Question about Toro 15" Electric Trimmer&Edger
Trimmer bogs down when giving it gas and then dies
I have a poulan pro link 33cc sting trimmer it runs for a while then it dies or I give it it wants to die out an bog down anyone know what to do
Fuel filter!
They are located in the gas tank.
Use a hook to grab the fuel line/tubing, there will be enough tubing to pull the filter out of the tank. Filter will be on end of tubing.
Replace it. Hope that helps you out.
Good luck.
look here...
May 19, 2015 | Poulan Garden
Why does my mini tiller start then bog down and die as soon as i give it any throttle
Sounds like your carburetor is dirty and not letting enough gas get it to run. Also is there a screw on the carb to set the gas flow ? If there is turn it to the left to let more gas flow.
May 18, 2015 | Garden
Why wont my trimmer take gas after it starts ?
Open, turn ccw, the high 'H' speed jet screw about .3 of a turn while holding the throttle wide open at the trigger. Engine should increase spread andyou may have to adjust. Failing that and assuming correct oil/gas mix it will likely be carburetion, clogged fuel filter or bad fuel line.
May 02, 2014 | Husqvarna 128LD 17" Gas Trimmer
Why does my craftsman 2-cycle model 316.791860. Gas trimmer die?
Those little carbs clog very easily and what you experience is a common symptom. Go to any bog box home store and in the mower area pick up a can of small engine carb cleaner.
Remove the carb, take it apart as far as you comfortably can and soak all pieces in a can/jar of CLEAN gasoline for 10 -15 mins. Agitate to get the gas moving.
Remove the carb, and drip clean then use the carb cleaner to blow out every port you can see. reassemble and install the carb, it should work fine.
Before storing for the winter drain all gas from the tank and start it allowing the machine to run till it stalls out due to no gas. You should be fine for next season that way.
Apr 27, 2014 | Craftsman Convertible 25cc. Gas Line...
Ryobi weed eater stalls when giving it gas
check air filter and spark plug if good carb adjustment is needed or carb may be loose. could be bad fuel water in gas will cause this
Aug 26, 2012 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
My 7-year old 25cc Craftsman line trimmer began surging during use, would bog down when given throttle, then would completely die, became hard-starting, and now doesn't start and run at all. Acts like...
A new fuel filter with new fuel lines and a rebuild kit for the carburetor should do it. You may even be able to get away with just the gasket and diaphragm kit for the carburetor. It is cheaper than the complete rebuild kit if you choose. Run synthetic oil and these things will last a good long while.
May 14, 2011 | Craftsman 25cc Gas Line Trimmer
I have a Shindiawa T-27 weedeater.Everytime i give it gas,it stalls.Idles fine but stalls as soon as you hit the gas.i put clean gas a new plug in it no good.
Depending on how old this unit is, you should be able to adjust the hi/lo speed needles on the carb. If it is so new that they have a strange head rather than a screwdrive slot, you will have to experiment to find something that will turn them. Sounds like you are not getting fuel when you open the throttle. Other than that, probably a carb cleaning would be in order.
When turning the fuel needle, you just want to turn it about 1/4 turn then try to give it the gas. You are going to be turning it out, or counter clock wise. Once you get it so that the engine will rev, try giving it fuel 2 or 3 times very fast. If it bogs down or acts like it is going to die, adjust the needle a bit more.
Oct 21, 2009 | Husqvarna 28cc Gas Line Trimmer
Ryobi BC 30 trimmer bogs down with throttle
some have to warm up, although there should be a gas/oil mix screw on the carb try adjusting it
May 07, 2009 | Ryobi Garden
The trimmer will not run when i give it gas
When 2 cycle engines preform as you have stated...the main problem is a carbon build up on the spark arresting screen on the muffler, it needs to be cleaned or replaced with a new one
Apr 04, 2009 | Garden
Toro 15" Electric Trimmer&Edger Logo
139 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
