Question about Bunn Coffee Makers & Espresso Machines
How to clean??
I have a Bunn "Single" industrial coffee maker. The Product # is 23050.0007. (It is not a single serve maker, just called SIngle for some reason.)
I would love to be able to clean out the insides mechanism that is connected to a water line to make the coffee but don't know how. We also have coffee burnt to the bottom of the metal container and would love to get it all off.
Any help would be much appreciated.
  • 625 Answers
You'll need a phillips screwdriver and a small crescent wrench. start by unplugging the unit. unscrew the sprayhead. remove the small hexnut from the sprayhead tube. remove the two screws from the top cover and lift up the cover. if there is a warmer element on it, remove and mark the two wires to the element. use the back end of the crescent wrench and unscrew the brass nut in the reservoir. save the fiber gasket from under the tray. the pot holds two complete potfuls of water so be careful. mark all the wires and where they go and remove them one at a time from the top of the canister. remove all the screws or nuts that hold the top to the canister and remove the top. the thermostat bulb goes into one of the plastic bushings along with rubber packing washers in the top. unscrew the plastic bushing, the packings and the thermostat bulb. pour out all the water from the canister. there's a dip tube that goes to the bottom and is fastened to the water inlet pipe on the top part. this may have some scale build up on it. scrape off this deposit. in the bottom of the canister you will find a mineral scale which must be removed. a small sharp chisel without the use of a hammer can be used to remove this scale. while you have the machine apart, use the long steel spring to clean out the water tube that goes to the sprayhead.
Posted on Jun 05, 2008
I have a cup o matic and it has recently started leaking from the main unit...???? Can I fix it?
you can if you can find where the leak is, and as long as it is just a worn o-ring and not a crack. You could contact Cuisinart for service? There are some articles on your particular problem in the main link at the bottom.
Pt 1: How To Use: Cuisinart SS-1 Cup-O-Matic Coffee Maker - YouTube
? 10:04
https://www.youtube.com/watch?v=jEPf5hXWkB4
Oct 18, 2007 - Uploaded by Jay Brewer
Learn how to use coffee pods and ground coffee with the Cuisinart SS-1 Cup-O-Matic Coffee Maker.
SS-1 - Coffee Makers - Discontinued - Cuisinart.com
https://www.cuisinart.com/discontinued/coffee_makers/ss-1/ Regular or bold, large or small - your ideal cup should never be compromised. Now with the Cuisinart® Cup-O-Matic™ Coffeemaker, it's easy to brew your cup ...
[PDF]Cup-O-Matic™ Coffeemaker SS-1 - Cuisinart
https://www.cuisinart.com/share/pdf/manuals/ss-1.pdf Cup-O-Matic™ Coffeemaker. SS-1. For your safety and continued enjoyment of this product, always read the instruction book carefully before using.
Amazon.com: Customer reviews: Cuisinart SS-1 Cup-O-Matic Single ...
https://www.amazon.com/Cuisinart-SS-1-Matic-Coffeemaker.../B000RIAIXO Find helpful customer reviews and review ratings for Cuisinart SS-1 Cup-O-Matic Single Serve Coffeemaker, Black and Brushed Chrome at Amazon.com.
Cuisinart® Cup-O-Matic™ Single Serve Coffee Maker - Bed Bath ...
www.bedbathandbeyond.ca/store/product/cuisinart-reg-cup-o-matic.../1014760199 Regular or bold, large or small, your ideal cup should never be compromised. Now with the Cuisinart® Cup-O-Matic™ Coffee Maker, it's easy to brew your cup ...
Cuisinart Cup-O-Matic Single Serve Coffeemaker Review
www.goodhousekeeping.com/.../cuisinart-cup-o-matic-single-serve-coffeemaker-881/ Rating: 2 - ‎1 review
Unlike coffeemakers that only make a cup at a time, this model can be used with your favorite ground coffee as well as from coffee pods.
Single Serve Coffee Forums
cup matic leaking water Google Search
Sep 03, 2017 | Coffee Makers & Espresso Machines
It will not make coffee in either the Keurig pods or regular ground coffee. It says PURGE, or NEEDLE after I clean it and use paper clip to remove grounds. What else can I do?
Customer Reviews: Hamilton Beach 49995 FlexBrew Single ...
www.amazon.com/Hamilton-Beach...FlexBrew.../B00...
Amazon.com, Inc.All in all, the Hamilton Beach FlexBrew Single-Serve Coffeemaker is an ... exhibit the same exact problems using the K-Cups recommended by Hamilton Beach.
Hamilton Beach FlexBrew Troubleshooting Common ...
? 3:39
https://www.youtube.com/watch?v=yA2dlGKUBKM
Sep 7, 2015 - Uploaded by Ronald Kretz
Hamilton Beach FlexBrew Troubleshooting Common Problemmust see if you ... Hamilton Beach Single ...
Customer Reviews: Hamilton Beach FlexBrew Single-Serve ...
https://www.walmart.com/reviews/product/21130276
WalmartProblem the model I purchased was the only one they made that uses K Cup. ... MyHamilton Beach FlexBrew Single-Serve Coffeemaker was truly a wonderful ...
FlexBrew® Single-Serve Coffee Maker (49995R) - Hamilton ...
https://www.hamiltonbeach.com/all-coffee-maker...
Hamilton Beach BrandsThe FlexBrew® Single-Serve Coffeemaker allows the flexibility of brewing freshly ...Not sure how much coffee grinds to add when brewing your next cup? ... and thenrunning 2-3 cycles of cold tap water before making the next round of coffee. ... 2016Hamilton Beach Brands, Inc. Trademarks by Hamilton Beach Brands, Inc.
Hamilton Beach FlexBrew 49995 - Consumer Reports Online
Jan 05, 2016 | Hamilton Beach 49995 FlexBrew Single Serve...
How do I fix water leak in Cuisinart ss700 coffee maker
if Cuisinart is like my bunn they do not have parts to fix , it is throw away and buy new .
Oct 12, 2015 | Cuisinart SS700 SINGLE SERVE BREWING...
WHY HAS MY CAFE STOPPED WORKING? IT DOESNT DRIP COFFEE INTO CUP.
Sounds like your machine is congested. Consider cleaning out the nozzle or the filter.
Sep 22, 2014 | Bunn Commercial Bunn My Cafe Pourover...
Why won't my coffee single serve brew after cleaning?
You could try what this guy did with his http://www.youtube.com/watch?v=BWP_vn4uHew
Aug 07, 2014 | Mr. Coffee Coffee Makers & Espresso...
BUNN MY CAFE BAD TAST WITH COFFE OR HOT COCO
Try really cleaning the basket that the water and coffee or cocao goes into. If you don't really clean it well, it will have the taste of the last thing brewed mixed in with the new brew. Coffee followed by coffee should not be a problem, but coffee followed by cocao will give the cocao a coffee taste, and visa versa.
Nov 21, 2013 | Bunn My Cafe MCU Universal 4-in-1 Single...
Cleaning the thermos on the BUNN single TF DBC
For the thermos you can use a small amount of purocaff and fill the thermos with hot water, let sit over night then rinse with cold water a few times to clean you can also use a soft brush to clean while the purocaff is in thermos. Clean around the showerhead with a clean towel, or you can use a filter with a little purocaff and brew into thermos and clean both in one shot.
Mar 23, 2009 | Bunn BREWWISE Single TF DBC Coffee Maker
Bunn Coffee maker leaking out of the bottom of the coffee maker when the coffee maker is not making coffee.
that needs to go back to bunn for a replacement tank, they will likely only charge you for return shipping
Dec 10, 2008 | Bunn NHB Coffee Maker
Bunn VPR Coffee Maker
I own a bunn and my brother's business owns 2 of these. The rule of thumb as he was told by the salesman is 2 oz of coffee grinds per 48 oz of water.
Jan 23, 2008 | Bunn VPR Coffee Maker
Coffee Makers & Espresso Machines Logo
202 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
gbob59
zimcloud
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
