Question about Philips Televison & Video
Magnavox color tv model no 20MT4405/17 vertical shrinking
    Top Expert:
  • Philips Master
  • 74,136 Answers
Hello
Vertical shrinking means lack of height we thinks. If there is a height problem for philips tv, surely some of the philips electrolytic capacitors should be replaced. Most of the electrolytic capacitors made by philips shows either a slight leak or lack in capacity after some years or days after use. When replacing them make sure to select other brands of same capacity and voltage ratings. If this doesn't help, get into the service mode of that tv and adjust "VH" and "VLI" functions, if you knows the service mode code. If you don't know it, please get assistance of a technician.
Posted on Oct 16, 2010
Phillips magnavox P960349102 model#PTV835
If its shrinking this is and easy fix...Goto the site www.TvRepairKits.com and get there shrinking video kit for your model.
As for the colors they are likely just washed out which is due to the CRT coolant. The same site has repalcement CRT fluid for your projection TV also.
Feb 09, 2013 | Philips Magnavox 9P6034C 60" Rear...
Picture shrinks , pulseates, color off until warms up
This is a very common problems with this model. Goto www.TvRepairKits.com and get there shrinking and expanding kit for your philip magnavox model.
Apr 05, 2010 | Philips Magnavox 9P6034C 60" Rear...
Magnavox 55 rear projection has no power
This is a common problem. You can get parts and instructions from www.TvRepairKits.com . Find your model on their site and get the shrinking and expanding kit.
Mar 20, 2010 | Philips Magnavox 9P6034C 60" Rear...
Regular picture size shrinks and color fades
This is a common problem on certain models of Philips Magnavox TV sets. The most common symptom is the screen will shrink and expand over and over. After the TV heats up for a while the video will work like normal. After a few weeks or months your TV will eventually stop working and not have video. You can get complete parts and instructions from www.TvRepairKits.com
Jan 01, 2010 | Philips Magnavox 9P6034C 60" Rear...
Picuture shrinking color fading
I have the same Tv.. Repair tech said it was the deflection board. Cost $395.00 to repair.
Feb 28, 2009 | Philips Magnavox 9P6034C 60" Rear...
Picture from 60" to 19" then gone.
The fluid is a fairly easy replacement. They just need to remove the CRT with the bad fluid and drain the old fluid and clean the CRT and then replace the fluid. The Shrinking is just a Vertical Deflection problem which is also an easy repair. A new Vertical IC and a couple Capacitors. In my shop it would run @ $200.00 to fix both.
Dec 19, 2008 | Philips Magnavox 9P6034C 60" Rear...
Phillips Projection TV - Model 9P5511C
Common problem with the model. Check the site www.TvRepairKits.com. They have a fix for the shrinking and expanding screen problem.
Sep 07, 2008 | Philips Magnavox 9P6034C 60" Rear...
NO PICTURE HAS SOUND
When you say small do you mean shrunk up top and bottom as well as from side to side. You definitely have a deflection problem either horizontal or vertical.If the picture just shrunk top and bottom you have a vertical deflection problem. Do you have the service manual for your model? If not let me know and I will email you one. Describe the shrinking issue a little more and I should be able to give you some guidance.
Feb 06, 2008 | Philips Magnavox 9P6034C 60" Rear...
Zenith console tv model sentry 2 27 inch
Resolder the vertical deflection section. Change pump up capacitor if it has one...100uf is a typical value. Is the vertical output some flavor of LA783x ?? May need to replace. A model # would help.
Nov 04, 2007 | Televison & Video
Televison & Video Logo
166 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
