Question about HP Pavilion dv9000z Notebook
MY HP PAVILION DV09000 LAPTOP JUST COMES ON FOR A SECOND THEN GOES OFF. THE BATTERY IS FINE. I NEED IT DESPARATELY. SOMEONE PLEASE HELP! 601-928-3333 CENTRAL TIME AFTER 6 PM
  • 2,567 Answers
Motherboard is defective & needs to be replaced with a new one.
You can find a replacement motherboard by searching on e-bay.com with the motherboard's model number. This could be found under the RAM.
Posted on Oct 16, 2010
HP laptop zv6000 won't charge battery
Get the Internal Power Unit checked as i can see its not been able to communicate each other.
May 03, 2010 | HP Hewlett Packard Pavilion DV9500T 17"...
HP Pavilion DV5000 battery charging problem
Sounds like you need to calibrate the battery, it is supposed to be done every 3 months. If it is not done, your battery will display the same symptoms are you describe. Yes, this holds true for adding a new battery also.
Here is HP's instructions on how to do it. You want to scroll down to the section called "Calibrate the notebook PC battery".
http://h20239.www2.hp.com/techcenter/battery/Battery_max.htm
Feb 27, 2010 | HP Pavilion dv5000z Notebook
Problems with HP HP Pavilion dv5-1159se 15.4
Power drain would be a better solution in this case.
1.first shut down the comp
2.unplug the charger
3. remove the battery
and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer .
Oct 29, 2009 | HP Pavilion dv5-1159se Laptop
HP Laptop Battery Problem
I had a similar problems and I had my batter replace by Hp free of charge. Most like your batter could be damage internally or it could be a motherboard problem.
I suggest you visit this HP link http://h20239.www2.hp.com/techcenter/battery/Battery_max.htm
Jul 03, 2009 | HP Pavilion dv6000z Notebook
My HP Pavillion laptop turns on but the screen doesn't show.
You could be expierencing a problem with your monitor screen. try this.... connect another monitor screen to the VGA port of your laptop. Now try booting up. Look for and push Fn + the key that turns on a secondary display. if the monitor screen comes on. you need
another laptop monitor. At least you can use your laptop with the second monitor for now.
Jun 16, 2009 | HP Pavilion dv9000z Notebook
Laptop switches off immediately after powering on
Try powering it on with the battery removed. I have seen some laptops where if you have a bad battery it will cause boot issues.
May 12, 2009 | HP Compaq Business Notebook NX9010
When put on,the indicator light comes up breifly and goes off
is the light indicator blinking that is the battery light ......... then connect the adapter of the laptop ( power cord ) and start
Apr 04, 2009 | HP Pavilion DV6500Z Notebook
Motherboard needs replacement
Try to power up laptop when battery is taken of, if symptoms are the same try to replace CPU and keep battery of the laptop at all times, chenge power supply if this deos not help then possibly your motherboard need repairn. You can sent it to me to have a look, inspection is free. go to www.laptoplabs.net to find my address.
Jan 13, 2009 | HP Pavilion Tx1110us Notebook
My laptop will not boot up
Try soft resetting the laptop .
1. Disconnect the Ac adapter
2. Remove the laptop battery
3. Press and hold the power button for 10 seconds
4. Reconnect the power adapter only and power on .
5. If the laptop starts fine , reinsert the battery back
Thanks
Proton
Jan 10, 2009 | HP Pavilion dv4000 Notebook
3 beeps at start
hmmm...that's not good. works fine with no battery. I suspect your motherboard may be taking a vacation from working soon.
got backup for your HP?
Feb 12, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
HP Pavilion dv9000z Notebook Logo
95 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
