 days over the weekend and now it won't run on batteries. I need to have it on AC power every time I use it.
Laptop batteries can become unchangeable if they are completely discharged, and left that way for too long. This happened to my Asus. IF you leave it charging over night and it still doesn't work you will need a new battery. If you contact the manufacture they will probably charge you over $100 for a new battery. If you use eBay, the average price is $32.
Regards, Chris
Jul 12, 2011 | Lenovo IdeaPad S10e Netbook
Why will my phone not charge? now it wont turn on all together. last night while attempting to charge my phone i had to move the charger around just to get it to charge but it would stop charging right...
hi this sounds like a problem with your charger , try using another charger if not you may have a battery problem which may be quite simple to replace on auction websites such as ebay etc.
Dec 20, 2009 | Motorola Mobility ROKR E8 Cellular Phone
K850i charging problems and red light flashing at on/off key
Your battery is either not charged or the battery cell is completely gone.
I'll advice that you get another battery and give it a trial, also look out for the charging port. Check if it is not rust in any way because, if the charging port is rust, it will be difficult for the charger to contact the charging port.
I believe what's wrong with your phone is a minor fault, just do a thorough check and you will find a solution to the problem.
Best wishes.
Dec 04, 2009 | Sony Ericsson K850i Mobile Phone
Battery is always dead
This is a common problem with the Q. It uses a lot of juice to run all of the programs. There are a few things you can do to help with this problem. First, Kill all of your running programs before going to bed. You can do this by selecting Start, then System Tools, then select the Task Manager icon, then choose Menu, then "Kill All". Since you will repeat this a lot it is a good idea to save the Task Manager program as a speed dial. Second, Make sure you are not overcharging you battery. When it is fully charged, stop charging. Charge it again when the battery runs all the way down. Then repeat. This will "reset" your battery. Third, make sure you have a second battery and a battery charger. When you go to bed at night, simply replace the battery with a fully charged one. Finally, try this...keep your phone plugged in at night. Then run it all the way down before you replace the battery. Reset the battery often as you lifetime for the battery will diminish the more you keep it charged all night.
Jun 15, 2008 | Motorola Mobility Moto Q
My battery swell
Hi, Battery is calculated in Cycles and One Cycle is One charging & discharging. In ur case probly u might have used ur 300 Cycles. Most of the people do a mistake of keeping charging for whole of Night but when u talk about the cell phone if u keep in charging for the whole night unnessary Cycles are getting wasted. Mobile charge has a funda like it charges and over a time automatically it discharges as well. so don't keep it in Over night charging. U need to replace the battery. Else u will not get a perfect back up. Madhu AVN
Jan 28, 2008 | Sony Ericsson K310i Cellular Phone
Motorola RAZR flashes Cingular logo and then disconnects when phone rings
It may be just a faulty battery
I know you said it's straight out of the box but these things can happen.
try cycling your battery.
Step 1 run your bat now until it is low and phone is beeping to recharge
Step 2 Charger your battery for 4hrs with the phone on
Step 3 use it now until it starts to beep again and then repeat step 2.
Batteries are strange different types have different charge characteristics.
these do not like over night charging or being run dead flat they preform better if they are maintained with charge all the time
Nov 03, 2007 | Motorola Mobility RAZR V3
Cell Phones Logo
63 people viewed this question
Top Motorola Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Motorola Cell Phone Expert? Answer questions, earn points and help others
