Question about Canon PowerShot A510 Digital Camera
Lens I have a canon power shot a 510. When I turn the camera on the display as far as the start up screen is fine but the screen is black when you try and take a picture. The lcd screen is fine, if you put a memory card in you can view all the pictures on it. It will not take any new pictures.
  • 1 more comment
  • Anonymous Aug 05, 2008
    i only get my start up screen on my a510 it will not do anything else
  • gstefun Nov 08, 2008
    My A510 will no longer display a preview or take a picture. Support will not cover this under warranty. My camera is only 3 years old!
  • Anonymous Mar 11, 2009
    My Powershot A510 is just 3 years old. Some months ago the lcd would remain black for a while and pictures i took would be just black (i thought it might just be an lcd issue, not a lens issue). It would eventually fix itself after being on for a few minutes. Now it doesn't come back at all.
    I am pretty sure it is the CCD image sensor, although i can't be totally certain. Canon recalled a bunch of camera models with this very problem, but sadly the A510 is not included. Here is the link:
    http://www.usa.canon.com/consumer/contro...
    I was hoping someone was able to fix it and post a fix-it here.
    Problem Solver:
  • 7 Answers
You might have switched off the display by mistake, which is used as a power saving option and can be switched on by pressing the display button.
Posted on Jun 20, 2008
No image is captured by the screen itself (LCD screen works but completely dark).
Did you try pressing the display button several times? in both viewing mode and record mode? Cycle through all display modes, s you get used to the button, so it does not trow you off when it happens again.
Feb 16, 2015 | Canon Cameras
Canon power shot A1000IS displays only black screen
Turn on the camera and press the DISP button 2 -3 times and see the result.
Aug 09, 2012 | Canon Powershot A1000IS Digital Camera
Black screen on canon a 550
Sounds like you accidentally pressed the DISP or DISPLAY button on the back of your camera. This manually turns the screen on or off to save batteries. You would then use the optical viewfinder, just like you've been doing. To turn the screen back on, press the button once more.
Oct 11, 2009 | Canon PowerShot A550 Digital Camera
Canon A630 lens error and black photos
hi u need to get the lens repaired the railing in the lessystem is no correct so pleas dont try to doit or push in .... it will be permanent damage ....get to the shot5 the camera is not broken need small fix....
Aug 30, 2009 | Canon PowerShot A630 Digital Camera
Y Canon Power Shot SD400 digital Elph camera won't shut down
Your problem in your lens...Try to bring service center. Cause, canon lens it for me it not easy to disassembe dan assemble it again...Different with other camera lens, like KODAK and Samsung.
At sony camera "E18" can be "Turn the power off and On again" like my Sony W.35
Aug 22, 2009 | Canon PowerShot S400 / IXUS 400 Digital...
CANON POWER SHOT SD750 DOESNT TAKE PICTURES BLACK SCREEN
Mine started working again. The only thing I can attribute to it is that I zoomed the lens in and out several times. The next time I turned it on, it worked. Go figure. I'll update if things change.
Dec 03, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Canon Power Shot S1 IS
canon has a recall on this camera. call them and they will send you a box to send it back. If you are one of the lucky ones the will send you a canon s5is back...really nice camera
Oct 29, 2008 | Canon Power-shot S1 IS Lens Converter
Canon Power Shot A710 is
The hand with parenthesis is your image stabilization. It sounds like if your images are turning out black, you may need service.
Try hitting your display button a few times and see if anything shows up on the screen.
May 29, 2008 | Canon PowerShot A710 IS Digital Camera
Canon SD1000 display is black while the camera in shot mode
After some inspecting of the camera it seen the issue lies with the lens, not the camera itself so don't go banging the camera up or you might damage some other part and the camera will be broken for real. Inside the lens is a closer which block the internal system from capturing image. The closer look just like the one you see before turning on your camera but it's smaller and it's inside the lens way in the far back. Look carefully and you'll see it - you will see the closer if your screen is black while in capture mode otherwise you will see a nice round glass (the internal lens for capturing image/video).
Think of if like this, imagine an eyeball with its eyelid close. That's what happened when the screen is black while in capturing mode.
HOW TO FIX IT: In order to fix the black screen while in capture mode and cost as little damage to your camera as possible, simply turn on the camera in either picture or video mode and look inside your lens, there should be a closer in the far back end. Gently hit the lens a few times until you don't see the closer no more and only a round glass and your camera should begins capturing image and video again.
Good luck to you all. And remember don't use anger to force your camera to works or you will regret it.
If you need further help, contact me via email y a j y e e (at) h o t m a i l (dot) com
Yee Yang
Canon PowerShot SD1000
May 13, 2008 | Canon PowerShot SD1000 Digital Camera
Canon Power Shot Pro1 will not turn on
A new camera will fix problem perfectly. LOL Did you drop it? Seem like there might be a short or something similar. Had U ever play the game "Operation"? This camera need it, of cause done by the pro. LOL
Sep 09, 2006 | Canon PowerShot Pro1 Digital Camera
Canon PowerShot A510 Digital Camera Logo
176 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
