I am looking for a manual for a kenmore 867.765240 furnace
Honeywell manuals
Turn the fan in the ON position to verify you have power to the furnace. If the fan turns on, turn it back to AUTO. Pull the thermostat off the wall to get to the low voltage wiring. If you have a gas furnace, pull the red & white wires off and pinch them together. If the furnace starts, the thermostat is bad. If it doesn't start, then begin looking for flame roll out switches in the furnace burner compartment to manually reset. If the furnace inducer (combustion motor starts, & you get no flame, then it is either an ignition problem, or someone didn't pay their gas bill. :0
Dec 11, 2013 | Honeywell Programmable Thermostat Heater
Heil furnace electronic ignition module red light flashes
the flash codes are usually on the control box or the back of the furnace door
Jan 02, 2013 | Heating & Cooling
Heater not working properly we put on heat it comes up cooler what I have 2 do
This worked for me try and reset your furnace while you're at it change the filter never hurts a furnace in need. My furnace has a switch on/off like a light switch externally however some don't if you have an older furnace you may have to manually light your furnace it would help if you listed your furnace model number. Try and find your furnace owners manual if you don't have it look online or contact company who build it. Also some states in the us don't run gas to homes until a certain time of year. I live in Northern Minnesota so its year round here just wondering if this also could be an issue.
Oct 17, 2012 | Heating & Cooling
Furnace manual huppert
http://homeappliance.manualsonline.com/manuals/device/furnace.html
furnace manuals
if no luck you might get some support or advice
http://huppert.com/
hope it helps
Apr 21, 2012 | Computers & Internet
I have a william furnance and need a manual
Without knowing the Model Number of your Williams Furnace, it's impossible to help you. However here is a link to a site that has Williams Furnace Owners Manual. Look for your Model Number and you can download and print the manual.
http://homeappliance.manualsonline.com/manuals/mfg/william_furnace_co/william_furnace_co_furnace_product_list.html
Mar 23, 2011 | Heating & Cooling
I have a goodman electric furnace. Model no AR32-1, where can I get a manual. My furnace is making a grinding/squeak noise. Is it okay to run it until it's fixed?
I'm not sure you have a true Electric Furnace or a Heat Pump, since both are electric.
In any event, Goodman has Owners manuals that you can download in a pdf format. Just look for your model #.
http://www.goodmanmfg.com/SearchResults/tabid/37/Default.aspx?Search=Owners+Manual
Feb 04, 2011 | Goodman Heating & Cooling
I HAVE AN OLD KENMORE CENTRAL HEATING/COOLING GAS FIRED FURNACE. IT WORKS GREAT BUT I RECENTLY UPGRADED THE THERMOSTAT AND COULD NOT WIRE IT PROPERLY BECAUSE I COULD NOT IDENTIFY THE WIRES DUE TO THE...
You will have to look in the furnace to see what color wire goes to the varios terminals on the furnace it should be labeled R,W,G,Y record the wire colors to the terminals in the furnace and wire the thermostat accordingly.
Jan 09, 2010 | Heating & Cooling
Electric furnace won't shut off
It sounds like a bad or badly miswired T-stat
Jan 20, 2009 | Goodman CLQ36AR49 Air Conditioner
Furnace will not turn on in Auto mode thermostat
It sounds like you T-Stat is messed up. Look in your manual to see if there is set up instructions. If not I would change the T-Stat.
Jan 02, 2009 | Heating & Cooling
Goodman GMP100-5 Rev Furnace Manual
I don't know where you are located, but there is a Goodman distributor in Sacramento, CA. Also in Ontario CA. They are a distributor so they may be able to help you or tell where to find someone who will help. Goodman is also known as GMC or Janitrol.
Jan 07, 2008 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
47 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
