Question about Samsung Dryers
Samsung Model # DV203AES/XAC Doesn't dry any more. 2 years old
Circuit board replace and maybe wiring harness.75/25=100dollars parts
Posted on Nov 23, 2010
Samsung Dryer dv203aes/xac will not heat. Drum is rotating and lint was cleared from exhaust.
Check the following:
1. Does it have 220 volts (yes it runs, but dryers run on 110 volts)?
2. Check the heating element and the safety thermostats located on the heat element canister. Low air flow from any restriction like lint build up or mashed ducting or blocked air exhaust vent cap can either trip the safety stats or burn out the element. Clean dryer and exhaust ducting thoroughly and replace bad parts before placing back in service. Poor air flow is the number one problem with "No Heat" dryer issues.
Sep 20, 2016 | Samsung Dryers
Model #dv203aes/xac. it lights up the controls but it just counts down not spininng or heat.
Check for goop gum or junk on the wet sensor inside the dryer under back side of filter. If something is blocking dampness, the dryer analog monitor on the pc will send power to the count down timer for energy savings.
Dec 30, 2015 | Samsung Dryers
SAMSUNG MODEL DV218AEB/XAC LEAKING WATER
Dryers don't use water, washing machines do, so it's probably the washer.
If the dryer is drying, then it's not moisture.
Check the house drain for the washer, watch it drain and make sure it's not backing up, check the drain hose.
Apr 03, 2013 | Samsung DV218AE Electric Dryers
Service (repair) manual for Samsung WF203ANS/XAC
You have this listed in the Projection TV area--try posting a new question in the major appliance area---if you post the model number a expert in that area MAY help you or suggest how to get what you want.
Apr 06, 2012 | Televison & Video
How to dismantle
Where is the element heater of Samsung DV203AES/XAC?
Nov 29, 2011 | Samsung DV218AEW Electric Dryer
I have a barely 1 year old samsung dryer (DV203AES XAC). It used to work fine. Up until about a month ago. The problem we have now is in "Normal" mode (where the machine detects how damp or...
I have the same problem. When the timer approaches 0:00, it adds one hour. Try turning off the power (breaker) for a while and turning it back on. It works for me.
Jan 29, 2011 | Dryers
Hi, I have problems with SAMSUNG Dryer Model # DV665JW/XAC. It does not dry clothes at all. Could u please help!!! cheers, lucina
you probably have a broken wire in the heating element. located on the back of machine, top right corner, behind panel.
remove the two screws
Sep 01, 2010 | Samsung Dryers
Need to read owners manual for samsung wf218an washer
WF218ANB: http://www.samsung.com/us/support/downloads/WF218ANB
WF218ANB/XAC: http://www.samsung.com/us/support/downloads/WF218ANB/XAC
WF218ANW: http://www.samsung.com/us/support/downloads/WF218ANW
Aug 30, 2010 | Freestyle Mongoose Bmx & Owners Manual -...
I have a GE PDW8680 dishwasher. 5 1/2 years old.
sadly when doing DIY repairs you must be able to figure out how to remove and replace the parts. you could search youtube for a video
Oct 16, 2017 | GE 24 in. Profile PDW8680JSS Built-in...
Samsung YP-S3JAB/XAC mp3 player
GOT IT!!!!!
let it convert and try to transfer.....after it reports failed to transfer, go to default folder for converted file(win7 is documents/video/emodio/videos) copy to s3/s3/video.
done
Nov 08, 2008 | Samsung YP-S3JAB Digital Media Player
Dryers Logo
772 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
