Question about Kenmore Heating & Cooling
Kenmore window air conditioner
I have a model no. 580.74124400 window air conditioner. Does it have a reset button or a fuse? How do I find it and how do I fix it?
  • 525 Answers
Below is a link to the model that you describe. This link shows a parts breakdown and cost feature. From the parts description, I was unable to locate a customer replaceable fuse. I have never heard of a fuse inside of an a/c before but I just wanted to be sure. It appears that this is electronically controlled model, so
make sure you have adequate voltage and grounding to your outlet before you call for service.
http://www.retrevo.com/s/kenmore+air+conditioner+580.74124400?rt=tr&p=http%3A%2F%2Fwww.appliancefactoryparts.com%2Fairconditioners%2Fhelpcenter%2Fbreakdowns%2Fkenmore%2F
Posted on Jun 03, 2008
Air conditioner will not restart
if that is all that was changed 240 volts is either not there. does it have reset on poer cord.
Sep 04, 2014 | Kenmore Model 253.70181 Window Air...
Air conditioner 253-70251
drawing to many amps. can be capacitor issues.
May 11, 2014 | Kenmore Model 253.70181 Window Air...
My air conditioner just shut down like it has no power but the outlet has power. Is there a reset button or something? It's a Comfort Aire Model RAD-151-B
Many window units now have a GFCI plug. If the power cord, where it plugs into the wall, is huge, it should have a reset button on the face or side of the plug.
If not, then a power fuse on the control panel has blown, or the control panel has died.
Aug 14, 2010 | Comfort-Aire RADS-151 Air Conditioner
Just put in the window for the first time his year
no fuse or reset just for the compressor. Since the fan is working only, you will have to open up the unit and see what you have. Possible causes: 1. bad thermostat
2. a wire burned off
3. bad capacitor
4. low on refrigerant
5. bad compressor
Jun 22, 2010 | Kenmore 71121 Air Conditioner
My kenmore window unit keeps blowing reset button what could be problem. its not the plug to house i already checked it
It's the reset button on the plug itself.
Those things are the worst invention ever.
Cut that thing off and attach a normal plug.
Then buy a cheap power strip with automatic reset switch and plug to that.
Mar 11, 2010 | Kenmore 75050 Wall/Window Air Conditioner
My kenmore 12k BTU window unit will not turn on and behaves the same way as if unplugged... no sign of ''life.''
Hi, check house panel circuit breakers or fuses, check receptacle/outlet. if you got plug/receptacle, check for reset button, press reset. if there's power at receptacle, could be faulty circuit board. good luck
Sep 10, 2009 | Kenmore Slider/Casement Air Conditioner
No pwer as well
my ac unit will not turn on the model number is ca5036vka1
Aug 01, 2009 | Kenmore 75085 Air Conditioner
Kenmore window air conditioner blows a fuse.
You got short circuit in the system. Then check the line where the fuse is blown that's where the fault is. Or if it is just the fuse for the two line, you have to check the entire unit.
May 24, 2009 | Kenmore Heating & Cooling
Reset button
it should be at the plug. should be a test and a reset, like a GFI outlet. if not there is none, let it cool down say a prayer or 2 and plug it back in.
May 07, 2008 | Kenmore 72055 Air Conditioner
Kenmore Model #731893 Room Air Conditioner
Does you air conditioner have a GFCI on the end of the plug if it does there is a reset there.. let me know if it doesn't and you want to go deeper?
Aug 07, 2007 | Kenmore 73189 Air Conditioner
Heating & Cooling Logo
456 people viewed this question
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
1STHVACMAN
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
