Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
Hi, i have never scanned a document but i need to, how do i do it please
    President:
  • 2,571 Answers
You open the scan lid, put the document in, close the lid.
You should have a shortcut to the scanner on your desktop, or it may be in start / programs / epson.
Your scan software should start up, do a preview of the document, if you like the result, you can do the full scan.
You can change the quality of the scan and the directory where the scan is saved to in the settings.
If you are still unsure, download your manual from epson support
Posted on Oct 15, 2010
Scanner does not scan MX890
you need to Reinstall the scan drivers, It will fix the issue
Regards,
Sean
Jan 22, 2013 | Canon PIXMA Office Equipment & Supplies
Photosmart C5180
Hi
1. Double Click on HP director to start it up. Look for "HP Director" on your desktop (the screen in front of you). It is usually an icon that materializes after you install your printer. (It may look slightly different with different models.
2. Scan the document by clicking "Scan."
3. Select "Save to File." (You can set up a folder ahead of time so you know where to find the document or photos once they are scanned). Often times the computermag-glass_10x10.gif will create a default "scanned documents" folder and organize them by saving them on the date scanned.
4.Click scan and then wait for box to appear.
5.
The software will prompt you to save the file. Put it in the folder you created (you can see the path/folder). Give it a name you will remember.
6.
Then click "Save"to finalize it. The document should be in the folder that you designated.
Hope this helps
Aug 07, 2008 | HP Photosmart C5180 InkJet Printer
How do i scan a document?
Visit to the given link and download the manual. The detail procedure is given in the manual... http://www.retrevo.com/support/HP-J4580-Multifunction-Printers-manual/id/20067ag014/t/2/
Hope this has helped you.. Please rate the answer.. Thanks...
Jun 25, 2010 | HP OfficeJet J4580 All-In-One Laser...
Hi I can scan documents when I click on control panel/scanner...all documents scan to picasso. When I press the scan button on printer I want to be able to have documents scanned to word. Please advise
You need to get the HP Scangear manager. or use Scan to word or scantoPDF software download from 'net, if you have installed it correctly, you go to Word go to INSERT, go to INSERT Picture, Image, and select scanner and scan. OR scan to clipboard and paste into Word.
First make sure you have installed ALL the HP software.
Get Vuescan, it's a great standalone program, that doesn't require a driver, and just works. There are other scanning softwares too Google for them
Apr 01, 2010 | HP PSC 1350 All-In-One Thermal Printer
I can't scan documents into my computer. I need this done ASAP. I'm using a HP 950 printer/scanner/fax/copier. I don't know why it will not scan. Please help.
Try using the HP Solution Center Icon instead of using the button on the printer itself. If you already are doing that then check in My Scans in the My Documents section. Should list as " SCAN001" or something similar.
Hope this Helps,
RSMITH972278
P.S. PLEASE RATE MY ASSISTANCE
Dec 09, 2009 | HP PSC 950 All-In-One InkJet Printer
Need to scan - unable to on my HP officejet 5610xi All-in-One
open control panel -> go to scanners and cameras -> start the hp officejet 5610xi -> then it should start enjoi :)
Jan 20, 2009 | HP Officejet 5610 All-In-One InkJet...
Scanning
by default it is save in my picture but when we scan then from brouse we can select the location from the brouse options
Jun 27, 2008 | HP Photosmart C6180 All-In-One InkJet...
Cannot edit scanned document
its like this, the OCR or the SOftware installed in your computer is limited. If you're trying to scan a document which has a picture or with text that uses different fonts like monotype, or those that are not usually being use for normal documents, usually it wouldnt detect and it become distorted. Anyways, here are the steps that i want you to follow.
1. Open solution center. (click start, go to all programs, go to HP, then click on SOLUTION CENTER). or you can see SOlution Center on your Desktop.
2. Click on Scan Documents, then the Scan documents setting will open. Change the settings to these.
* SCAN TO: Microsoft Word.
3. Then, hit scan.
4. After scanning, the folder My Scans will open automatically, just go ahead and open the scanned document.
5. From there, you can start editing the text.
..remember, the scan a document is limited, it will not read all types of fonts. if the document is using a "times new roman" or "arial" the scanned document appears to be almost the same with the original. But, if the scanned document contains pictures or stylish fonts, that would make the document distorted.
Please let me know if you still have clarifications.
Thank you.
adonscott
May 01, 2008 | HP Officejet 5610 All-In-One InkJet...
HP PSC 1410
Hi ,
Please follow the below procedure to scan a document.
  1. Connect the scanner to the computer
  2. Install the software with the help of CD which you get from hardware manufacturer
  3. Open the Lid of scanner, Place the document you want to scan
  4. Close the Lid after placing document
  5. Open HP software which you have installed above, click scan now ( or any thing similar )
  6. Scanner will start scanning you can hear the sound and strong light rays passing through the document
  7. After this it creates a soft copy
  8. Save the file , by default is get saved in my documents you can save any where else if you want
  9. For better results veiw soft copy in PDF that is acrobat reader.
Hope this answers your post, Please let me know by providing your valuable feed back
Thanks,
Robosoft
Dec 24, 2007 | HP PSC 1410 All-In-One InkJet Printer
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
60 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
