Question about Amana Dryers
Amana dryer model no. LGA50AL will heat for about 15 minutes and then the flame shuts down. After a couple of minutes the ignition unit will come back on but the flame will not refire. You can shut it off and wait 30 minutes and repeat the process. The vent is clear.
    President:
  • 1,430 Answers
This is usually the dryer coils have failed. They tend to fail as they heat up. They are inexpensive and easy to replace. Here is a video on replacing the dryer coils. If you need further help disassembling your dryer you will find videos there also.
Posted on Oct 15, 2010
Amana NDG2335AW Gas Dryer runs but doesn't heat
Check the spark ignitor when firtst starting the dryer up. It should click within the first 15 seconds to light the pilot up
May 31, 2010 | Amana NDG2335AW Gas Dryer
Gas comes on and ignites first time and after up to temp and flame shuts off it won't relite. the igniter glows but no flame
bad gas coils located on top of the gas valve.when the coils are on there way out they will do this,when they heat up they fail,when the dryer and the coils cool down they will fire.they let the gas in and the ignitor ignites the flame after 15 to 30 minutes they fail.let me know how you make out
May 24, 2010 | Kenmore 73952 Gas Dryer
Kenmore dryer Model #6507923 Gas sometimes won't
You may have a bad thermocouple. The thermocouple senses the heat from the flame and "tells" the control unit that the flame has lit. If it is sending no signal, the control will think it didn't light and shut off the gas to prevent an explosion. Good luck.
Jan 03, 2010 | Dryers
Dryer starts with heat. After 10-15 minutes, when dryer calls for more heat, here a metal clicking noise, flame does not ignite. When it's clicking, I can look down the back from the top and see a glow....
Your gas valve coils are defective. Part #694539 and 694540 are required. Once the coils get hot they collapse internally and the gas valve shuts off. This is a common problem when valve coils get weak from use.
Nov 09, 2009 | Whirlpool LGQ9857L Gas Dryer
I have an Amana gas(LP) dryer DLG330RAW that doesn't heat. When I turn on the dryer the ignitor glows red, and ignites a great flame for about 10 seconds, then I hear a click and the flame shuts down. A...
Replace the two small round black solenoids located on the gas valvle. I just did it last week. They come in a set and only cost me $26.50. Easiest fix I've done. I was all set to go out and buy a new dryer.
Sep 24, 2009 | Amana DLG330RAW Gas Dryer
The heater starts up but then heat shuts off within a couple minutes
i would look a a high limit problem.check for obstruction between heat exchanger and top of unit or plugged heat exchanger.remove top and look straight down and you should see burner flames between heat exch fins. depending on which ignition you have,could also be flame sensor problem.ususally with flame sensor problem burner shuts off within 20 seconds.hope this helps.
Aug 24, 2009 | Pool & Spa
Dryer heating problem
It sounds like an air flow issue. There is a flame sensor on the side of the flame housing. If the venting is not sucking the flame down the tube it will cycle very quickly and never reach the right temp.
Jul 04, 2008 | Amana ALG331RAW Gas Dryer
Dryers Logo
71 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you an Amana Dryer Expert? Answer questions, earn points and help others
