In my home I have a Encore Model 7676 by Electro Brand It is a AM FM/Cassette/Message Center, built into a cabinet (above my wall oven) it works fine, but, is there an updated model which would play my cds. The instruction book says "Designed for use in Motor Homes, Mobile Homes, Recreational Vehicles and Manufactured Housing". Thanks, Tricia
3 Suggested Answers
Fixe_You
  • 1800 Answers
SOURCE: Electro Brand "Encore" RV Stereo
check for any magnatic field or radioactive units .
and try to be as far as u can.
Posted on Mar 05, 2009
tech48
  • 624 Answers
SOURCE: We have a phonograpph with
The most likely problem is with the belt that goes around the flywheels of the deck. You would need to take the cassette deck out of the unit and check it out to be sure. If the belt has come off or is broken, it needs to be replaced with the same type of belt and then it needs to be put back on in the exact way it is meant to be put on. This is something that may not be very easy for you to do unless you have some experience with this sort of repair. Taking apart a cassette deck can cause more problems with it, if it is not put back together perfectly.
The best solution for you would probably be to take it in to a repair center. If you decide to try it yourself, I am willing to offer help, but I do advise against it if you have no experience with them.
Let me know if you want more help,
Dave
Posted on Jul 26, 2008
Cannot read instruction manual
Here is the company contact info. Call them and ask them to send it to you. Electro Brand USA
Apr 08, 2014 | Encore Technology Portable Cassette...
How do we get an jvm59 GE Microwave oven out? The cabinet above appears to be covering the screws.
Sometimes older microwave ovens are built into the walls and are attached to the studs and mountings already in the house with cabinets built around them. Try taking off the paneling of your cabinets a little at a time until you can see how the microwave is attached. With any luck, it's held in by brackets underneath the cabinets and not attached to the studs in the walls.
Dec 05, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Mounting OTR microwave oven under a penisula cabinet
We put false doors on the back of the peninsula, mounted the wall mounts on the inside of these doors and then connected it to the top.
Mar 24, 2017 | GE Profile Spacemaker Over-the-Range...
I have a microwave oven that I need to take out.
These are mounted thru the cabinet above. there should be two bolts which you need to remove in the cabinet abobe. remove these while you have help holding the unit. it will not drop but is kind of hinged on the wall (a lip sits on a bracket on the wall) After removing the two bolts tip the unit forward and lift off the bracket on the back wall.Don't forget to unplug it and pull cord thru cabinet as well Good luck...
Jan 19, 2009 | Jenn-Air JMW8330DAS Stainless Steel...
Removing Old Built-In Microwave
You did not note your Make and Model. As there are many different types, all I can give you are basic directions.
First make sure the Power Cord is UN-PLUGGED from the wall.
1. Remove the Top Vent Grille Cover. There are screws holding this on, either Three you can see (one on each side and one in the center), or Open the Door and look for screws at the top of the Frame that go Up Into the grille.
2. Look in cabinet above unit for screws that hold unit up. Usually two (one on each side, front), can be more. Remove.
3. Look where Top Vent Grille Cover was removed. There should be a Long Screw or Screw-Type Lock at each( top) corner. These hold the unit tight on the Wall-Mount Plate. Remove. You should have HELP at this point as you will slide the unit forward until it comes clear of the Support Arms.
GOOD LUCK!!
Jan 31, 2008 | Microwave Ovens
Microwave installation under cabinet, no rear wall
Hi , I would like to suggest to visit near appliance center to purchase hanging for oven . ace hardwares.
Jan 15, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
825 people viewed this question
 Grubhead
Grubhead
