Question about Dryers
Where does the high limit thermostat go on a whirlpool dryer
My whirlpool dryer wont start, I replaced the start switch and the door switch seems fine. I hear a ticking noise
The door switch may not be making contact. All dryers also have a High Limit thermostat that shuts down the dryer when too hot. The high limit thermostat should reset when the dryer is cooled off but may be defective. If the dryer is electric, 110 volts run the drum motor, and the other leg of the 220 line is for the heating element.
May 05, 2014 | Whirlpool Dryers
I have a Kenmore electric (front load) dryer, model number 84092500 that would spin but does not produce any heat. I tried cleaning/vacuumin the tubing that vents to the outside and resetting the circuit...
The first step of the fix has been done by cleaning the lint filter and the vent system.The next step is replacing the thermal cut-off and the high-limit thermostat both located on the blower housing. It is common that the dryer stops heating when the thermal cut-off blows open due to the failure of the high-limit thermostat to cycle off and regulate the heater temperature. The thermal cut-off cuts power to the heating element should the high-limit thermostat fails and the dryer temperature goes extremely high as a safety feature. Click on the links below for the troubleshooting and repair details.
Whirlpool and Whirlpool-made Electric Dryers (With Removable Back Panel) Not Heating
Whirlpool and Whirlpool-made Electric Dryers (Without Removable Back Panel) Not Heating
Jun 19, 2011 | Kenmore Dryers
My whirlpool leb 6000 pqo will not heat
check heating coils, high limit, temp selector switch.
Apr 05, 2011 | Whirlpool Dryers
Kenmore dryer blows cold air. I replaced heat element still no luck? model 96263800
It doesn't necessarily mean the heating element is busted when an electric dryer stops heating. The heating circuit is not just composed solely by the heating element, it is composed by the thermal cut-off, high-limit thermostat, cycling thermostat, motor centrifugal switch, and the timer. The first thing to look at when an electric dryer stops heating is the thermal cut-off. It cuts power to the heating element when it blows most likely due to the failure of the high-limit thermostat. The thermal cut-off must be replaced, together with the high-limit thermostat, if found open. Click on the link below for the detailed instructions in troubleshooting this problem.
Troubleshooting Whirlpool and Whirlpool-Made Electric Dryers (Filter on Top and with Removable Back Panel) Running But Not Heating
Mar 25, 2011 | Kenmore Dryers
No a kenmore 80 series dryer will not heat . if the heating elment is good & fuse is good what else could be the problem
The heating circuit is basically composed of the heating element, thermal cut-off, high-limit thermostat, cycling thermostat, and the motor centrifugal switch. The problem is very likely in the thermal cut-off and the high-limit thermostat located on the blower housing. The thermal cut-off blows when the high-limit thermostat fails and cuts power to the heating element. Both the thermal cut-off and the high-limit thermostat need to be replaced if the former is blown open. Click on the link below for the detailed instructions in troubleshooting this kind of problem.
Troubleshooting Whirlpool and Whirlpool-Made Electric Dryers Running But Not Heating
Mar 09, 2011 | Kenmore Elite HE3 Steam 8676 Dryer
Dryer wont heat
The problem is likely the thermal cut-off and/or the high-limit thermostat if the dryer runs but doesn't heat. Verify this by bypassing the thermal cut-off and the high-limit thermostat. Click on the link below for the detailed troubleshooting.
Feb 18, 2011 | Whirlpool GEW9200L Electric Dryer
LER4634EQO Whirlpool Heavy Duty Extra Large Capacity 4 cycle 3 temptures My dryer is not heating. I have checked the breaker(s). There is not much lint around the dryer in the back or the vent, what...
The problem is likely in the thermal cut-off (cut-out) and the high-limit thermostat located on the heating element housing. Verify this condition by bypassing the said components. Disconnect power then remove the rear access panel to access the thermal cut-off (cut-out) and the high-limit thermostat. Disconnect the wires of each component then connect them together and insulate it properly. Reconnect power then start the dryer. The problem is indeed in the thermal cut-off (cut-out) and the high-limit thermostat if the dryer heats up. Replace both parts and it should solve the problem. It is an easy and cheap repair to make.
The
thermal cut-off (cut-out) and high-limit thermostat are sold as a kit with part number 279816 and costs about $30.
In case the dryer still doesn't heat up with the
thermal cut-off (cut-out) and high-limit thermostat bypassed, bypass the cycling thermostat then replace it if the dryer heats up. Check the heating element for broken coils if the dryer still doesn't heat up with the three components mentioned above bypassed.
Feb 10, 2011 | Whirlpool LER4634J Electric Dryer
I have a thin twin stacking whirlpool washer/dryer. The high limit switch is kicking off the element within 2 mins of running. So heating element heats up red hot, then clicks off after 2 mins. I have...
I think you are on the right track with a faulty high limit switch. When i serviced these units we always replaced the operating thermostat and the high limit switch together they came in a kit. The operating thermostat in theory should never let it get hot enough to trip the high limit switch, which is really just a safety backup for the operating thermostat. Get the kit and replace both, and also make sure your exhaust vent going outside has good flow at the outside vent,a restricted vent system will cause similar issues.. Good Luck
Oct 07, 2010 | Whirlpool LTE6234D Top Load Stacked...
Whirlpool LER7646JQO Electric Dryer turns on, drum turning, runs for 3 to 5 minutes then clicks and shuts off. Smells like it is burning. No kink in hose vent or lint clogs.
Most dryers have more than one thermostat.
Most likely, the operating thermostat has failed, but the high limit thermostat is working and turns off the machine when it gets too hot. When it cools down it will start again and run briefly. If the high limit thermostat fails, the thermal fuse will permanently stop the dryer to prevent a fire.
Apr 07, 2010 | Whirlpool Dryers
WHIRLPOOL DRYER MODEL LEQ8858JQO
Thermostat, High limit and low limit thermostat or even a safety Temp limiter. All three are similar in cost and located on the back inside of the dryer and 1 by the airflow tube under the lint trap.
Apr 08, 2008 | Whirlpool LEQ8858J Dryer
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
