Question about Toshiba 32AF41 32" TV
Rca jacks loose
I have toshiba 32af41 . The jacks on the front are loose.I would like to tighten them. How to?
  • 89 Answers
You may have open the set to reach the rca jack connections. Most probable cause would be loose solder connections. You should do this only if you have experience in electronics, esp. TV circuit boards, otherwise, I would take the set to a service center.
Posted on Jun 03, 2008
After being moved, tv has no color
PROBABLY LOOSE CONNECTIONS FROM THE MOVE. THERE ARE MANY REASONS THESE NTSC TV'S LOOSE COLOR
Dec 28, 2009 | Toshiba 32AF41 32" TV
How do u take of the spring in the back
Block the front wheels, Raise the back end axle included intil tires are a couple inches off the ground. and support the body with jack stands. Then remove the spring u-bolt nuts. Now let the jack down and tap the u-bolt lower plate until they break loose drom the lowering of the axle weight. Remove u- bolts. now take the shackle end loose (back end of spting) then the frony spring end Keep in mind the vwhicle ia on stands, so don't **** and pull on anything. Do not use your pinky to line up holes on assembly. Screwdriver or centering punch. Lube all fasteners so you don't have squeeks.When tightening u-bolts alternate between the front and rear nut to pull u-boltdown evenly Tap on the u- bolt while tightening to keep the bolt centered vertically or it will creak and crunch. With all assembled, Drive the vehicle around making leftt and right turs and through a few dips. Reck u-noltnuts again and tighten if needed. If the u-bolts are not vertically straight yhey will come loose. Just tap them back and forthand they wiull find their own center@ the Loosest point. Good Luck and be ever aware of the vehicle and jack stand stability. _Ned_
Nov 02, 2009 | 2000 Isuzu Rodeo
A.c.adapter and mother board
its a problem with the dc jack in the laptop, thats where the charger plugs into.
The solder joints are loose to the jack and need to be resoldered. It will tighten the connection of the jack to the motherboard so that way you can plug in the ac adaptor and not have to hold it in.
An electronics shop can do this or if you have some soldering experience you can do it.
Ben
May 23, 2009 | Toshiba (K000002020) Motherboard
My rca tv not working
the lamp which you rteplaced is not seated properly.and also it can be the problem of colour wheel or the ballast.to check out all three just check out this links 1 by 1 for colour wheel with diagram and procedure
http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/
for lamp in 5 minutes with diagram and procedure
http://www.jangro.com/a/2006/08/03/how-to-change-your-samsung-dlp-lamp-in-5-minutes
for ballast with diagram and procedure
http://www.consumermeet.com/entry/samsung-dlp-ballast.html
Feb 09, 2009 | Toshiba 32AF41 32" TV
TV Stand for Toshiba 32HFX71
Amazon.
Toshiba TV Stand 62HM196
Jan 20, 2009 | Toshiba 32AF41 32" TV
Remote control not response from tv
Solder connects IR detector front of chassis,if that does not
do it, replace detector...............................T.
Nov 10, 2007 | Toshiba 32AF41 32" TV
Sony KV- 32V35 Front Jacks
Yes, the front RCA jacks on the Sony sets always seem to crack loose. I have seen that many, many times. To get to those jacks, you will have to remove the back of the TV and carefully pull out the main chassis, taking care not to pull out any wires or jacks. When the main chassis slides back, there is a smaller board in front of the main board, and the pushbuttons and RCA jacks are on that smaller board. The connectors to that board usually come off when you slide the main chassis back, so you will need to put those jacks back in place when reassembling. Slide the smaller board back, flip it over and resolder the connections on the RCA jacks. Sometimes I find that the copper trace to the center pin of the video (yellow) RCA jack is broken, so test for continuity and solder a small jumper wire to take the place of the cracked copper trace if necessary. Reassembnle the set and your jacks should be working fine.
Aug 31, 2007 | Sony KV-32V35 TV
Toshiba 32AF41 Power up Problem and Green Screen
My first inclination would be to check the picture tube, especially if the set is over 7 years old. If it is not that, then anything from bad solder connections to capacitors or a defective IC could be the cause. If it's over 10 years old, replace it. No use flogging a dead horse.
Jan 13, 2007 | Toshiba 32AF41 32" TV
Red lines across screen
it sounds like a b+ cap going bad and is intermittant that feeds the the video drivers on the crt pcb or the crt is shorting. I have seen intermittant shorts in crt before.
Mar 27, 2006 | Toshiba 32AF41 32" TV
Toshiba 32AF41 32" TV Logo
137 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
