Question about Lexmark C540N PROD SPECS TBD Printer
Error code 942.01 ??? what does this mean? service yellow TMC
5 Suggested Answers
wheatlandsvc
  • 1110 Answers
SOURCE: What does an error code H4-01 mean on a Sharp
Fuser Heater failure. The fuser is the part of your machine that heats up and "fuses" the toner onto the paper. It is located right near where the paper exits the copier. This error code means that the fusing unit is not heating up as it should. The most common failures in order of ocurance are thermal fuse, thermister and heater lamp. In any case you are going to need a service person to come out and diagnoe which part has failed, replace the part and reset the code for you. Should not be more than say $200 to repair.
Good Luck and Thank You for using Fixya.
WheatlandServices
Posted on Nov 13, 2010
  • 217 Answers
SOURCE: 942.02 Service Yellow TMC Sensor
Remove the toner cartridge, and inspect the lenses on the toner meter cycle (TMC) card.It is positioned on the right side of the toner cartridges
Are the lenses blocked, or dirty? Clean them
If damaged replace them
Posted on Mar 09, 2011
Printtech
  • 1087 Answers
SOURCE: What means "943.02 Service Black TMC Sensor"?
A 94x.xx TMC Error indicates that the printer has failed to detect the Toner Metering Cam for a specific cartridge. This error typically occurs when the cartridge or developer are misaligned or incorrectly seated
Please click on the link http://bit.ly/ozldpC to see instructions on how to go about the procedure.
For further assistance, please contact Lexmark Technical Support.
Posted on Jul 14, 2011
Printtech
  • 1087 Answers
SOURCE: tHE 942.02 Service Yellow TMC Sens message is in
Error indicates a problem with the Cyan toner cartridge/developer. Try the following steps:
Power off the printer/MFP and open the toner access door. Reseat all of the toner cartridges. Power on the printer/MFP again and print a test page. Did the error message return? Power off the printer/MFP and remove the developer unit for the color specified in the error message, and then reseat it. Try printing another test page, verify if you're still getting the same error. It is possible that specified color's toner cartridge and developer unit are defective. If you have a replacement toner cartridge and developer, install them as a test and print a trial page.
For further assistance, please contact Lexmark Technical Support Center.
Posted on Jul 15, 2011
I just replace the TMC on my 2003 cadillac cts not shifting at all is on limp-in mode
TMC as in TRAFFIC MESSAGE CHANNEL (European vehicles) or TMC as in TCM-Transmission control module.
If its the 1st, your antenna is probably resisted.
If its the 2nd, need FAR FAR more info and this is definitely a job for professionals. If its in limp mode, a warning lamp is also on or will be. That means fault code(s) set and there will be freeze frame, failure record, and code ID info a tech must have to proceed. If you replaced the Trans Control module...it must be programmed correctly for the vehicle...and more importantly, who said to and why did you? If someone diagnosed it, thats fine, they should warranty it. But it really will require significant tooliing (Above average enhanced scantool and a meter or scope, possibly some pressure measurement equipment) that you just dont have and cant buy at the local hardware store or parts house..
Mar 05, 2015 | Cadillac Cars & Trucks
943.02 Service Black TMC Sensor error
The best way is to call the company's technical dept.
Aug 15, 2014 | Lexmark X5495 Printer
942.02 Service Yellow TMC Sensor error showing
Mar 07, 2011 | Lexmark C540N PROD SPECS TBD Printer
Feb 20, 2011 | Lexmark X543dn Laser Color All-In-One...
THE 942.02 Service Yellow TMC Sens message is in the screen. What does it mean. It will not let me print
Jan 27, 2011 | Lexmark C540N PROD SPECS TBD Printer
Puk blocked, travel pilot TMC GPS 3.0 pin & puk entered imn error
A request for a PUK code ("Personal Unlocking Key") will appear on your phone if your SIM card PIN code is entered 3 consecutive times incorrectly.
Your SIM card will then become "PUKed" or Blocked. This is a security measure to protect your service.
You need to call the Customer Service department of your cell phone provider and they will give you the PUK code which will unblock your SIM card.
Dec 01, 2010 | Blaupunkt TravelPilot Lucca MP3
I have a lexmark c782 office printer that is showing a code of 942.05 service yellow tmc sensor what does this me
The error indicates either a defective yellow cartridge metering cycle or a sensor problem that usually requires service. But you can try replacing the yellow cartridge first. If problem continues, I recommend you contact Lexmark technical support or your authorized service provider for further assistance. Thanks.
Aug 20, 2010 | Lexmark C782N COL LASERPR 25PPM 1200DPI...
Yellow light on and the driver report an error code: E198 0000 What does this code mean please.
Jun 26, 2009 | Canon LASER SHOT LBP-5000 Printer
Error code E000020-0181
Hello Brass, This error code means that the yellow drum/developer unit has failed. Your machine has 4 drums, cyan,magenta,yellow and black. At best they are good for about 40,000 copies. You can order one online and it is fairly simple to replace. Let me know if I can help further.
Jan 03, 2008 | Canon imageRUNNER C3200 Copier
Lexmark C540N PROD SPECS TBD Printer Logo
340 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
