Question about Roper REX4634KQ Electric Dryer
Dryer want heat up? Fuses checked, ok. - Roper REX4634KQ Electric Dryer
  • Roper Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Jan 15, 2011
Replaced all parts for dryer because of no heat dryer runs drum turns had breaker and wiring going into dryer everything ok still no heat could wires be backwards going to replacement parts?
Electric dryers have as many as three thermal fuses. See if you might have missed one. One next to coils, one next to drum and one near the lint trap at air outlet. All three have different trip settings.
Jan 04, 2016 | Dryers
2005 Whirlpool Gas Dryer. It won't heat. The coils won't glow. Had the fuses, ignitor, and coils checked and are ok. Could it be the timer? How do I check it?o
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101-
Jul 22, 2011 | Whirlpool LGQ9858P Gas Dryer
There is no heat in my dryer, i got the fuses check and they are ok.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 09, 2010 | Samsung DV218AEW Electric Dryer
Dryer will not run...checked fuses ok.....240v ok....what else could it be?
if it won't turn or anything its probably the neutral wire on the terminal block in the rear of the unit,they carry a high amount of current and can get brittle and break off or burn off in time check the incoming power connections first,if it turns but doesn't heat,then it may be your thermal fuse located in the vent duct housing inside the dryer if this opens you will not get any heat from either a gas or electrically heated dryer
May 18, 2010 | Dryers
Maytag Dryer model number PYE2300AYW will not start.
check your fuses in the dryer their is only one fuse that could shut down the whole dryer like that. Open back panel and get a volt meter and check for continuity on the fuses. HOW? first un plug it then open back then you will see the heating element their are 2 fuses on the heating element take off wires and check those.Then if those are ok look down thier is another fuses its long white with 2 wires comming out of it with a black center that should be your problem check it repair it run it . GOOD LUCK
Oct 12, 2009 | Maytag Dryers
Dryer will run in cool down mode,but not in any other.
Hi!
Please check the following---
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Please accept this solution and ask for any clarification.
Thanks
Rylee
Mar 22, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
There is no heat
Disconnect power and access your dryer fuses. Check and test your fuses for "continuity". Most likely, a white thermal fuse. Can possibly be your ignitor or heat element as well. Is your dryer gas or electric?
Jan 27, 2009 | Hoover Dryers
Runs, but no heat
First of all if you have fuses check for one of the fuses being open, if circuit breakers be sure they are ok. Next check for 240 volts to the heating element, if you have that and no heat replace the heater
Jan 04, 2009 | Whirlpool LGV4634JQ Gas Dryer
Kenmore Dryer
If the motor can run, check the fuses in the house's panel. Electric dryers run on two phases of the 220-240 volts outlet; the motor on one phase, the heating coil on both phases. One of the two fuses may be burned out.
REMOVE the fuses before touching any component inside the dryer's housing.
If the fuses are OK, check if the the switch resting on the motor itself, has not burned terminal or wires.
Check if the heating coil is opened (burned)
Nov 07, 2007 | Kenmore 63942 Dryer
Roper REX4634KQ Electric Dryer Logo
49 people viewed this question
Top Roper Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Roper Dryer Expert? Answer questions, earn points and help others
