Question about Toshiba Satelite A10 Notebook
On Startup, I get an error message: C:\Program Files\Camera Assistant Software for Toshiba\CEC_MAIN.exe Please reinstall program I have tried to reinstall the driver and it still does not work
    President:
  • 2,571 Answers
To stop getting the error message, type msconfig into the run/search box.
Go to the startup tab and untick the entry for the camera.
Uninstall the software, run a cleaner like CCleaner, run the registry cleaner.
Download the latest version of the software and try again .
Choose your model and OS, and download from here http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp
Posted on Oct 15, 2010
Testimonial: "Thank you very much. I did not quite use your method, but you set me on the right track."
Runtime Error! Program: C:/Program Files/Sony/VAIO Gate/VAIO Gate.exe This application has requested the runtime to terminate it in an unusual way. Please contact the applications support team for...
Hi,If you want to fix the problem you can try to reinstall the application. If you just want to disable the message you can try this:
1. Go to Start Up \ Run command and type: msconfig then press Enter. 2. Go to Windows StartUp and search the item with this string: "C:/Program Files/Sony/VAIO Gate/VAIO Gate.exe" and remove the check. Then Apply and Close.
Mar 21, 2011 | Computers & Internet
How do i take a picture on my Toshiba laptop
1. Open a program called"Camera Assistant." This is a Toshiba-supported computr program designed specifically for people with cameras built into their laptops.You can find this by clicking on the "Start" menu and then navigatingto the "Programs" sub-menu. 2. Press the"Picture" button in the "Camera Assistant" program windowto take a picture using your built-in camera. This will take one stillphotograph for every time you click the button. The image you are taking willappear on the right side of the main program window. 3. Press the"Video" button in the "Camera Asst" program window tobegin recording video using your built-in camera. This will record video untilyou press the "Stop" button. The video you are recording will appearon the right side of the main program window. 4. If you can't open"Camera Assistant," reinstall your drivers. Though the camera on aToshiba laptop is designed to work right out of the box, if it doesn't you mayneed to reinstall the driver that makes it work. Look for the CD labeled"Drivers and Software" that came packaged into the box with yourToshiba laptop. Pop it in your laptop's CD-ROM or DVD-ROM drive and install the"Digital Camera" driver contained on the disc.
Nov 11, 2010 | Toshiba Satellite A105 Notebook
I have Toshiba laptop with built in camera, but whenever i try to open the camera i recieve an error message 'CEC_Main.exe' reinstall. Kindly help how do i go about.
You also have Kasperkey ?
The error message 'CEC-MAIN.exe' is connected with the Camera Assistant Software,
You are unable to run the camera software because your KIS (Kasperkey Internet Security is blocking it by keeping "CEC-MAIN.exe" in the 'Untrusted File'.
Resolution:-
1) Launch your web browser
2) In the Notification Area (Down by your clock - Right click on the KIS icon and select "Pause Protection" > select "Resume manually"
3) In Notification Area: click on KIS icon elect "Applications under Control"
4) In the "Applications under Control" menu relocate "CEC-MAIN.exe" from the "Untrusted File" to the "Trusted File" - click "OK"
5) > Start > All Programs > CEC-MAIN icon to run your web camera program
Or My computer >> Local Disk (C) >> Program Files >> Camera Assistant Software Folder >> CEC-MAIN icon
Your webcam should now be running
Worth putting a shortcut on your Desktop at this stage .
6) With the webcam still running, then In notification Area - Right click on the KIS icon and select "Resume Protection"
7) Check the "CEC-MAIN.exe" in "Applications under Control" and confirm it is still in the "Trusted File"
8) Restart your computer
Aug 19, 2010 | Computers & Internet
Ceccmdll.dll cec-MAIN.EXE HAS STOPPED WORKING
Have you just installed a new security app such as Kaspersky?
If so you could so allow CEC_main.exe in the firewall which should cure the problem.
Sep 10, 2009 | Gateway Computers & Internet
Being asked to reinstal CEC_MAIN.exe how do i do this
The CEC_MAIN.EXE belongs to the Camera Assistant software. The file you find on C:\Program Files\Camera Assistant Software for Toshiba.
Uninstall the software then reboot, reinstall.
Regards
GeWiz.
Jun 16, 2009 | Computers & Internet
Error on startup
Clicking on it won't help, as you said 'the file is corrupted'. I would just uninstall 'Toshiba Camera Assistant' and redownload it from the internet if you need it. If you've never used it, don't worry about reinstalling it. It isn't nessisary.
Jan 30, 2009 | Toshiba Computers & Internet
Cannot install Nero 9
I had the same problem after a previous bad installation of Nero.
I solved it by completely removing that installation.
Check that these folders are deleted:
\program files\Ahead\Nero
and more important:
\program files\common files\Nero
Then clean your registry and re-install
Nov 09, 2008 | Computers & Internet
Reinstall my camera assistant software
I believe the best way to re-install that is by using the Recovery CD that came with that NB. Just insert the CD, run it inside windows & it should ask you to install applications & driver. Install the camera software and/or drivers and you should be good.
Hope this helps.
Sep 22, 2008 | Toshiba Satellite A135-S4527 Notebook
Camera not working
This works better and is within the Kaspersky help.
Fine-tuning rule settings Application Filtering rule applies to a great number of system resources and actions to be performed with them.
In order to fine-tune the application rules for actions to be performed with system resources:
  1. Open main application window
  2. In the left part of the window select System Security.
  3. Press the Application access rights link in the Application Filtering section.
  4. In the window that will open select tab Applications.
  5. Select the application in the Program column.
  6. Press the Edit link in the bottom part of the tab.
  7. In the window that will open select tab Rules.
  8. Select a resource category for which a detailed access right configuration is required using a drop-down list in the top part of the tab.
  9. Open the shortcut menu for the column containing actions to be performed with protected resources.
  10. Select the required menu access rights.
  11. Save changes.
Aug 02, 2008 | Computers & Internet
Toshiba Satelite A10 Notebook Logo
80 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
