Question about Casio EXILIM EX-Z1000 Digital Camera
Around rock lenticular part, if after zoom in/out does ever emerge writing "LENS ERROR" and retry power on. its road map appeal ??
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Casio Master
  • 102,366 Answers
  • 3 Answers
SOURCE: Zoom shutter wont extend fully
the same thing happened to me. I took my camera apart - just removing the case. I then operated my camera and it became "unstuck". now it works just fine. I put the case back on and all is just as before.
Posted on Jun 28, 2007
  • 374 Answers
SOURCE: says lens error!!!!!
A lens error requires to be sent into repairs. Give them a call at 800-706-2534 option 2.
Posted on Apr 05, 2008
pontelemon
  • 538 Answers
SOURCE: When I turn on my EX-z150 it says 'lens error or retry power on.'
Defective Lens Block.
Needs to be replaced.
Posted on Mar 20, 2009
  • 45 Answers
SOURCE: my camera says lens error
Chances are your focus is messed up or damage or the lens motor is i would suggest getting a new camera or getting it fixed at a camera store
Posted on Aug 08, 2009
BillB-SA
  • 2761 Answers
SOURCE: Casio exlim EX- Z29 lens error upon power on
If you've recently dropped the camera you may have damaged the lens tube (housing) or jarred the zoom mechanism off of its track -- either of these problems will require professional repair. If the camera has not been dropped, your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may be too weak/worn to properly power the camera, or the camera may require professional repair.
Posted on Oct 17, 2009
Every time i switch it on,it displays that lens error or retry power on.
The lens error is due to failure of the lens control system. You can remove battery and card replace battery and while switching on tap the lens hood on your hands so as to disengage any dirt or mechanism being struck.
Use some air to blow between the lens to dislodge any sand particles struck inside. Unless you are familiar with handling of small devices must the camera be opened. If so check the voltage on the motor drive, check the auto focus and Zoom drives, it must be free with manual movement. If jammed the motor can be removed and realased. If none of these works then you can think of taking consensus with the service centre.
Get estimate before you decide. It will be good to have it checked at the authorised service as you do not have to run around for spares.
Jul 21, 2011 | Casio Cameras
Les Error, cannot get in focus when in auto focus. I when itry and use the zoom I get a lens error and retry power on
the lens unit was not extend properly and cause of turning off once you turing on and zoom out.If you can open the camera and get the lens unit. Try to open the lens unit and clean it and try to rotate to the maximun position but dont put too much force. if you cannot do that bring it to service center
thank you
Jun 17, 2010 | Casio Exilim EX-S500 Digital Camera
My camera says lens error
Aug 07, 2009 | Casio Exilim EX-S600 Digital Camera
Zoom Error
I think a grain of sand was blocking the zoom tubes. This will not work if the camera has been dropped & the zoom apparatus is bent. It is entirely at your own risk & may invalidate any guarantee but they may charge anyway if you have got sand in. I cut a finger of 80gm computer paper 1cm X 5cm. Inserted this first  around outer zoom tube & worked it all around. It goes in quite deep so be gentle. I switched on to open zoom & tipped out batteries before it had time to close & repeated procedure. When I put batteries back in it worked OK. I repeated procedure with lens fully extended. I found a thin bit of plastic packing worked better as it did not kink so easily. It is still working today having failed 100% before.
Chris
Jul 02, 2008 | Cameras
Casio EXILIM camera lens will not extend fully!!!
Try plugging the PC interface cord into the external connector. No need to hook it up to your computer, just plug it in and out a few times. Then try to power up the camera.
Good luck.
Zductive
Jun 02, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Says lens error!!!!!
Apr 02, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
EX-Z60 A Casio
Is there anything that sounds like a "beeping" noise when it extends? A lot of times the focus motor gears are knocked out of place. This causes a lens error, even if the lens extends fine. The camera has the "external" zoom lens, and an internal focus lens. This can be only fixed with disassembly of the lens, if indeed this is the problem you're talking about.
Aug 08, 2007 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Casio EXILIM EX-Z1000 Digital Camera Logo
27 people viewed this question
Top Casio Cameras Experts
mohamed salim shaikh
pontelemon
pontelemon
Are you a Casio Camera Expert? Answer questions, earn points and help others
