HP Laserjet Cp2025n Printer Logo
Posted on Oct 15, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i print two sided automatically? - HP Laserjet Cp2025n Printer
Ikhlaq Hussain
Level 3:
Master:
Sergeant:
  • Master 381 Answers
  • Posted on Oct 15, 2010
Ikhlaq Hussain
Master
Level 3:
Master:
Sergeant:
Answers
381
Questions
Helped
79052
Points
1135
You will need to select this in printer settings and save as default
1helpful
3answers
My Epson L120 won't print on both sides whenever I print on my Mac OS: Monterey?
Unfortunately, 2-sided printing is only available for the Epson L20 when used with the Windows OS. See page 22 of the user guide available here: https://www.epson.com.ph/Ink-Tank-Printers/L-Series/Epson-L120/s/SPT_C11CD76401?review-filter=Mac+OS+X+10.11.x#manuals . The current link to the manual is http://support2.epson.net/manuals/english/ij/l120/pdf/npd4965-00.pdf . You might be able to use the Duplex feature if you install BootCamp and an licensed version of Windows (XP up to WIndows 10). Neither BootCamp or licensed copies of Windows are free.
I wish that I had better news for you.
How to duplex print with 895cxi
This model printer does not have a duplex unit and cannot print double sided documents automatically.
DOUBLE SIDED PRINTING USING A SINGLE SIDED PRINTER
If your printer does not have a duplex unit then the printercannot print double sided pages automatically.
You can print double sided pages but you have to do it one page at a time.
First print Page 1 then place the page back into the paper tray, but turn thepage upside down and the print Page 2.
Then print page 3 on one side then page 4 on the other side and repeat for therest of the document.
I suggest you try a test page first, to get the printing the right way up onboth sides of the page so it reads correctly.
How do i get my hp officejet j6480 all in one scan both sides and print
To automatically scan and print, you need to use the automatic document feeder (for letter-sized documents) and have the HP Automatic Two-sided Printing Accessory installed.
Then to use the duplex printing feature, you need to set the printer properties to use the duplex feature. In Windows, open a document to print then click on File Print. Choose Setup and then Properties or Preferences (depending on your OS). Then click on the Features tab and set Two-sided Printing to Automatic. (This is a drop-down menu on the Features tab.)
You also need to set the scan settings for two-sided in the HP Solution Center. (If you just want to copy the document, you can set this from the Control Panel on the J4680.)
If you want to do this manually, you can scan each side of the pages. Then print them one page at a time. Then when the ink is dry, put the page back into the paper tray. (Note: this could result in paper jams.) The printer prints on the underside of each page put into the paper tray with the top of the page printing on the forward part of the page.
I hope this helps.
How do you print duplex on a HP Laser Jet 4650n
You have to print the first side then take those prints and put them back into the paper tray to print the second side (Manual Duplex). If this were a DN model it would have built in automatic duplexing and you cound select "duplex printing" from your print setup screen and the printer would print both sides automatically.
1helpful
Does the Lexmark X9575 print automaticly 2 sided with no manual feed. I have a 15 page document doulbe sided. How do I print this without babysitting the printer. Thank you
Your model supports automatic duplex printing using letter and A4 sizes ONLY. If you want to print two-sided documents on another type or size of paper, use the manual duplexing method.
1) With a document open, click "File" > "Print..."
2) Click "Properties" or "Preferences" or "Options" or "Setup" depending on your system
3) Click the "Advanced" tab
4) From the "2-Sided Printing" area, select the 2-Sided Printing option and then select either the "Sideflip" or "Topflip" option (sideflip is the setting most often used)
5) From the drop-down box, select Automatic.
6) You will see an "Extend dry time" option, which allows extra drying time between sides when you are printing on both sides of the paper. The Automatic 2-Sided Printing option affords enough time for the ink to dry on supported paper types in average air humidity. Under conditions of high humidity, or if the normal drying time does not allow the ink to dry completely, you should select Extend dry time.
7) Click <OK> to close any printer software dialogs that are open. This will take you back to the General Print screen.
8) Click "Print"
Note: To return to single-sided printing, return to the Advanced tab. From the 2-Sided Printing area, clear the 2-Sided Printing check box.
Can not print on two side of the paper
Not enough info. Not all printers are capable of printing 2 sides automatically, most are manual. You print one side, turn over the paper in the feeder and print the second side. Read your manual to see if it does 2 sided printing automatically.
How do I print double-sided automatically? HP Color LaserJet 2605
Go into the control panel, select the printer, select printing preferences, select finishing, put a checkmark in box where it says "print both sides"
3answers
HP Laserjet 2015n printer
Sir, the Hp LaserJet 2015n printer CANNOT automatically do duplex printing since the printer does not include mechanism and paper storage areas to cycle the paper through the printer a second time and print on the reverse side. Manual duplex printing can be done as follows: Choose duplex printing and remove all sheets after the printing is complete. Turn the sheets over while preserving the orientation and insert them in the paper feed path. I have an HP 1020 laserjet printer which is similar to the 2015.
3helpful
2answers
Do pixma Mp610 support duplex printing
The MP610 does support duplex printing.
Duplex Printing
The duplex printing function allows you to print data on both sides of a sheet of paper.
The procedure for performing duplex printing is as follows:
Performing automatic duplex printing
You can perform the duplex printing without having to turn over the paper.
1. Open the printer driver setup window, check the Duplex Printing check box, and confirm that Automatic is checked.
2. Select Normal-size Printing (or Fit-to-Page Printing, Scaled Printing or Page Layout Printing) from the Page Layout list.
3. When printing a document that has small margins, click Print Area Setup... and set the print area.
When you perform duplex printing, the print area of the document becomes slightly narrower than usual and the document may not fit on one page.
sub.gifTo print without reducing the page:
Select Use normal-size printing.
sub.gifTo reduce the page slightly during printing:
Select Use reduced printing.
4. Specify Staple Side.
The printer analyzes the Orientation and Page Layout settings, and automatically selects the best staple position. Check the Staple Side setting. If you want to change the setting, select another value from the list.
5. If necessary, click Specify Margin... and set the Margin width.
6. Click OK.
Duplex printing will be started.
Performing duplex printing manually
You can perform the duplex printing manually.
1. Check the Duplex Printing check box and uncheck the Automatic check box on the Page Setup tab.
3. Specify Staple Side.
4. If necessary, click Specify Margin... and set the Margin width.
5. Click OK.
sub.gifIf a media type other than Photo Paper Plus Double Sided is selected for Media Type on the Main tab:
When you execute print, the document will be printed on one side of a sheet of paper. When printing is complete, reload paper according to the displayed message and then click OK. The document will be printed on the opposite side.
sub.gifIf Photo Paper Plus Double Sided is selected for Media Type on the Main tab:
When you execute print, the document will be printed front and back alternately for one sheet at a time. Load the paper according to the displayed messages.
caution.gif Note sub.gifDuplex Printing is unavailable when:
- A media type other than Plain Paper, Photo Paper Plus Double Sided or Hagaki is selected from the Media Type list.
- Poster Printing is selected from the Page Layout list.
sub.gifWhen Booklet Printing is selected from the Page Layout list, Duplex Printing and Staple Side appear grayed out and are unavailable.
sub.gifAfter printing the front page, there is an ink drying wait time before starting to print the back page (Operation stops temporarily). Do not touch the paper during the time. You can change the Ink Drying Wait Time at Custom Settings on the Maintenance tab of the printer driver.
sub.gifWhen you perform the automatic duplex printing for Hagaki, print an address first and then print your message.
refer.gif Tip sub.gifIf you select Photo Paper Plus Double Sided for Media Type on the Main tab, the Duplex Printing check box on the Page Setup tab is not checked automatically. To perform duplex printing, check the Duplex Printing check box.
sub.gifIf the Media Type dialog box appears when performing borderless printing during duplex printing, select Plain Paper or Photo Paper Plus Double Sided.
sub.gifWhen performing the automatic duplex printing, do not use any plain paper smaller than A5. Also, do not select any type of paper other than Plain Paper, Photo Paper Plus Double Sided or Hagaki at Media Type.
sub.gifPhoto Paper Plus Double Sided is highly recommended for printing photographs on both sides of a page.
sub.gifIf the back side of the paper becomes smudged during duplex printing, perform Bottom Plate Cleaning in the Maintenance tab.
k24674
Grand Canyon Tech
Grand Canyon Tech
