Question about Electrolux Vacuums
Good evening, I have a Xio Z1010 electrolux vaacum cleaner and I hope you'll be able to give me some advice. The vacuum cannot be started. Last time it started for a few seconds and stopped suddenly. Something similar happened long time ago but that was due to overheating. Once cooled down in few hours it would start again. It is not the case now after 24 hours. Could you give me any idea what could be the reason? Your help would be much appreciated. Adorian
LizDahl
  • 75 Answers
SOURCE: Electrolux Oxygen Ultra
The problem is that Electrolux sold a portion of the company to Eureeka, so the Electrolux you are familiar with is under the name Aerus-Electrolux. Aerus vacuums are still produced with the same high quality as always, and still are made in the USA!!!
Posted on Feb 26, 2008
reddevil6
  • 1673 Answers
SOURCE: Electrolux diagrams and schematics
Sorry, I don't, but you cn look on line or phone book for Aerus Electrolux. But if they will ive you any info, I don't know. Sorry I couldn't help you out.
Posted on Jun 17, 2008
  • 373 Answers
SOURCE: electrolux model 1401
try a local vacumn repair center or web site
Posted on Feb 04, 2009
  • 134 Answers
SOURCE: Electrolux canister vacuum
Mmm cant find any info on this machine. Did you buy it in CAnada?
However. If you can find where the exhaust filter is, the bit where the air blows out, take off the cover and filter. If there is an exhuast blower it will be here.
I have to say that of late Electrolux have done away with this on most machines
Rob
Posted on Feb 19, 2009
EwingElect
  • 276 Answers
SOURCE: vacuum cleaner won't go - missing a step
In between the filters there's an access panel that can be removed - there may be a blockage there. You should also check your hose for a blockage.
Otherwise you may need to take it to your local Electrolux Service Center. There may be a problem with the pressure board. The machines have a 2 year warranty, not sure what it'd be in your neck of the woods.
Posted on Apr 03, 2009
Vaacum cleaner not sucking up
The first place to start is checking the brush roll and installing a new belt if it's over 6 months old.
Feb 23, 2015 | Hoover Elite U5061-900 Bagged Upright...
I have an Electrolux Oxygen 3 vacuum I purchased rebuilt. After 1 month the power stopped working. I took it into Electrolux Authorized repair dealer, which was a horrible experience. When we received it...
Never have liked Electrolux doing any repair because it has been my experience that they don't do what they say they did....if you can read between the lines.....give me a picture of the unit and more details and I'll try and help you.
Aug 04, 2013 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Electrolux Epic Series 6500 SR. The machine is 15 yr. old & is working beautifully. However, when operating it emits a terrible stink, like cat *****. I've changed bags & filters but no ch
You need to have the vacuum cleaned out. If you are good with tools, just remove the motor and fans assembly, take the fans off and wash them. Brush ALL dirt out of the housing and reassemble. Your Electrolux dealer can do this but it isn't cheap. I used to be the service manager for my area. Since it isn't under warranty, you can have ANY reliable vacuum cleaner shop give a good cleanout. NEVER put anything into the cleaner to make it smell good. Electrolux cleaners get their power by having a straight through suction. The air goes through the motor. Adding smelly things can crystallize onto the motor and burn it out.
Jan 17, 2013 | Electrolux Epic 6500 Vacuum
How to repair electrolux xio no power
Could be a break in the cable, thermal switch if it has one, some have them on the motor in case of overheating. Could be a faulty power switch.
Could be a number of things, if you are not confident enough to take it apart and look then you should take it to a repairer.
Apr 15, 2012 | Electrolux Vacuums
What charge for this service?
Actually there are no hidden screws on your Electrolux Epic model. This is the newer plastic body canister made by Aerus Electrolux. In order to open the vacuum cleaner to inspect the motor, first open the vacuum bag door and remove the vacuum bag. After the vacuum bag has been removed, keep the vacuum bag door open.
The two rubber furniture guards on both sides of the vacuum cleaner are actually what are holding the top housing and the bottom housing together. You'll need to slide both of these rubber furniture guards off in order to open the rest of the vacuum cleaner. They slide forward towards the vacuum bag housing which is why the door needs to be open.
In order to get these slides started, it's sometimes necessary to put a flat head screwdriver in between the back of the furniture guard and the start of the cord reel housing. Right after the rubber starts behind the word Electrolux. Fit a flat head screw driver in this gap, and it's sometimes easier to use a hammer, and hit the screw driver that's on the furniture guard facing the front of the vacuum.
With a little perseverance, you should be able to get the slide started, and when the slide starts to come out past the vacuum bag housing, simply grab the end of it with a pair of pliers, and pull the rest of it out of the vacuum.
Do this on both sides of the vacuum, and you'll be able to separate the two housings, and get access into the motor compartment.
If you have any problems, or would like me to take a few pictures of this being done, I'd be happy to do so. Please just rate my repair as helpful if you found this advice useful. I really do appreciate this.
Thank you,
Chris J.
GoVacuum
Apr 07, 2010 | Electrolux Epic 6500 Vacuum
My electrolux oxygen vacuum cleaner shut off and will not turn back on. It's less than a year old, but I bought it off Craig's list--they were the orginal owner and they said they bought it in May of 2008....
No..Electrolux is really great about warranty service. They will help you even though you are not the original owner. http://smallappliances.electroluxusa.com/files/usa_english/0-999/OxygenOwnersManual.pdf owners manual. Here is a link to the site.
http://smallappliances.electroluxusa.com/node82.asp Also, you might check for an obstruction. The Electrrolux is thermostatically protected. Means that if there is no airflow through the motor, the motor will shut down before overheating can occur. Remove your hose from the cleaner. Drop a quarter down through it, did it come through? If not, you have a clogged hose. If it came through, remove your wand from the power nozzle, look througfh the wand, is it clogged? Now, look at the power nozzle, can you see light through the elbow? Your cleaner will come back on after it has cooled. Try the machine. It should be working now. I hope I could help to Fixya! Please let me know if I helped you. Thanks, Rene (the Vacuum Doctor)
Nov 15, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Cord rewinder on a Electrolux model C102J vacum cleaner
Hi there Johnd, SmartAlec from Nelsonvacuums.com.au here. I fix vacuums full time for a living and the first time i had this problem with the australian version of this vacuum it tok me an hour to pull it apart and back together. now i have done a dozen or so it is about a 30minute operation. I dont know what you rate your technical skill level at but i give this machine a 8/10 for hardness. It is most likely that the cord has jumped off the reel and is wedged so it shouldn't require parts but it cant be done without nearly stripping it down. There is no reset or similar for the reel. My advice unless your very confident take it to a repairer. It would be 1/2 - 1hr of labour charge only i would think.
Hope this helps.
SmartAlec
Sep 02, 2009 | Electrolux EL7055A Bagless Canister Vacuum
Need to replace belt
turn it over on the bottom by the roller there is a cover with 5 screws take off cover theres the belt........hope this helps
Dec 17, 2008 | Eureka 5848AV Bagless Upright Vacuum
Feb 10, 2008 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Vacuums Logo
67 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
