Question about Refrigerators
Condensation is forming the freezer compartment of our refrigerator and freezing in the bottim of the freezer. I have cleaned the coils, etc and cleand out the freezer to a mimium of food. Whynis the condensation forming?? jwacker42
    Genius:
  • 1,478 Answers
Before you delve into any electrical appliance and especially something like a refrigerator, it is extremely important to switch off the refrigerator and unplug it from the power source. If you are skeptical about your food going bad, there is no need to be worried, because it would not be the case. Even if the refrigerator is switched off, the cooling which has already happened will keep the food from spoiling. After you have switched off the power of your refrigerator, you would find a grill like cover panel at the bottom front part. Unscrew or remove this panel by snapping it off, you can do either depending on its setting. Then find a plug point for your vacuum cleaner as you are soon going to need it.
You have already set the vacuum cleaner, so just turn it on. Use the attachment of the wand and nozzle, your condenser cleaning equipment for cleaning out all the dirt and grime collected beneath the refrigerator. Get rid of as much dust as you can from the condenser. The nozzle attachment will be more helpful in cleaning the coils. Once you are done with the coils, check out the cover plate which would also be dirty. Clean out the grills from that cover plate. Hot bleach water will do wonders to clean the plate. Before you re-install the cover plate let it dry.
Take care.
Posted on Oct 15, 2010
Kelvinator fridge compressor running constantly, but freezer section barely freezing
CHECK THE CONDENSER COILS UNDER THE UNIT. THEY PROBABLY ARE DIRTY AND CANT REJECT THE HEAT.
Oct 18, 2012 | Kelvinator Refrigerators
An old kelvanator freezes in the refrigerator compartment
Normally in most situations if you are getting ice forming on the coils, and I mean ice, not frost, on either coil, be it freezer or fridge chances are you have a refrigerant problem. A good indication of this would be to expose the coils and see if the ice is localized, or more so concentrated in one portion of the coils, i.e. upper right corner, etc. Going further into the problem, the two things that would cause this is (1) a restriction in the line, (2) low pressure in the lines which is because of a leak or weak compressor. To really diagnose this problem accurately you need a set of refrigerant gauges and tap into the low side line of the sealed system.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Apr 20, 2012 | Refrigerators
Cooling but not freezing.... melting in freezer compartment
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 08, 2011 | Frigidaire Refrigerators
Freezer is not freezing some items and not freezing some. Ice Cream is not freezirng, sausage & hotdogs are not freezing. Ham is not freezing, etc. There is no food blocking vents. I tried to...
Hi, The freezer is not staying cold enough...ice cream takes colder temps...
heatman101
Aug 02, 2011 | Whirlpool Refrigerators
Refrigerator is not working but freeze is. Top compartment warn
heatman101
May 21, 2011 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerator & freezer compartments @ 64 & 24 degrees F. respectively.condenser coil clean, however, "clean condenser coil" appears on display even after being reset. circuit board...
heatman101
Apr 16, 2011 | Sub-Zero 650 / O Bottom Freezer...
Model # FRT18IL6DWP Moisture droplets on top of freezer - not freezing at normal setting - turn to coldest setting and freezes but moisture droplets still forming but freezing - model is 4 years old Model...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Dec 27, 2010 | Frigidaire FRT22TSE
My Frigidaire Mod. # FRS6R5ESB0 P/N 218888702 side by side the freezer is cold close to freeze but not freezing, what can I doo, I already clean the coil condenser and the entire back compartment. Thank...
Refrigerator
heatman101
Dec 25, 2010 | Frigidaire FRS3R5EMB Side by Side...
MY FREEZE DOES NOT FREEZ BUT IS COOLD DOES IT NEEDS GAS
When the compressor is running, two fans should be running. One inside the freezer compartment that moves air over the evaporator coils. The other is under/behind the fridge that cools the condenser coils.
If the fan on the condenser coil (the one under/behind the fridge) stops working, the system cannot dissipate the heat from those coils, and thus cannot sufficiently cool the inside of either the freezer nor fresh food compartment.
On mine, when the condenser fan failed, I noticed right away. The front face of the wall separating the compartments became very hot. Extremely hot.
Apparently the refrigeration system is designed so that waste heat keeps condensation from forming where the magnetic gaskets on the door need to seal. When the condenser fan failed, there was too much waste heat (because no heat was being dissipated from the condenser coils by the fan), thus making that gasket-sealing area very hot.
If it is your condenser coil fan, you can relieve the problem temporarily by removing the bottom back panel from the fridge and aiming a box fan (a regular room or window fan) at the condenser coils. This will circulate air over the coils, thus removing heat from the coils.
Jul 29, 2009 | GE GSH25JFR Side by Side Refrigerator
The freezer has ice build up on vents
Cooling is poor For an overall understanding of how refrigerators should work, read about refrigerators in the How Things Work section of our website. A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas:
Evaporator coils
Condenser
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
  • The defrost timer
  • The defrost thermostat (also called the bi-metal switch)
  • The defrost heater
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Condenser Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush (see the Appliance Accessories section) and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
also click the links below for more help
It's stopped completely
It's not cool
Cooling is poor
It's noisy
It leaks
The freezer compartment is icing up
The food in the refrigerator freezes
There's water dripping inside the refrigerator
The refrigerator never cycles off
The ice maker has a problem
There's an ice- or water-dispensing problem
Dec 06, 2008 | Kenmore 53642 / 53644 Side by Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
