Question about Sansui HDLCD3200 TV
How do i set it to AUX 1 - Sansui HDLCD3200 TV
    President:
  • 2,777 Answers
You need to use the TV's remote control, it will have an INPUT / SOURCE / MODE button, one of those three. Just hit that button and it will take you through the inputs, one of which is AUX 1.
Please make sure you rate my answer 4 thumbs up, it is extremely important to me. I would be forever grateful if you could do so. If you need more help on this question please just respond to my answer here and I will get right back to you.
Thanks,
Tim
Posted on Oct 15, 2010
  • Tim Grayson
    Tim Grayson Oct 15, 2010
    Please consider coming back to the question here and changing your rating to 4 thumbs up if possible. I know it was 4 thumbs up for a while but somehow it changed. Thanks for your consideration.
How do I hook up Roku 3 to my television?
hook the RCA cables to the "input" on the tv and switch your tv to the setting for "aux" (you may have multiple aux inputs like 1 and 2) make sure setting is on aux 1 if cables plugged into aux 1 etc. then put in the ssin numbers fron your router and password then you should be up and running. sometimes you have to set your router to not be password protected and not use a password.
Dec 09, 2014 | Roku Televison & Video
Pioneer keh p6025
You need an extra part to use the AUX function, part number CD-RB20 or CB-RD10. You then have to turn the function on in the settings:
1) Press FUNCTION to select AUX.
Press FUNCTION repeatedly until AUX appears
in the display.
2) Select AUX on or off with 5.
Pressing 5 will switch AUX between on and
off and that status will be displayed (e.g.,
AUX :ON).
Dec 18, 2013 | Pioneer Car Audio & Video
How do I reverse a lockout of aux 1 polaris?
check to see if repair man disconnected that aux if so plug back in if not go to system set up to activate that aux
Jul 07, 2012 | Jandy AquaLink RS OneTouch RS8 Pool or Spa...
I'm plugging in an active speaker to aux 3 of my fx16ii, but it doesn't work. I have it set up the same as aux 1 and 2 where I'm also running active speakers (for monitors). Am I missing...
If you look at the signal flow diagram in your user manual, you will see that while AUX 1 and 2 can be selected are PRE or POST fader, AUX 3 is POST fader only... this means that the channel faders control the AUX3 level as well as the aux out level. Make sure you use TRS balanced lines to your speakers and not TS cables.
Sep 02, 2011 | Soundcraft FX16ii 16Channel Audio Mixer
I have a Pioneer DEH-P5200 and i plugged the aux chords in the back to my ipod but dont know how to switch to the aux mode on radio...
OK - had the same problem and got it finally figured out. Power the unit on the ignition key. Press and hold the source button so the unit shuts off. With the unit shut off press and hold the function button (the key is to hold the function button down) The clock, aux etc will show on the screen. Press (but do not hold) the function button and it will move to each function. When you get to the AUX press the ^ button and the will switch the AUX to "on". Once you know, like everything else, it's pretty easy.
Nov 29, 2010 | Pioneer DEH-P5200 CD Player
No sound thru surround sound system in TV Mode
You need to connect your TV to the AUX connection in the back of your HT system. Then set your HT system on AUX 1 and wait about 5 seconds for the TV sound to come through. If it does not work on AUX 1, you may have to try on AUX 2 or AUX 3 settings on your HT system. Make sure the A/V cable you use is good and in working order and is a good quality cable.
Hope that helps, Gary
Jan 30, 2009 | Samsung HTZ-510 Theater System
Programming AUX as a channel.
pick up a universal remote
Mar 28, 2008 | Televison & Video
Wiring with a sattelite receiver and new Samsung TV
Nope RamaTheMan - you are incorrect! No way to get an actual surroundsound from your TV on this turd - this came straight from the Samsung FAQ -
"You cannot get surround sound from your television. On the other hand, if your television has audio output jacks you can connect your TV or Set Top Box to your Home Theater System and get stereo sound (that is, sound from the left and right speakers of your Home Theater System only).
To connect your TV or STB audio output jacks to your Home Theater System and get stereo sound, follow these steps:
  1. Turn off your TV and Home Theater System.
  2. Connect the Audio Out jacks on your TV to the External Audio Input jacks on the back of your Home Theater System. The External Audio Input connectors are typically labeled AUX IN. Note: There are usually two pairs of Audio Input jacks, AUX 1 and AUX 2. Each pair has a jack for the left audio input and the right audio input. Often, there are two Video AUX IN jacks as well. You can plug the audio cables into either audio AUX 1 or AUX 2. See the following diagram.
  1. Turn on your TV and Home Theater System.
  2. Press the Function Button on the front panel of your Home Theater System until the display on your Home Theater System shows AUX 1 or AUX 2.
For advanced installation, if you are using a High Def STB, you can connect an OPTICAL connection from the STB to the HTS. This is a specified cable that must be purchased separately.
In either instance, you must then set the HTS to its auxiliary input. (i.e AUX 1, AUX 2, DIGITAL IN) in order to get the sound from the HTS.
Note: If your television does not have Audio Out jacks, you may be able to get stereo sound by attaching the Audio Out jacks on your VCR to either the AUX 1 or AUX 2 audio inputs on your Home Theater System. If you attach your VCR to AUX 1 or AUX 2, you will have to tune your television to channel 3 or 4, and then tune to the station you want to watch on your VCR."
Dec 26, 2007 | Samsung HT-X50 System
Got an aux cord to plug my ipod in, doesnt switch to "aux in" mode
According to the manual, you need to "enable" the AUX 1 or 2 thru the initial settings menu.
Press and hold the SRC until the unit turns off. Then press and hold the MULTI CONTROL (knob) until the Language appears. Turn the knob to cycle thru the options, select AUX 1 or 2 and press the knob again to select ON.
After selecting them to on, power the unit on and press the SRC to cycle thru the sources to find AUX 1 or 2.
The owners manual is here if you need it;
http://www.pioneerelectronics.com/pna/v3/pg/support/details/0,,2076_310070337_338818745,00.html
Best of Luck.
Nov 18, 2007 | Pioneer DEH-P6900UB CD Player
Sansui HDLCD3200 TV Logo
131 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
