Question about Garmin n?vi 260W GPS
Wrong milage on my GPS
My GPS is giving the wrong milage. Everytime it gives a milage to a location, it is like 30 miles off or more. what could the problem be?
    Problem Solver:
  • 4 Answers
Cheack settings to see if its in miles or kilometers
Posted on Jul 24, 2009
It will not talk r give the right directions. Everytime i enter my location it ask if i want to simulate route. If u hit no it turns off. If u hit yes it starts telling u to turn and there isnt one and...
Either you are in GPS simulator mode or you are unable to receive satellite signals. go into your tools menu Tools > Settings > System > "check if GPS simulator is activated". De activate if it is and your unit should work fine, if this dosent work try giving the unit an update using Garmins WebUpdater software it can be obtained from this link http://www8.garmin.com/products/webupdater/howtoinstall.jsp.
Hope this helps!
Feb 13, 2011 | Garmin nuviĀ® 200 Car GPS Receiver
Roadmate 2000 has suddently started giving me crazy directions. If I followed them, the routes would take me 30 miles out of my way.
  • Check first the signal. Make sure the signal is not weak. Because if the signal is weak normally thats what will happen.
  • Reply to this solution if you have questions.
Jun 12, 2010 | Magellan RoadMate 2000 GPS Receiver
What kind of oil does this van use
It will give the weight needed, printed on the oil filler cap, some have it on the dip stick.
Mar 31, 2010 | 2001 Ford Windstar
The odometer/milage counter stopped working.
You need to replace the VSS or vehicle speed sensor. Located on LH, lefthand rear of transmission.
Sheilah
Apr 04, 2009 | 1995 Ford Thunderbird
(1) what type of engine oil to use for a change on a 1999 chevy silverado k1500 (2) drivers power window inoperable
the oil depends on how many miles are on it and where you live. In a cold climate with low milage it should be 0-30 or 5-30 with higher milage 10-30 or 10-40 in warmer climates low milage 5-30 or 10-30 higher milage 10-40
Jan 20, 2009 | 1999 Chevrolet Silverado 1500
Wrong directions
needs map updates,when was unit updated last?
Aug 06, 2008 | Navman F20 GPS Receiver
Distance
You say it is 30 miles away because you know the route to the specified location. 16 miles means that the distance directly from your location to the specified location.
Jun 28, 2008 | Garmin nuvi 200W GPS Receiver
Wrong milage
There are a number of aspects to this:
The consumer type GPS has an average best accuracy of about 30 to 50 feet at any location. This is as long as it can have good reception from 3 satellites or more with no reflections. In the city there can be some reflections that can also contribute to errors.
When there are many turns along the route, some of its error rate can be accumulative in its caculations.
When the GPS is making calculations it is active on its results from the activity that is going on in the background of its operation. Sometimes it may see alternative combinations of possible routes and it may be sampling from these extra combinations, and then re-calculating. This can cause some changes in its calculations while on route which will look like some instability.
What the consumer maping GPS is good at is getting you to the location. This it should do this to within about 30 to 50 feet accuracy after the route has been completed. The GPS system works on a global basis. When considering the span of all of this and the distance to the satelites, this is feat in itself that it works!
Jerry G.
Jun 03, 2008 | Garmin n?vi 260W GPS
My GPS Unit does not say the leading decimal point in distance.
The voice say "point 6 miles" it does not say "6 tenth miles"
Jan 03, 2008 | Garmin StreetPilot i3 GPS Receiver
Garmin n?vi 260W GPS Logo
104 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
