Question about Sony KP-46WT510 46" Rear Projection HDTV
Color is dark and blacks out after awhile! whats up with that
  • 3 Answers
If it's anything like my rear projection TV, it may have a lamp that needs replacement. After many hours the lamp dims and needs replacement. A new lamp cost about $100 and you can replace easily by your self.
Posted on Oct 15, 2010
P50 dose not print black color
You might have to run the head clean more than once - if no black at all is printing.. Alternatively, set out a page of all black (background) and print few pages on high print quality setting.
good luck!
Feb 17, 2015 | Epson P50 Inkjet Printer
MY SAMSUNG DLP MN HLP6163W PICUTURE HAS FADED
If you have had this unit for awhile it could just be the lamp. If the image does'nt brighten up you may have an issue with the light path. The color wheel produces the color. If there was an issue with the color wheel you would most likely have a black and white image.
Jan 24, 2010 | Samsung HLP6163W 61" Rear Projection...
Oil has turned black and thin
You don't identify the engine - if it is a diesel engine it is normal to turn dark. If it is a gasoline engine properly maintained it shouldn't turn dark. However, something leaking into the engine would cause other problems. Gasoline leaking in would thin it but not cause the dark color. Coolant leaking in would cause a milky look and transmission leakage would cause other symptoms. I suggest you change the oil and filter and check it regularly for awhile and note any symptoms that don't seem normal when driving. If it hasn't been changed for awhile it may just be dirty, and hot oil draining will seem thinner.
Dec 21, 2009 | 2006 Dodge Ram 3500 Truck
Hp psc 1210xi- the black ink cartridge appears to be out- i have a good color cartridge-how do I get the error off of my printer and print with my color cartridge?
  1. Take out the black cartridge once you've determined that you are completely out of black ink. You'll have to rely on the dark hues from the color cartridge to print in black.
  2. Adjust the printer software settings. Once you take out the black cartridge, your printer's software will typically warn you that you are missing a cartridge. Follow the instructions for your printer to allow the printer to print without the black cartridge. Then set the printer to print in black and white, not color. This overrides the black cartridge and allows the printer to access the dark hues of the color cartridge.
  3. Print a test page to ensure that your printer now prints black using the color cartridge.
  4. Print your documents. Bear in mind that your documents may not appear as black as normal. Still, they should be dark enough to pass for black, depending on how much color ink you have and the strength grade of the ink.
Sep 29, 2009 | HP Office Equipment & Supplies
R52wh74 fades to one color then dark, then black
awewryte,
I have the same TV and now have the identical problem that you described. Did you ever get it fixed or find out what the problem was? If so, will you please pass the information on?
Thanks.
Aug 08, 2009 | RCA Televison & Video
Upstream oxy. sensor signal wire, what color is it?
In my 1990-1995 manual it is Black/Dark Green.
Dark green/orange is 12 V supply, Black is ground, Black/Light Blue also comes from the powertrain control module but is common to many other sensors.
Dec 23, 2008 | 2000 Dodge Neon
Dell A960 printing blank pages
I just sprayed windex on bottom of cartridge several times and wiped with paper towel until dark streak of black appeared. Then I dried off cartridge and replaced. It works now. Must have been clogged.
Nov 18, 2008 | Dell A960 All-In-One InkJet Printer
Sony KP-46WT510 46" Rear Projection HDTV Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
