Question about Garmin n?vi 260W GPS
Wrong milage Hello, I just purchased a Garmin 260w, and for some reason it is giving me false milage. I am using standard miles and not Km. Some addresses I have went to, it said on the GPS it was like 77 miles, and it ended up being 110 miles. Another instance. The distance on GPS was 96 miles and ending up being 139 miles, and I am using the routes directed by the GPS. What could be the problem with my system?
    Genius:
  • 1,673 Answers
There are a number of aspects to this:
The consumer type GPS has an average best accuracy of about 30 to 50 feet at any location. This is as long as it can have good reception from 3 satellites or more with no reflections. In the city there can be some reflections that can also contribute to errors.
When there are many turns along the route, some of its error rate can be accumulative in its caculations.
When the GPS is making calculations it is active on its results from the activity that is going on in the background of its operation. Sometimes it may see alternative combinations of possible routes and it may be sampling from these extra combinations, and then re-calculating. This can cause some changes in its calculations while on route which will look like some instability.
What the consumer maping GPS is good at is getting you to the location. This it should do this to within about 30 to 50 feet accuracy after the route has been completed. The GPS system works on a global basis. When considering the span of all of this and the distance to the satelites, this is feat in itself that it works!
Jerry G.
Posted on Jul 01, 2008
I can not install the map on to my 260w garmin
connect the unit to the computer using a USB data cable and then go to www.garmin.com and register the unit, if your unit is new you get one free update with-in 90 days if outside that time frame you will have to purchase either a one time update for 49.99 or lifetime updates for 89.99
Sep 11, 2011 | Garmin nuvi 260W GPS Receiver
Hi - I own a Garmin Nuvi 260w. Is it possible to use the SD card to download a trucker navigation road map and upload this to my Garmin Nuvi 260w? Thanks for your response.
It is possible as long as the map is Garmin compatible.
However even with a trucker navigation map installed, the nuvi 260w will not function as a trucking GPS as the routing and IQ of the nuvi 260w does not have the capability to operate in this manner.
The nuvi 260w does not have a trucking mode to allow for the input of specific truck information like truck and trailer length and gross vehicle weight to use as factors on determining the best route for the specific truck/trailer combination.
I would recommend using a GPS specifically designed for trucking like the Garmin Dezl.
http://www.gpscity.com/garmin-dezl-560lmt.html
Sep 10, 2011 | Garmin nuvi 260W GPS Receiver
Nuvi 260w, need support on how to calibrate screen.
Garmin unit do not have a calibration feature so if you are noticing screen issues give the unit a firmware update using garmins web updater software it can be obtained here from this link http://www8.garmin.com/products/webupdater/howtoinstall.jsp.
Hope this helps!
Feb 24, 2011 | Garmin nuvi 260W GPS Receiver
My Garmin Nuvi 260W gives vocal directions but is unable to read the distance. For e.g turn in ...m
try going to Tools... Settings... System... on this page look at Units is it set to Miles or Kilometers
set to Miles
hope that works
Nov 06, 2010 | Garmin nuvi 260W GPS Receiver
Garmin 260W free updated map
Hello.
You can go to mygarmin.com or garmin.com . You have to register. It is for FREE. Then,you can update your GPS. You can also download maps by just following the screen instructions.
You can also find all the software/drivers you need there.
Hope it helps.
Apr 07, 2010 | Garmin nuvi 260W GPS Receiver
Is there a free map for garmin 260w for car gps
Garmin offers a free upgrade for a new or refurbished unit purchased from an authorized re seller. You have up to 60 days from your firsr sattelite aquisition to take advantage of it.
Apr 05, 2010 | Garmin nuvi 260W GPS Receiver
Have Garmin Nvui 260w that has lost it maps. earlier purchased mapdates and hasn'b been the same. shows Garmin and computer on sceen.
GO INTO SETTINGS
THEN MAPS
THEN MAP INFO ,
MAKE SURE THE "TICK" IS IN THE BOX OF THE MAPS YOU WANT TO USE
IF THAT FAIL'S THE THE DOWNLOAD DID NOT TAKE, IF SHOWING COMPUTOR ON SCREEN STILL, THEN RESET, EITHER THE RESET BUTTON ON THE BASE, (PUSH) OR HOLD/PRESS BOTTOM RIGHT CORNER OF SCREEN WHEN POWERING ON AND WAIT, THEN RELEASE PRESSURE TO HARD RESET
Dec 29, 2009 | Garmin nuvi 260W GPS Receiver
Switching from Miles to Kilometers
Use the driver information center to change your settings. The switch that controls it is located on the dashboard just left of the steering column. If you have your owners manual, it gives a detailed description of how to change it.
Good luck, let me know.
Regards,
Feb 21, 2009 | 2002 Chevrolet Monte Carlo
Wrong milage on my GPS
cheack settings to see if its in miles or kilometers
Jun 03, 2008 | Garmin n?vi 260W GPS
Garmin n?vi 260W GPS Logo
93 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
