Question about Apple PowerBook G4 Mac Notebook
Open case of Apple Powerbook G3
The power has stopped working on my old Mac Powerbook g3. I am trying to get into it to see if there is a simple fix. Any clue how to open case?
  • 186 Answers
Several screws on bottom and the whole top case snaps off. It will take a little time on this model to gently pry. Also, I think the keyboard comes off first before removing the top cover by two finger pegs. It's been a long time since I worked on this model you you'll just have to get in and look around. Very common on this design that the power plug just needs re-soldered to the motherboard.
Posted on Jun 20, 2008
Reinstalling system software
Good question, the wall street is the same as the Pismo. A great and simple machine. I recommend using os x 10.4 as the highest level. You install the system disc in the optical drive and restart it from its pop up menu. then it will prompt you for each step. You can also hold down the option key on startup to select the disc to boot from.
There is a list of key commands on apple support. Easy way to do it is to just let the disk prompt you after it restarts.
Jun 10, 2014 | Apple PowerBook G3 Mac Notebook
Usb not recognized on macintosh powerbook g3
The Powerbook G3 will be using the original USB architecture and I suspect that your flash drives are using USB 2 and are not backwards compatible, so sorry I don't really think it is possible.
Dec 16, 2011 | Apple PowerBook G3 Mac Notebook
Ik zoek een handleiding voor de powerbook G3
Je moet in staat zijn om de handleiding voor de macht boek G3 vinden op Hoop dat dit helpt.
Apr 18, 2011 | Apple PowerBook G3 Mac Notebook
How do I connect to the internet via WIFI with a MAC Powerbook G3 laptop?
The easiest way if your Powerbook doesn't come equipped with an Airport card or isn't capable of supporting an Airport card is to purchase this it slides into the PCMIA slot on your Powerbook G3 (the credit card sized slot on the side of your Powerbook G3). There's support issues and model variations on older Powerbook G3's regarding Airport Card support and they're not as readily available as a standard PCMIA wireless card. This is my best suggestion for your situation.
Jun 01, 2010 | Apple PowerBook G3 Mac Notebook
I use a Mac G3 Wallstreet Powerbook with OSx. Does OSX talk SCSI?
It will only read devices connected unless there is a problem with the scsi port. Also be aware early scsi needed termination to be read.
Apr 08, 2010 | Apple Power Mac G3 Desktop
Apple Mac PowerBook G3 M5343
since apple drives are formatted in HSF+, a file system that windows cannon read, the chances of it even being bossible to run anything on it from a PC is very very slim.
Jan 18, 2010 | Apple PowerBook G3 Mac Notebook
Apple Macintosh PowerBook G3 Start-up problem
Your mac doesn't recognize the system folder. Try to find the original boot disks that came with the machine, and see if you can mount the hard disk while booting from the CDs. If you can, I'd backup the data as soon as possible and reinstall the operating system, including a full hard drive reformat. If you can't see the hard drive from the boot cd, another option is to hold down the T key during startup to boot the mac into "target disk mode" - this will allow you to hook up the g3 to another computer as an external hard disk in order to back up the data.
Oct 21, 2009 | Apple PowerBook G3 Mac Notebook
I have a Powerbook G3. Gets power but does not boot up.
It may not be a fan, it may be the cd drive spinning up. Is there a cd in it?
Jul 18, 2009 | Apple PowerBook G3 266Mhz w/ 14.1" Screen...
My Apple powerbook G3 Mac wont boot up
Hi trunzo,
You need to be aware of a couple of issues with PowerBooks.
1) The plug connection (where you plug into the laptop) attaches to the Audio card. This is a point of frequent physical connection failure, either due to abuse or even significant normal wear & tear. It continued being a problem until Apple came out with the MagSafe connector on the Intel MacBooks. If this is bad, you won't be able to charge your battery, so this will need to be determined first.
If you're lucky, you might try plugging it in and _gently_ applying gentle lateral pressure on the plug - - you might be able to _temporarily_ get a connection (the plug should light-up and your battery (if present) should charge. I've been able to get this to work if the break in the sound card isn't too serious, but eventually, this won't work anymore.
2) These computers are now getting to be 8-11 years old. In computer terms, this is advanced old-age, well beyond retirement. While I personally liked the modular design of these computers (I own 4 Wallstreets, all but one are for parts), I wouldn't consider putting a lot of money into these unless I was going to use them as an old-fashioned case for new internal electronics - - for example, dropping in a motherboard/RAM/CPU from a newer MacBook Pro. (The real killer would be replacing the display - _major_ technical challenge there. And there we're talking a _lot_ of money and lots and lots of spare time to do the engineering. Unless you're doing it for a hobby, its not worth it.) Trying to restore one of these to working condition is going to be a challenge in just finding parts or a battery that isn't completely played-out.
If you want to explore this further as a DIY (Do It yourself) project, I highly recommend as a good source for both how-to guides and replacement parts. The URL for the Mac how-to guides is
If I can be of further assistance, let me know. If this helps or solves the issue, please rate it accordingly.
Thanks in-advance for using,
Jan 23, 2009 | Apple PowerBook G3 Mac Notebook
Apple PowerBook G4 Mac Notebook Logo
727 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
