Question about Sony Walkman WM-FX281 Personal Cassette Player
I need a headphone jack J301 or jack part # for Sony walkman WM-FX-281
4 Suggested Answers
SOURCE: Sony Walkman WM-D6C
If your WM-D6C has a serial number below 267201 (take out the battery block and you'll see the serial number sticker there) then the problem is electronic, not mechanical. It is likely due to the speed controller chip (labeled as IC601 on the circuit board), which is made by Sony and is type CX20084. This chip decides the voltage that is fed to the motor which is only about 2.4 volts, Should the chip be defective then the motor receives about twice this voltage and thus runs too fast. If you take the back off the recorder you will see the circuit board; it looks like a rectangle with a small square extra bit sticking out to the right. It is here that the IC601 resides. It is about the size of a small pinky finger nail and has 8 tiny legs down each side. Measure the voltage on pin 15 (put one voltmeter probe (+) on the second leg down on the right side (pin 15) and the other one (-) on the battery negative), it should read about 4.8 volts, which it feeds into the base of transistor (Q601) that in turn will then feed 2.4 volts to the motor (if everything is working OK). If the chip is damaged, then the voltage on pin 15 will be close to zero, and the transistor Q601 will not be "held back" and so will feed about 5 volts to the motor. CX20084 is (unfortunately) obsolete, someone in the UK sells them for about $50, but an excellent company in Hong Kong (utsource.net) sells them for $5 (plus $8 S&H). Taking out the old chip and putting in a new one is close to microsurgery, you will need a micro soldering iron (18Watt Antex), a good eye, a powerful magnifying glass and a steady hand, but it can be done - I've done it! There is a possible second reason that could cause the motor to run too fast. There is a pick up coil on the main flywheel called FG901. If this is damaged it will be open circuit and then the only use for your recorder is probably a paper weight. You can test this by going back to chip IC601 and locating pin 1 (top left pin; a small circle on the body of the chip is next to pin 1), Pin 1 is connected to the positive side of a capacitor,  C602 (0.47 microF), check the resistance from the negative side of C602 to the ground (take battery out, and use battery (-) as ground). You should get about 600 - 650 ohms reading. If you get nothing, sorry there is not much you can do about it as these pick up coils are definitely not available. Finally, chip 601 (CX20084) goes bad if you connect the batteries back to front. Good luck. Giles..
Posted on Jan 16, 2009
  • 63 Answers
SOURCE: tape speed distorts and slows
motor belts are cheap. try replacing the belt that drives the wheel. this become distorted specially when the unit has not been use for quit long time. if you think its not about belt, clean up the rubber that touches the tape when played, also the tape head with 70% alcohol. hope this help.
Posted on Apr 05, 2009
caroldon
  • 17130 Answers
SOURCE: how to replace the drive belt on the sony walkman
Since this is a very small player what is important is to be very careful and delicate to open the rear cover and do the repair. The printed circuit board has to be removed and moved up carefully not to damage or detach wires. Now remove the capstan cap and take out the old belt, check the size with the new one and if OK run in the same direction you had taken out. replace the lid and the pcb carefully and fix the wires according to the same pattern so as not to touch the belt and drives. Now put in a cassette and test. If it works ok with the speed close the rear cover. clean the headd, the rollers and the transport section . Now your tape has been serviced and must work well. Hope my advice helps you . Good day
Posted on Jul 22, 2010
My unused WM-FX 195 doesn't play cassette
Fault with the drive belts, remove rear covers and take sample belt to buy and replace. Might be difficult to get them but in old stocks.
Aug 30, 2010 | Sony Walkman WM-FX193 Personal Cassette...
Please can you send me the user manual for Sony casset/radio modal WM-FX 277 thank you
You can download the manual from the manufacturer's web site at
http://esupport.sony.com/US/perl/model-find.pl?mdl=WM-FX277
Aug 11, 2010 | Sony Walkman WM-FX277 Personal Cassette...
Cannot hear out of both left and right headphones unless I twist the insert plug. Can this be fixed?
Plug another headphone in walkman to check wither headphone jack in walkman is damaged or its headphone plug.
If other headphone gives same problem then open walkman and re-solder headphone jack in circuit.
Hope this will solve your problem.
Nov 05, 2009 | Sony Walkman SRF-M70 Radio
Tape speed distorts and slows
Mar 24, 2009 | Sony Walkman WM-FX290 Personal Cassette...
No sound coming out the headphones
Try the line out on the back of the unit and see if sound signal comes out there U must plug that into a preamp on your stereo the signal level is to low for the headphones to sound and if there is sound then u have a blown output amp in the headphones circuit!
Dave Electronic Doctors email eledocs@hotmail.com
Feb 15, 2009 | Sony Walkman WM-D6C Personal Cassette...
My Sony Walkman WM -SR10 is not recording and the cassette tape is not working. Only the radio is player. And I cannot get another one to buy even its not the same. Can you help me
Hello aga2958,
I think you need to visit maintenance center to fix that cause its hardware problem.
But you can check somethings before u visit them .. like:
1. If you are using Batteries to power up the Walkman .. be sure the batteries are full charged.
2. Try to power on the Walkman by Adapter 3 Volts.
3. Be sure the tapes you are using are fine into other Cassette.
Thanks for using FixYa.
Nov 09, 2008 | Sony (Personal Audio) Walkman AM/FM Stereo...
No sound
you must have your walkman be checked. it might be broken.
Apr 06, 2008 | Sony Network Walkman NW-A1200 MP3 Player
Static
Of course, I have to start with the obvious. Try changing batteries and headset and see how that helps.
I would get some cleaning solution called deoxit, and clean the battery leads. Also coat the headphone jack with it and put the jack into the player. Recoat and try again. Twist the jack around, it should help distribute the solution.
If the static is caused by a poor connection, that should clear it up.
Mar 30, 2008 | Sony Walkman WM-FX290 Personal Cassette...
Sony Walkman WM-FX281 Personal Cassette Player Logo
87 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
